Question about Dell Inspiron 1420 Notebook
I just broke my Dell's screen. something heavy for a lap top fell in, and the screen just went form the normal view to a lot of colored lines ( I don't know how to explain it well) . . . is it possible to replace this part of the lap top . . .and are all my documents safe? If I want to get out my document which is the best way?
  • xhina Sep 06, 2010
    Thank you very much!!!
  • joecoolvette
    joecoolvette Dec 14, 2010
    Just to add for someone in the future, the Service Manual to help in replacing that broken LED screen. Click on Display,https://support.dell.com/support/edocs/s...
    Problem Solver:
  • 19 Answers
1) These Dell's usually come "stock" with newer Sata HD's, where your data is stored. As soon as they "free fall" the heads lock, which should save all your data from problems. The HD won't have been damaged, and it sounds like the only thing that is broken is the LCD- if there are lines all over or even on part of the screen, IT CAN NOT BE FIXED. Regardless of what you hear the LCD will need to be replaced- or use an external monitor. Essentially, the impact/drop/falling item on it broke the internal element OF the LCD itself. Good news it's an easy fix. You can do it yourself or bring it to a shop. Ebay sells common LCD's for this kind of laptop.
2) To get your data off, you'll need to remove the HD and have an external 2.5" SATA hard drive enclosure for it as well as a 2nd computer or access to one (to copy the data to). Turn the laptop upside down, and look for the HD (hard drive) cover -it might have a little icon that looks a bit like a 3d-soda can, very small, engraved into the cover or close to it. You'll need a small philips screwdriver. (If you need help finding it, go to dell's website and DL the manual for the 1420 and look up "replacing the hard drive). Once you have the cover open, lift on the tab there (I think it's black- lift straight up once you've unscrewed anything close to it). Once the HD is out, you can unscrew anything attached to it (and pull that little plastic-and metal comb thing off- that's the right-angle connector -don't loose it, they're really hard to find). Plug in the HD to your 2.5" external case, and plug it into your 2nd computer. Copy the files across from your documents and settings/user name, as well as anything else you might want (again, your HD is probably ok, and a new LCD will get you back in business).
To note: you probably WON'T need a whole new LID, just the SCREEN itself. You CAN take these apart easily, though you will need to remove the power-button cover. The steps to replace the LCD yourself should be a different post, but are quite simple, and there is only about... 15-17 screws and a few cables, and you'll only need a philips screwdriver, a small flat screwdriver and the new LCD. Any dell 14.1" wide-screen LCD will work by the way. I'd look on ebay.
good luck and post if you want to try replacing the LCD yourself.
Posted on Sep 05, 2010
Testimonial: "Thank you. I already changed the LCD...but not happy with it. And I'm gonna buy a new laptop. Dell sucks!!! "
  • 748 Answers
I don't exactly understand what you mean by"something heavy for a lap top fell in"...
Did the laptop fly to the floor? Or something heavy hit it, and if so, where? Was it open or closed?
If the screen was hit, and got broken, then the rest should be more or less fine. If however some other part experienced a shock/impact, and the screen pattern is just a symptom of an internal malfunction, then there's no guarantee that the hard disk with your files is fine.
Anyway, you will need to visit a service depot to establish what the damages are. LCD screen panel is replaceable by all means, and if you ask the serviceperson to retrieve data from your disk it is also possible.
Posted on Jul 04, 2010
Testimonial: "The lap top was opened, (in that moment was in the flour) and was ON, I was listening to something , and the small ironing board just fell from the place it was into the computer, and hit the screen, maybe the computer keyboard too (I'm not sure), I don't know if something else is damaged too, (i hope not). Thank you very much for your support!"
Setting the right the screen resolution
Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system. Also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
always click APPLY after making any changes. Right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add to the Toolbar File Edit View Favorites Tools and Help On the top of the internet page you should see some tabs file edit view favorites tools and help Click on the view tab on the drop down list you should see a zoom % and full screen option. Click a different percentage also a text you might try a different text although this will not increase the of the page only the text fonts inside it
There might be a menu button on the monitor where you can adjust reduce / expand the screen s usually located on the underside of the monitor of course this will depend on your brand of monitor.
Apr 15, 2013 | Acer S200hlabd Black 20" 5ms Led...
Screen has colored lines through it
you lap top screens pixels has went bad in it.
Feb 16, 2011 | Compaq PRESARIO CQ60214DX COMPATIBLE...
My cell Nokia 6600 slide fell down have problems with display,screen have lines of multiple colors
In your case only with change your LCD is the answer to solve your problem.because the ink in the lcd was broke and formed like multiple colour line.I hope it help.
Jun 27, 2010 | Nokia 6600 slide Cellular Phone
Verticle lines across my dell lap top
Put your screen saver to black..let the screen saver come on if lines are there you need a new lcd.....if lines are not there uninstalll all graphics drivers reboot your laptop and reinstall this will fix it if not your lcd screen is on its way out.....NEVER CLOSE YOUR LAPTOP AND STAND ON IT THAT IS JUST SILLY THINK ABOUT IT PEOPLE I MEAN COME ON HOW STUPID CAN YOU GET YES PUTTING PRESSURE ON THE LCD WILL REMOVE THE LINES FOR A WHILE BUT THEY WILL COME BACK.
Aug 22, 2009 | Compaq Presario M2000 Notebook
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
Colored lines down the right side of monitor.
Sir
It seems that the lcd screen was damaged you mentioned something fell on it and damaged the lcd. You would need to replace.
Feb 12, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Toshiba M55-S135
check your battery on some other's laptop, i think the battery life is over, you have to replace the battery
Oct 29, 2008 | Toshiba Satellite M55-S135 Notebook
Perpetual windows protection error loop!
use a win ME startup floppy disc. get to DOS and run scandisc.exe on c drive. if still no progress afterward, then repeat but this time, load cd driver and then re-install windows.
Oct 20, 2007 | Computers & Internet
Open Questions:
See all Dell Inspiron 1420 Notebook Questions
Dell Inspiron 1420 Notebook Logo
257 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
