Question about Danby Silhouette DWC512BL Wine Cooler
I have model DWC282BL. It is four years old. The fan runs but the temp doesn't cool.
Our new Dometic DM2852 will not stop running. Help!
Old solution from a forum but it get sense.
Citation: "It seems like there could be several possibilities:
1. Refrigerator is struggling to keep cool - maybe because of high outside temp, maybe bad seals, maybe other issues. Fan runs all the time because the back of the frig is hot.
2. Refrigerator is cooling ok, but fan runs all the time because there's poor ventilation on the back - maybe vents are blocked in some way.
3. Refrigerator is cooling ok, but fan runs all the time because it has a defective or improperly adjusted ventilation thermostat (that controls the fan).
4. Refrigerator is cooling ok, but fan runs all the time because Dometic did not include a thermostatic control on this model.
I'd suggest checking the manual or calling Dometic to ask about #4. If there is a thermostat controlling the fan, it may be covered under the Dometic warranty (which might be longer than 1 year)."
Feb 06, 2018 | Refrigerators
How to repair fan when it dont come on at high tempreters
What make , model an year vehicle ? Fuse , relay , a computer problem ect... Cooling fan doesn work
Jul 13, 2016 | Cars & Trucks
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
2 year old Bosch B22CS is not keeping temp low enough.
Check the condenser on the bottom back side of the fridge if it is plugged off the freezer will not cool enough. If the condenser fan motor is dead then the freezer will never cool down enough. If that doesn't do it then you are looking at a waxed up cap tobe in which care you will need a professional to take care of the problem. Good luck
Sep 08, 2012 | Bosch B22CS30SNS (22 cu ft) Side by Side...
Cooling fan temp light stays on when air condition is on. fans are not kicking on. Is it the fan module ?
I didn't know it had a light on the dash that said "cooling fan temp".
My 93 doesn't.
The cooling fans are controlled by the computer and turned on when the ac is running or when the engine reaches 220 degrees.
A mechanic would check the fuse and relay for power and the fan motor for power and ground.
Aug 26, 2012 | Cadillac DeVille Cars & Trucks
What temp should my golf run at if the cooling system is operating properly? Runs perfectly on the highway but when i stop start it goes from min temp to only half on the gauge but seems to be runnning...
the temp seems to be fine. 80degrees celsius or less in stop and go traffic is normal,especially since the cooling fans are working and coming on at the proper time. the what seems to be running rough is another problem that doesn't seem to related to the cooling system temp. may want to check the spark plugs for worn electrodes.
Aug 08, 2011 | 1994 Volkswagen Golf
Frigidaire wall oven fan running - door will not unlock
the fan will run untill the oven cools. if it dont shut off you need to shut down power for ten mineuts the reset if still runs you shuold call for service
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 22, 2010 | Ovens
LG Bottom freezer refrigerator Model LFC21760 does not cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages
Sep 28, 2009 | Refrigerators
Fan is running, fridge and freezer not cold
I have a Westinghouse side by side refrig/freezer that the compressor will run but will not cool or freeze. Do you have any suggestions?
Apr 06, 2009 | Refrigerators
Danby Silhouette DWC512BL Wine Cooler Logo
65 people viewed this question
Top Danby Furniture Experts
Charles T Nevin
Charles T Nevin
Dennis Boxerman
jdthefixer
Are you a Danby Furniture Expert? Answer questions, earn points and help others
