Question about Microsoft Xbox 360 Console
1 red light on e68 - Microsoft Xbox 360 Console
  • Microsoft Master
  • 4,806 Answers
E68: Hard Drive Error - Hard drive not DMA configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. Also this can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
Regards.
Posted on Jul 04, 2010
4 Suggested Answers
IBeMad
  • 85 Answers
SOURCE: 1 red light on 360
Make sure that all of the pins for the harddrive are lined up properly, and make sure that they aren't bent at all. If that doesn't work, it may just be a faulty drive, in which case you will probably have to replace it(the hard drive).
Posted on Mar 15, 2008
  • 3 Answers
SOURCE: 1 red lights shows on
Maybe you dont't keep ot in a good cooling area. The same thing happened to me. Do this:
Take out your hard drive and let it cool for 5 mins.
Dissconnet all the cables including the controlers.
When your done dissconnet the power cord.
After this is done let the xbox cool for 5-10mins.
Reconnect everything except the hard drive then see if it works. When the xbox is back to normal it is safe to put the hard drive back.
Posted on Apr 19, 2009
XboxRepKit
  • 168 Answers
SOURCE: One red light and E68 code?
This behavior occurs when an Xbox 360 Hard Drive hardware failure occurs.
1. Turn off the console.
2. Remove the hard drive. For more information about how to attach or remove the Xbox 360 Hard Drive
3. Reattach the hard drive, and then turn on the console.
4. Obtain the latest automatic update for the Xbox 360. To do this, connect to Xbox Live.
5. If you continue to experience this behavior, contact Xbox Customer Service.
http://www.xbox.com
020 7365 9792
or 0800 587 1102
Hearing Impaired (TTY device):
0800 587 1103
Above UK offices
US office below:
  • Toll free: (800) 4MY-XBOX
  • Direct dial: (425) 635-7180
  • Hearing impaired (TDD device): (866) 740-9269 or (425) 635-7102
Posted on Sep 28, 2009
Do i need a new hard drive if the one i have gives me the e68 error when it it in the xbox when it isn't in it turns on no red light but when i plug it back in i gives me it again. thank you.
Hello! no need to worry! the E68 error code is one of the more simple things to fix. most of the time it's just simply a hardware fluke. Attached you will find detailed instructions on how to successfully restore your hard drive and eliminate the e68 error code. If unfortunately, you must purchase a new hard drive, you can find reasonably priced drives at your local electronics or computer store.
If the steps listed in the link fail, the contact information for Microsoft is included as well. Good Luck!!
How to Fix The E68 Error Code
Dec 29, 2010 | Microsoft Xbox 360 Console
One red ring, erra 68.
What you need to do is try using the console without the hard drive or with a different hard drive, one red ring means a hardware failure, and the error code e68 is in relation to the hard drive. If using the console with a different hard drive, or none at all doesnt work, ensure that the fans are working as they often also cause the e68 error and a single flashing red light.
I hope this helps. Good luck.
Sep 03, 2010 | Microsoft Xbox 360 Console
Red light at right bottom plus on screen it says e68
E68 is a harddrive error. Remove the harddrive and try it.
Jul 10, 2010 | Microsoft Xbox 360 Console
System error E68 - red light on not able to play
E68 is a problem with your harddrive, try taking out the harddrive then trying the xbox, if it is still sealed phone up mircosoft
Jan 24, 2010 | Microsoft Xbox 360 Pro System Console
1 red ring E68
The single red light on the Xbox shows that there is a hardware failure.
The E68 error is linked to a problem with the Xbox 360 Hard drive. Try removing the hard drive from the Xbox and attempt to use the Xbox again.
If the error does not occur when the hard drive is not connected then you will need to replace the hard drive.
If the error still occurs then the console will need to be repaired.
Nov 17, 2009 | Microsoft Video Game Consoles & Games
Got system error E68-and a red light-this has happened after using a hard drive to save my game data-now can't find any data-would appreciate assistance!!!
I've got a permanent fix for Error E68 to help you out, But first ill tell you my XBox was dropped so it might have just worked for mine, i will be posting a vid on youtube by Nov. 5 2009 look for imthatstupidkid fix X Box Error E68 walkthrough
Oct 20, 2009 | Microsoft Xbox 360 Console
http://www.xbox.com
020 7365 9792
or 0800 587 1102
0800 587 1103
Above UK offices
US office below:
Sep 28, 2009 | Microsoft Xbox 360 Console
XBOX READING E68
This error code appears in the center of a black screen on the television or on the monitor. If you receive a different error message, you are experiencing a different issue. For more information about what to do if one red light flashes and you receive a different error message, click the following article number to view the article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/)
Mar 17, 2008 | Video Game Consoles & Games
System error E68
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
Feb 25, 2008 | Video Game Consoles & Games
Xboxe 360 console arcade
you got the red lights of doom #1 suggestion make sure your harddrive is plugged in all the way #2 make sure all cables are pluuged in if thats not it go onto the web fin da video of how to get three red light instead of one nd send it into microsoft becuase your warranty cover three lights not 1 or 2
Jan 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
90 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
