When trying to connect a wireless connection to the from dsl cable modem on a wireless router a dns error keep occuring on connection test. llthough ip address connection successfull there is no connection of internet how do I rsolve this problem?
    Sergeant:
    Champion:
  • 293 Answers
Try to reconfigure your dsl modem. dhcp should be implemented .
Posted on Apr 17, 2008
I have a d-link router for my laptop and my wireless has worked fine until abotu a month ago my wireless just stopped working, it says that i have full strength connection like all the bars are showing...
this is a DSL router I think
Try pulling the power to the DSL Dlink wi fi router.
For 30 seconds then plug in back in and switch it on again.
If you have a DSL modem attached to the Dlink wi fi device then down power the DSL modem and wait 30 seconds and repower it up. Wait 5 minutes for it to resync with the dsl on the phone line.
As a side note
Have you had the DSL upgraded like from dsl -1 to DSL -2 if yes then check the dsl filter on the phone line sockets can handle DSL - 2
Diagnostics
go to the P.C windows o/s I hope .
Go to command prompt
ping the routers ip address
10.0.0.1 or 192.168.0.1 is the most likely ip address
type in ipconfig
press enter
what is the default gateway (this is the router ip address)
Type in tracert www.google.com
press enter
Can you resolve the DNS name . and get an ip address
if no then DNS server issue check DNS server settings are they on AUTO . in modem or DSL router .
See if the IP hops get to the modem or to the ISP .
May 13, 2017 | D-Link (DI-784) Wireless Router
Well i have a PS3 and i tryed to connect it to my Wireless router it said that the signal strength is 80 to 100% but when i took the connection test it said that it has a DNS error and even it is connected...
in this type of problem open your network connection and put the ip address (192.168.1.1) (most access point uses) in preffered dns server and in default gateway. if required restart your system.
this will solve your problem
Aug 20, 2009 | Linksys Wireless-G WRT54G Router
How to use bellsouth router on windstream internet
yes you have to configure it with the dsl modem plug your modem ether net cable into routers ethernet,open your modem configuration page by typing 192.168.1.1 login by using by default the router login are "admin"and pass word is also" admin" note down dns setting and other setting which yopu may need tosupply the router now open router login page and supply required connection setting change set router default address 192.168.1.2 soit should not conflict whith each other supply dns setting, enable wireless ,set wireless secuirty ,try now sitehr@gmail.com
Aug 16, 2009 | Westell Wirespeed VersaLink...
I do not know how to connect my wireless router to my modem
simply connect by ethernet cable from DSL modem to wireless router define ips give DNS setting of your service provider suyyam@gmail.com
Jul 22, 2009 | Toshiba WRC 1000 Wireless...
Modem to router to hub to wireless
What you can do is test the PS3 while wired to the router first. If that does not work you may need to forward ports on your router so it will allow the PS3 to accept connections through the router firewall.
Nov 26, 2008 | 2wire HomePortal 1000HW DSL Modem and...
How do i fix the dns error on my ps3
reset your router. if this doesnt work restart your cable or dsl modem. you can also try tochange cables. use wireless instaed or wired connection. wifi card goes bad on the ps3 sometimes
Nov 13, 2008 | Sony Playstation 3 (PS3) Console
Internet connection failed but IP address obtained.
Check to make sure that your router has gotten an IP Address from your ISP. Because you PS3 is telling you that it has an IP from your router. This means that the Router to PS3 connection has layer 3 connectivity, but what about from your router to your ISP? check that in the router by logging into the router's web page and going to the status page it should have your information from your ISP if it does not make sure that the main page is set to the proper settings either get IP automatically (Cable Modem) or Get PPPOE (DSL) connection (Make sure that your password information is correct to).
Now after checking these items make sure that you set the router up as the DNS for your network buy setting this on the status page then in your PS3 (set the DNS setting to point to your router, and set your router up as a caching DNS server).
Then power cycle the router after saving everything, and power cycle your PS3 after setting everything. This should clear up your problem.
Thank you,
Shuttle83
Oct 24, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
