Question about Nokia 5130 Cellular Phone
Hey , m using nokia 5130 , i need to format my phone memory, but whenever i go to restore factory settings, it ask for a code, and when i enter the code "12345" it says code error...how to reset the code...
  • 149 Answers
Then try using a hard reset the code for your phone is *#7780#. or *#7730# . one of it will work and the default pass code is 12345
Posted on Jul 04, 2010
Nokia 5130 c2 xpress music MASTER RESET CODE
5130 xpress music unlock my phone password? I forget my moblie phone security password
May 08, 2012 | Nokia 5130 Cellular Phone
How to format nokia 5130 format solution
Hello .To format 5130 just select "Restore All" from the phone setting. Open >Menu>> Setting>>Restore Factory setting>>Restore All and enter the security code 12345 or what you have made.If you could not remember the code use this How to Generate Your Phone Security code..Only for Nokia bb5.Thanks for visiting fixya
Mar 18, 2012 | Nokia Cell Phones
Nokia 5130-c factory reset
Open menu >>Setting>> Restore Factory setting >> and select Restore only after this it will ask you to enter the security code.enter the security code (default code) or what you have made .good lcuk
Feb 08, 2012 | Nokia 5130 Cellular Phone
Formmating code for nokia 5130c-2
Hard reset/Format/Restore to Factory Settings the phone by entering *#7370# and you will need to select "YES" for restoring to factory defaults. Remember that it will delete the settings and data saved in the phone not on the memory card but it will still be advisable for you to have a back up of everything before doing so.
Thank you for choosing www.fixya.com
Dec 08, 2011 | Nokia 5130 Cellular Phone
I have problem with my nokia 5130 music player.whenever i press music it says not enough memory update cancelled bt there is nothing on phone memory only games 513kb. pls solve my problem soon i'll b...
hi
restore the factory setting of the phone
1)go to menu
2)Setting
3)setting
4)general
5)factory setting (enter the phone code.default code is 12345)
or if doesn't work try to hard format the ph memory by dialing *#7370# as there is nothing important in ph memory
(NOTE--Bro before hard format pls back up ur phone memory contact as it will delete all the data in phone memory including installed applications in ph memory)
Apr 21, 2011 | Nokia 5130 Cellular Phone
How to formate Nokia 5130 mobile
Hello and Welcome to FixYa
To format your Nokia 5130 Mobile
dial code *#7780# or *#7370# which restores the factory settings and format. it will ask you to confirm that press OK. it will take some time and your handset will be format & restored to original settings. When it ask reset password and u have not changed it before then
Default security code for Nokia is 12345
But if you format the whole phone memory then follow the procedure below
First of all Switch off your phone then press and hold 3 keys combined
  • Green dial key
  • Star key no *
  • No 3 key on keypad
then press the power on to switch on the phone.
  • In the process don't leave the 3 press and hold keys, After some time the phone will format completely
Note: Remember one things this will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your phone is like a new phone. So better is first save all your data and then restore it.
Default security code for nokia is 12345
See my TIP & TRICK to format Nokia Handsets which will help you out briefly.
Anymore help, I am here to help.
Thanks and Keep using FixYa
Mar 23, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
How to reformat my cell phone 5130 xpressmusic
There are three method to format nokia devises.
METHOD1.
There is one software oxicube which can use to format phone memory.
Try following steps this will help you.
Download and INSTALL oxicube in your computer ->connect your phone to computer through USB CABLE ->In phone select PC suite mode ->Go to your phone memory -> delete your all unnecessary stuff.
In this way you can delete all your phone memory data.
METHOD2.
There is no need to format your phone memory.You have to just restore factory setting.This will clean your phone memory .Try following steps:
Go to menu -> click on setting -> select phone ->Click on Restore factory settings -> press OK -> then enter default code 12345 -> then press OK.
METHOD3
There is one code you can use to format your phone memory.
Enter the code *#7370# -> then press OK ->then enter default code 12345 ->in few seconds your mobile phone memory will erase automatically.
I think this will help you.
Mar 08, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
How to do soft format dial
nokia 5130 platform is Series 40 5th Edition, Feature Pack 1.So formatting feature is not available.The only thing you can do is "reset to factory settings"
how to do ------------
menu>settings>restore factory settings
Key in your phone security code when asked.(default code is 12345).
If you want to fully format your phone contact customer care.They can do flashing your firmware and reinstall it.
good luck.
plz rate
Jan 26, 2011 | Nokia 5130 Cellular Phone
How to format nokia5130
you can't format it,but you can restore your phone(similar as formatting).
go to settings-restore factory setting-then set will ask your security code-enter it-then your phone will get restored..
Oct 29, 2010 | Nokia 5130 Cellular Phone
I want to format my nokia 5130 xpress music phone memory HOW CAN I DO THIS..?
Please go to setting then restore factory default & enter your mobile phone security code .
If you dont have security code of your mobile phone, then please in any nokia multimedia mobile install the software names "MCODE" available at any mobile software website.
Now enter ur emei no. when asked u will get a 1o digit code it will be ur new security code
Thank You.
Jan 25, 2010 | Nokia 5130 Cellular Phone
Nokia 5130 Cellular Phone Logo
225 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
