I'm hooking my monitor to my computer and it says out of range what do i need to do
  • Tony Rose
    Tony Rose Jul 04, 2010
    Hi, could you give a bit more detail of what you want to do
  • 748 Answers
It means that the display settings of your computer (resolution, refresh rate) have been set beyond the monitor's capabilities. It's best to boot Windows in Safe Mode, then you should get the picture ok, and set the display settings according to your monitor's optimum resolution and refresh rate.
Posted on Jul 04, 2010
My Asus VK191S monitor comes up with the following error "out of range". How do i solve this
You will need to change the screen resolution of your computer. It means that the monitor cant handle that screen resolution. If your are unable to access your computer because of this my may have to hook it up to a monitor that can handle it then go turn the resolution all the resolution. Then hook up the Asus monitor and work your way up. till its at the highest resolution without saying "out of range" you do this by right clicking on a blank space on the desktop and going to properties or personalize then display settings or a similar tab or category :) hope this helps
Dec 27, 2010 | ASUS LCD Monitor
Says out of range
Out of range means that your computer resolution is set too high for the monitor to understand and accept.
Try restarting the computer with the screen turned on and that may correct it.
If not, You may have to reset your computer resolution to a lower level using a different monitor then hook up the viewsonic.
Aug 18, 2010 | ViewSonic VA1716w Monitor
I just hooked up a new computer and on the monitor it says "video resolution is out of range" How do I fix that? No picture and can't open screen
Go into display options and set the resolution it is not set at the right resolution for the monitor.
800x600, 1024x768 these are the settings you will need to experiment with.
Jun 19, 2010 | HP Pavilion F1703 17" LCD Monitor
Change from a monitor to a flatscreen
You need hook up your old monitor back and set the PC video resolution to 1024 × 768 @ 60Hz which is the native/max resolution of the E15T4, remove the old Dell monitor and connect your E15T4.
You are getting out of range because your PC video resolution is too high for the E15T4 to display.
Apr 28, 2010 | E-Machines eMachines Monitor E15T4
Screen says out of range
I would say that the computer is trying to use a display resolution that the monitor is incapable of displaying. You may have to lower the resolution from the PC before you get a picture. Make sure you install the correct drivers for the monitor onto the new computer and use a different monitor to adjust the display resolution to a level that the monitor is capable of displaying.
Dec 15, 2009 | AOpen F2705 17" LCD Monitor
Out of range
I usually see this caused by settings on the computer that the monitor can not handle.
Lower the resolution on your computer or raise it slightly if resolution is already low.
If that doesn't work, check other settings like refresh rate. Pretty much, just make sure all settings can be handled by the new monitor. You can find out exactly what the monitor can handle by looking at its specs.
Sep 17, 2009 | Westinghouse L2046NV Monitor
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
Out of Range
Usually with the resolution your computer's set resolution for ur display is to high for the screen
try using a different screen to change the frame refresh rate and resolution to ur monitor
Oct 21, 2008 | X2Gen MG19MY 19" LCD Monitor
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
