Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
DELL POWER SUPPLY FOR MONITOR 2001FP - Dell UltraSharp 2001FP 20.1" LCD Monitor
    Problem Solver:
Although this site does not list the 2001fp speciffically it was very helpfull for me to learn about caps on power supply boards. Follow the steps of the "tutor" at the bottom of the page (after the testamonials) and its pretty straight forward.
http://www.lcdalternatives.com/
Posted on Sep 12, 2010
SOURCE: Dell UltraSharp 2001FP 20.1" LCD Monitor REPLACEMENT POWER CABLE
Here is what you need at a good priceLCD MONITOR LSE0202C2090 AC ADAPTERS WHOLESALE
Posted on Feb 05, 2008
proton77
  • 1183 Answers
SOURCE: problem with Dell 2100FP LCD monitor
Dell support , would recommend you to buy a new monitor because , they donot do any repairs on the LCD monitors., except for exchanging them, if they are in warranty. You can try the following people , they do repairs on dell flat panels
http://www.lcdrepair.us/
Thanks
proton
Posted on Nov 26, 2008
c_robertson
  • 123 Answers
SOURCE: Dell 2001FP Monitor Problem
I have seen many of these. It appears the video processor board is dying or dead. You can replace the board or the monitor.
http://www.lcdrepair.us/2001fp-logic.html
This is the board. Not to hard to replace if you have some tech ability.
Posted on Apr 29, 2009
  • 3 Answers
SOURCE: Dell 1905FP Monitor - power supply
Can also be the lamp of the monitor that is slowly dying
Posted on Jun 06, 2009
SOURCE: Dell 2001FP vertical band issue
I'm having the same problem... there's also going to be about 5 years of dust sitting in there, so I hoping it might just be a failure of convective cooling. My first attempt to remove the bezel was unsuccessful, so I wasn't able to go in and look for any swollen capacitors or such. I have blown canned air in the sides, and it's actually doing a little better right now. Probably won't last... having a rather warm summer.
Posted on Jul 22, 2010
Dell UltraSharp 2001FP (Gray) 20.1"
This monitor uses a power supply not just a cord . You can get one on e-bay very cheat . Just type out 2001fp an choose the person you want to get it from .
Feb 09, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell Monitor 2001FP has a circular power supply connection Where can i get one of these??
They are on e-bay for very little . Just type in 2001fp an you will get people who have new power supply .
Feb 08, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
What causes the power brick green light on Dell's 2001fp lcd monitor to 'dim' when connected to the monitor & full brightness when disconnected?
It can be due to bad DC filter caps in the brick or the monitor has short circuits inside and drawing too muck current.
See picture of bad caps here: http://s807.photobucket.com/albums/yy352/budm/Bad%20capacitors/
http://en.wikipedia.org/wiki/Capacitor_plague
The power supply is rated at 20vdc 4.5amp. You can try loading it with 24v bulb rated at 40~50watts and see if it maintain 20vdc output, it should since it is regulated power supply.
Jul 09, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
It doesn't turn on
Check the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 30, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor gone black but shows self test not floating
Sounds as though the control unit has died. There are 3 parts to most monitors. The video processor board, power supply board and the HV/backlight board. You can replace the video processor board.
Make sure you leave the unit unplugged first and set for an hour. Usually no other fix then replace the board.
Apr 29, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Thanks
proton
Aug 02, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
20V AC power adapter for Dell 2001FP 20" LCD monitor
try to contact dell spare parts department. they may give you a good price.
Feb 01, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 1901FP monitor
It is probably either a CCFL back light issue inside the LCD or a set of capacitors on the inverter/power supply board.
Would you be willing to part with it ?
Oct 26, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
214 people viewed this question
Alun Cox
