Question about Drills
I have a 17 inch Craftsman Drill Press model 152.229010. I was moving it out of storage and it fell over. The center pulley on the top that adjusts the speed came loose. Does it have a screw from the bottom to reattach the eccentric to the base. It fits into the hole but it seems as though something must hold it in place. thanks for your help
  • 2,100 Answers
The pulley does fit loose so the quill or the spindle can ride up and down on it. Just has to be snug enough to grab it and spin but loose enough to move up and down. Hop this helps.
Posted on Jul 04, 2010
Drill will not rotate
Did you have to set the chuck into the spindle, or when you got the press, was the chuck already attached to the spindle? With the drill press I got (different brand), I had to set the chuck in the spindle and I put pressure on the chuck to set it in by placing a bit in the chuck and drilling in a piece of wood, which placed pressure on the chuck. If that's not the issue, check to see that the pulleys are turning ( flip the top open). Also check the tension of the pulleys (machine OFF) If there is nothing apparent or obviuosly not working, and if the press is new, yes, I would return it.
Nov 09, 2013 | Craftsman 23 hp 10" Drill Press with Laser...
How to change belt on 17-990x delta drill press
You've probably already tried looking for set screws on the pulleys, both the pulleys that attach to the spindle and the pulleys on the motor shaft, to remove both/either sets of pulleys and allow replacing the belt. I didn't mean to restate the obvious; I'm just brainstorming. I've restored a few old machine tools, and I've found that removing pulleys often requires the use of gear pullers. This is due to slight mushrooming of the ends of the shaft due to heating or hammering. I have even had to file the end of the shaft in one case to reduce the diameter before I could remove the pulley. Also, based on your picture, you might be able to remove the entire motor from its mounting to allow replacing the belt. read more at http://www.bestcordlessdrillhq.com/
Mar 02, 2013 | Delta Used 17-990X 16-1/2" Drill Press
DELTA 17-924 Mortising attachment for chisel bits
Go to the Dewalt Servicenet site (they own Delta) at http://servicenet.dewalt.com/. Put your model number, 17-924, in the parts search box (with the dash, otherwise it can't find it) and you'll go to a page where you can view or download the parts breakdown and instruction manual.
Sep 06, 2012 | Delta 17-924 Mortising Attachment with 1/4...
I need to replace the Rack on a Delta 16 1/2 inch Drill press, model 17925. Do I need to pull the drill head or is there an easier way ?
I looked at a schematic and owners manual for a 17-950, COULDN'T find the one you listed and if I am not mistaken I believe there is a collar holding the rack in position and if you snug the table or somehow keep from falling you can loosen the collar and using the height adjustment move the rack so you can remove it. BUT I also found a dedicated help line that I would suggest calling first about this and the number is 1-800-223-7278.
Feb 25, 2011 | Drills
My craftsman lawn tractor will start but not move. Canyou please help!
mycraftsman lawn tractor model no. 917.273140 motor will start and run will not move
Nov 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Keeps throwing transmission belt
There are belt guides that keep the belts on. They are about as round as a pencil and maybe two or three inches long. They are adjustable, just loosen and move them in towards the pulley but not up against the pulley, and re-tighten.
Apr 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I am using a Delta 17-950L drill press that when I use a 2" Forster bit the spindle stops. drill press is new and have cut approximately 100 2" holes. thought that the bit was dull so I purchased a new bit...
This sounds like a belt tension problem. If the motor pulley is still spinning but the spindle pulley is stopped try increasing the tension on the belts.
If both the pulleys slow down or stop together, then try reducing the spindle speed to give it more torque under load.
Dec 13, 2009 | Dewalt Delta 17 950L 16.5" Twinlaser...
Have replaced drive gear on Craftsman GDO. Everthing engages and chain moves but door only opens 3 inches are so. Have ajusted opening cointrol on side to max and only 3 inches. When I unlatch GD from...
Loosen the chain enough that you can remove it from the pulley on top of the motor unit. Now with the door closed run the motor until the pulley turns in the clockwise direction and stops. Put the chain back on the pulley and tighten. You may have to tweak the up and down limits now.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do you correct excessive drill wobble on a Ryobi 10 inch bench top drill press,model DP101?
First you have to determine if it is the spindle or the chuck assembly. I would go to ereplacementparts.com and look at a breakdown for this tool so you know what the parts look like and then go from there. I couldn't find the schematic on the Ryobi site.
Sep 19, 2009 | Craftsman Drills
Drill Presses problem
If adjustments are necessary, follow the this procedure: Spindle side-play can be minimized by adjusting the locknut located on the left side of the motor unit 1-1/2 inches behind the spindle and towards the bottom of the motor unit. While moving the feed handle up and down, tighten the lock nut until the play is minimized, but not so tight so as to restrict free movement of the spindle. The spindle should return by itself to the full up position. The drive belt tension may be adjusted by removing the top cover and then loosening the two nuts on either side of the motor pulley. Adjust the motor position and tighten the nuts so that moderate finger pressure against the belt causes it to deflect 3/16" to 1/4" (see Figure 6). Excessive belt tension may result in damage to the bearings. Note: Belt tension can also affect the generation of "noise" in the drill press. Although it does not affect drilling accuracy, it may be desirable to adjust the tension for minimum noise. The spindle has been generously oiled at the factory. You may have to periodically wipe off oil that makes its way down the spindle.
Aug 27, 2008 | Makita 6825 Factory Reconditioned Drywall...
Drills Logo
285 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
