SOURCE: TSA locked our TSA002 lock on our samsonite bag
No. That's part of the whole purpose of TSA passkeys; they're held securely and only at ports. If it were easy for anyone else to get hold of them the locks which are TSA approved would become pointless.
You only have three options if you do not want to return to the airport:-
1. Get a locksmith;
2. Cut the lock off/drill it out;
3. If your lock is usually key operated (not a combination) then there will be a number next to the lock barrel (not the TSA number, that just tells the TSA which of their passkeys to use). A Samsonite dealer can order the correct key for you using the number and some even keep them in stock.
SOURCE: I have a Samsonite suitcase
Hi!
Take a look at the instructions here...
An interesting FYI is shown here:
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
SOURCE: i forgot my combination for
Hi Daniel
Wanna give this a try?
On you tube there are some exaples on how to open it where it is difficult to explain verbally
http://www.youtube.com/watch?v=OfchUwkEckI&feature=related
good luck
rene
pls add kuddo's i try to get wizzy
Try asking your questions again in the proper category since the expertise in this area is tripods and cameras, not luggage. If you ended up in tripods after starting in luggage, contact the FixYa staff to correct the problem. The other categories experts will be much better at answering your specific problem than the photo guys.
