Question about Hotpoint Washing Machines
My hotpoint ultima wt960 stopped working.no power at all even after i changed the fuse.
dazmaraz
  • 67 Answers
SOURCE: Hotpoint Ultima (WT960)
check filter first as the pressure system is connected to the filter
Posted on Jul 06, 2007
SOURCE: how do you remove the child lock off the washing machine
hold the child lock button down for a few seconds.
Posted on May 09, 2008
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
My WT960 was also very noisey on the spin cycle, but it had been like this since new, but became increasingly loud, to the point it sounded like it was going to explode. Boyfriend took machine apart to find the concrete weight had also loosened, bolts tightened, though awkward to get to. Now the machine spins ALOT silently than before!
Posted on Aug 10, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint wt960 ultima, very noisey when on spin
Remove lower rear panel of washer, remove belt and spin drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then look elsewhere for prob..Could be noisy motor, or loose concrete balance wieght.
Please rate my solution.
Thanks.
Posted on Aug 27, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
Drum has stopped spinning hotpoint wt960
looks like your bearings have gone if you can not move with hands looks like you need a new machine as to pay someone to fix this is a lot hope this helped
Oct 31, 2011 | Hotpoint Ultima WF860 Front Load Washer
I need to download a user manual for a hotpoint ultima wt960 please
Go to---
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on--
HOTPOINT USER MANUALS
Ithe search box, enter your model number, and download the instructions.
Thankyou.
Jan 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
How do i reset my hotpiont ultima lcd wt960 washing machine?
I have a hotpoint wt960 i did 1 load of washing, turned it off. Put next load in then it would not turn back on. any ideas???
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960
this m,eans the water is not entering the machine it iseither the inlet valve or water off at tap
Dec 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT960
its either a fill valve or you water taps are faulty ie; rounded off knobs easey fix please leave feedback good luck
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WT960
may be the fuse in the pug, or the internal fuse within the machine..
Apr 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
123 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
