Question about Onkyo TX-SR506 Receiver
I think I blew a circuit. Can I fix it myself easily?
What would cause a fuse to blow out as soon as the battery is plugged in?
If problem on wiring circuit somewhere, replacing the parts won't fix it. If fuse 17--10 amp that fuse circuit is hot all the time. You have a short. Disconnect the wiring connector from generator, does the circuit still go to ground. Instead of blowing your fuses, use a test light across the fuse terminals, if the lite comes on, the circuit is still going to ground. Some don't like to use test lite for that test, but, anyway.
Could be problem with fuse box or the wire circuit from fuse to generator. Make sure generator wire connector doesn't show any signs of heating/melting or anything.
If you think the problem is the white wire with black tracer, you might leave a pigtail wire at both ends, hopefully the pigtails are good, then splice in a new wire for testing. If that fixes it, then make the new splices permanent and route the new wire properly.
May 06, 2017 | Ford Cars & Trucks
Blew fuse in survellience camea
Yes. There's a fuse inside soldered to the circuit board
Jan 14, 2014 | Home Security
Blown circuit breaker will not reset and lock into position
Replace the breaker. You could switch it with another same rating just to see if that is the problem.
Nov 14, 2011 | GE Electrical Supplies
Hoptopint wd72 - E15 and wont take water in
Hi, - fixed this myself. Problem was a blocked pipe from front of drum to pressure switch. - The machine was fooled in to thinking it had water in when it hadnt! - hence the error 15. that was also why it would not fill. - im guessing the heater blew because it was on with no water to keep it cool!
Jan 09, 2010 | Hotpoint Ultima WD72 Front Load...
Timer is not working. Can I easily fix this myself
It's not too complicated. Go to you local Maytag daeler to order your new part. Then all you have to do is remove the back cover and replace the timer.
Nov 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
We had a power surge...now it wont work. Can it be fixed
It depends.... on the severity of the surge and what it took out. If your frig. has a circuit board and it just blew that then you could easily fix it. If the surge took out the compressor then you are probably better off getting a new one. You will need to get someone to evaluate what all is wrong before making a final decision.
Nov 14, 2009 | Emerson Refrigerators
PTH5498 Akai TV Concave on top and bottom
I just picked up the same tv for free, and have the same problem.
but mine also has shadows of blue and red everywhere. but yes, it is in fact a convergence problem.
you can buy the part to repair it yourself, but its not as easy as just plugging it in. you have to solder it, plus a resistor(if that blew too), and a fuse(again, if that blew as well).
tvrepairkits.com claims they can make a kit for any tv, i sent them an email to see if they can make one for the akai.
here is the part number for the convergence ic's STK392-040 if youd like to find them on your own.
Jul 03, 2009 | Akai PTH5498 54" Rear Projection...
My blower resistor keeps going out, even after i buy a new one..
As the circuit is through this resistor, and the main load is the blower motor, I think this is taking a higher current than normal to make it turn. You could simply fit a lower rating fuse to the circuit - as this is cheaper to replace, and check the fan to make sure it is easy to spin by hand. If not, try and oil the bearings as a last resort before replacing it.
Jan 08, 2009 | 2001 Jeep Grand Cherokee
What can I do?
Sorry, the PS3 does not have a circuit breaker. Most likely when the power came back on the surge blew the power supply. You can get it serviced by Sony or replace the power supply your self.
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
Onkyo TX-SR506 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
