Question about Cameras
How do you connect a camcorder to the av input on a portable dvd player,to use the dvd player as an extra screen when on location, there does not seem to be any leads available
  • 2 more comments
  • video1 Apr 17, 2008
    thanks for your response.
    i am trying to find out how people connect there camcorders to there portable dvd players using the av sockets. so that the portable dvd player can be used as a monitor screen for the camcorder.
    I can only find a lead that has a 4 pole mini jack on one end and 3 phonos on the other, i need 4 pole mini jack on both ends.
    am i missing somthing obvious !!
    thanks
    video1
    the dvd player has an av in and the camera has an av out
    actually, what im saying is do you know where i can buy a lead in the UK to make the connection between camera and dvd player it has to be 4 pole mini jack on both ends.
  • Mike Johnson
    Mike Johnson May 11, 2010
    You can only do the if your Protable DVD has AV in ports? Does it say AV in and out or just out?
  • 477 Answers
Only some of the portable dvd players have AV in and out most have out only.
Posted on Apr 17, 2008
  • Mike Johnson
    Mike Johnson Apr 17, 2008
    check the menu of the p dvd and see if you have a choice of video modes if so try all of them with the camcorder playing a video also check the camcorder on a tv set and make sure it is transfering a output image.
  • Mike Johnson
    Mike Johnson Apr 18, 2008
    try looking on ebay for a svideo cable i think that might be what you are looking for?
Can I connect my to iPod Classic to watch video on Sony DVP-FX970 Portable DVD player? If so, what connection do I need?
The DVP-FX970 uses a composite (3xRCA) to mini-AV (2x mini-plugs) reducing cable. This is Sony part 9-885-103-56 and was included with the DVD player in the original packaging. See https://sony.encompass.com/item/7054170/Sony/9-885-103-56/Av_Cable_(010-0001-206) . Other vendors may also have the cable. You will also need an RCA (3xF) coupler, see http://www.cablestogo.com/product/40647/composite-video-stereo-audio-f-f-coupler-taa-compliant for one option. Connect the composite end of the above cable to one side of the coupler and the other side to the DVD player. Next connect the appropriate iPod Classic video dock, https://www.apple.com/shop/product/MC748AM/A/apple-composite-av-cable , to the other side of the coupler and the iPod Classic. Now, turn on everything and press the Input Select button for the DVD player multiple times until the current input is 'Line In'.
I hope this helps.
Jun 24, 2017 | Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Trying to copy from camcorder to disc.
You should connect your camcorder to an av input on your dvd,either scart or phono.Then put the dvd onto the input channel you have connected to,ie say av2,then your camcorder on play and the dvd on record.Hope this helps
Sep 07, 2009 | Televison & Video
How do you connect the portable dvd player to your big screen tv?
Look on the side of the dvd player you should see a connector that says AV Out or Video Out, you will need a wire that plugs into that which depeding on the model of dvd player can be either the Red / White/ Yellow Phono Plug Leads or a Lead which has the Red / White/ Yellow Phono Plugs and at the other end what appears to be a headphone jack connector with 3 black bands on it indicating that its a 4 Pole Video output cable, then you plug the Phono Plugs into the Phono Sockets on your tv, using your Tv remote you will need to select which input you got the dvd player plugged into this will either be called
Source Or Input Or AV 1-2-3 ect.
jon
Aug 11, 2009 | Initial Televison & Video
Trying to watch DVD played on portable Insignia player on the TV
If you hear a noise, when triying to read DVD, I am shure I´ts teh engine malfunktion.
you must get the mechanisiam or take this to a service.
I´ts very difficult for lenses to get brocken.
Jul 01, 2009 | Insignia IS-PDVD10 Portable DVD Player
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
Can't find the parts I need
Hey, not sure if you still need it, but there's a power cord for the PDM-2727 listed in an Ebay auction. Like you, I need the AV cord, er, at least I think that's the problem. The listing also shows an AV cord available for an extra $5 but it looks generic. Might be compatible though. I don't need the power cord or I'd ask the seller, but you might want to check it out if you still haven't found power cord/AV cable yet.
Mar 02, 2008 | Polaroid 7" Two-Screen Portable DVD Player
Camcorder connect to Insignia dvd/vhs copier unit
connect to front press av input button. set it on av 2. make sure your tv input is set to v2-component.
Dec 24, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Games
try going to radio shack and asking someone who works there to help find a AV female to AV input chord.
hook up the device that has a male AV out plug to the AV female plug and hhok it up to your DVD player
Dec 24, 2007 | Mintek MDP-1770 Portable DVD Player
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
Cameras Logo
44 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
