Just purchased the soleusair ph5-12r-32s and am getting an E2 reading on the display. What does this mean?
3 Suggested Answers
  • 119 Answers
SOURCE: We have a soleusair portable
Remove the water tank and look or feel up to where the float is at and see if it is stuck in the raised position. This is what is keeping the light on and not letting the compressor start.
Posted on Jun 20, 2011
  • 4736 Answers
SOURCE: what does it mean when
Unfortunately, you failed to mention which model GE AC unit you have. But, in most cases, E2 indicates a Sensor Failure Shutdown. Try turning the unit OFF & unplugging it it for 15 minutes. Then plug it back in and turn it ON. Hopefully, during the timeout, the electronics reset and reverted back to the original factory settings. If so, set the controls as you like and see what happens. If the E2 code reappears, contact GE Customer Service. The number should be in your Owner's Manual.
Hope this helped you and thanks for choosing FixYa.
Posted on Jul 23, 2011
My SoleusAir portable air conditioner has an "e4" code.
Here are the SoleusAir error codes...
e2 Room temperature outside of working range of unit (too cold).
e3 Faulty coils - Repairs needed.
e4 Internal frost in the unit - Defrost.
e5 General failure - repair needed.
e7 Reservoir full - Empty the reservoir.
If the unit is freezing up (frosting) you may want to check (clean / replace) the filters.
Sep 13, 2014 | Heating & Cooling
BRIGHT SPOTS ON MULTIMEDIA PROJECTOR SCREEN: SHARP XR-32S-L USED FOR 2.5YEARS DISPLAYS MANY BRIGHT SPOTS ON THE SCREEN? IS THE PROBLEM IN THE DMD? SHOULD REPLACE THE DMD OR BUY A NEW ONE? DINESH MUMBA
it is the problam of your dmd chip i think the dmd chip 304 small like a simcard change the chip your problam will be solved 100%
i will show you the chip
Nov 07, 2012 | Sharp XR-32S Projector
What does it mean when your air conditioner has e2 on the display and is not working was just purchased on 5/28/11?
Jul 23, 2011 | GE Heating & Cooling
How can I disassemble an HP 32s to clean its display? it seem there is mold there.
Go here for instructions:<br><br> http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv007.cgi?read=15885
<br><br>
John :-#)#
Mar 17, 2011 | HP 32sII Calculator
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
Manual for janome 32s
hi, i have a janome 32 sewing machine. everytime i try to sew lycra, the back of the garment does not sew - all the cotton balls up. can you tell me the settings the machine should be on for lycra material.
Feb 21, 2009 | Janome 6019QC Mechanical Sewing Machine
Range displays e2 f1 and beeps every so often
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Oct 26, 2008 | Whirlpool GS460 Gas Kitchen Range
Hi, I brought a Bosch front loader washer 8 weeks ago. It's been working fine. This morning did 1 load of washing, then washed a jersey on wool setting. When i checked to see how the load was going the...
If you look int the back of the care and use there is a section that says, Trouble Shooting minor faults. E02 is a water fault, low water, pinched hose, water turned off, clogged screens in water hose or water valve. Hope this helps. The section tells you what to check. Jeff
Apr 22, 2008 | Washing Machines
Heating & Cooling Logo
190 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
