Question about Whirlpool RF368LXKS Electric Kitchen Range
We had a lightning storm. Now the oven door is locked and displays eo efo I have the back panel off and am lost on what to do.
  • 15,935 Answers
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
What does it mean when one reads FD in the panel and the lights on the panel aren't stable?
The control board to your range may have been damaged because of the lightning storm. It happens when lightning strikes a power line and sends a surge of power to your home. This large current surge can easily damage electronic circuits. More often than not if a device is on and lightning strikes, that is when the device gets damaged. During large lightning storms it is best to turn off all electronic devices. The electricity going to your house is fine now and that is probably what your electrician checked.
Nov 22, 2017 | Kitchen Ranges
The control panel displays LOC and the time. oven door opens but unable to reset any controls. is there a way to reset the controls??
Look on the panel for a key that says lock or has a key on it and hold it for10 seconds to see if that clears our
Sep 26, 2014 | General Electric CGS990SETSS GE Cafe 30""...
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
Whirlpool gdb307 oven display not working after storm
Some things to consider:
1. There are two thermal fuses on this unit
- one fuse is in the bake/broil element circuit and if blown, would cause no-heat but the display would still light.
- the other thermal fuse is in series with power to the control board, if blown the control board display would be dark and no oven related functions would work
2. There is a low voltage transformer that supplies power to the control board that sometimes gets damaged by lightning surges. This would also cause the display to be dark with no oven functionality.
3. We repair a number of these control boards that are damaged by lightning storms. Here's a link to a related article that might be helpful:
//www.fixyourboard.com/techzone/ovens/e6_f2/e6_f2.html
Best Regards,
Bruce
Mar 03, 2010 | Whirlpool Ovens
We had a power outage and when the power came on the oven says it is locked but is not latched and will not clear. Randy
If you cannot clear the display with the reset/clear button on the range control panel, go to your electric panel and trip the breaker for the range/oven for at least 2 minutes, then turn the breaker back on.
Sometimes when power is lost due to a storm outage, the drop in voltage can cause some of the electronics to act funny and "think" certain buttons were pushed. Simply turning off and back on the power at the panel should clear any minor problem.
If this doens't clear/resolve the problem, it is possible that the electronic controls were damaged and a replacement control module is needed.
Try the easy fix first and see if that helps.
Jul 28, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
I accidently put the lock on my oven.Now the lock will not come off. Please help
Hi
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Please see this link for more information as how to disengage the lock on your Jenn Air Oven---
Door Lock On Oven
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
EO F2 Lock message on oven panel
The solution was to hold down the "start" button for five seconds, which reset the system. I figured out that I had entered the model number of my oven wrong (mistaking a "Z" for a "2"). When I re-entered the correct model number in the "search for manual" section of the Whirlpool site, I was able to access the user manual and find the section that walked me through the correction.
Dec 29, 2008 | Ovens
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Dec 22, 2008 | Jenn-Air Electric Double Oven
Whirlpool RF368LXKS Electric Kitchen Range Logo
83 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
