Whats the best way to repair a speaker that has a small cut on the foam edge of it
  • tr_st Jul 04, 2010
    that was very helpful thanks for the diy repair suggestion if you know a way to do it with out having to BUY parts or by replacing it. That only comes from experience thank you
    President:
  • 1,197 Answers
Stereo speakers can certainly be durable and can withstand years of use before needing to be replaced. Finding a tear in the foam of your speakers, however, can be devastating as fully replacing your speakers can be extremely expensive. Thankfully, you should be able to repair tears in the foam of your speakers on your own with some care and time. Knowing how to do this can save you plenty of money and the aggravation of trying to replace whole speaker sets.
    Repair Small Tears
  1. Step 1 Remove the speaker cone from the speaker. Take note of all tears in the foam surround of the speaker.
  2. Step 2 Tear or cut off a piece of toilet paper, tissue paper or other thin paper product that is large enough to cover the tear and about an inch in all directions around the tear. Do this for all tears that may appear in your speaker foam.
  3. Step 3 Apply a layer of glue or contact cement to the paper patch as well as to the back of the speaker foam. Place the patch firmly into place over the tear.
  4. Step 4 Allow the glue to dry completely; depending on your adhesive product, you may need to wait overnight for the adhesive to dry. Apply more glue as necessary to secure edges or areas that did not stick appropriately.
  5. Step 5 Allow all adhesive to dry completely before returning the speaker to use.
  6. Replace the Foam
  7. Step 1 Purchase a speaker repair kit from an electronics supply store, such as Radio Shack. Kits will come with new foam for your speaker as well as adhesive.
  8. Step 2 Remove the speaker cone from the speaker; make sure you get all of the foam, particularly if it is deteriorating or falling out. If you are unsure about how to remove your speaker, consult your product's manual or the manufacturer's website as instructions vary by product.
  9. Step 3 Remove the cardboard gasket from the speaker cone by carefully prying it with the edge of a utility knife or razor. This may take several passes, so be patient. If possible, preserve the gasket; some repair kits may include spare gaskets, but some will charge extra.
  10. Step 4 Scrape away any old foam residue or adhesive residue from the steel frame around the cone. You don't need to get every speck of old adhesive off; your goal is a smooth surface for the new adhesive to stick to.
  11. Step 5 Place about 1/8 of an inch of adhesive onto the steel frame and also onto the back of your new foam surround. Spread it around with your finger or with your utility knife until it forms a smooth, even layer.
  12. Step 6 Apply the foam to the frame before the adhesive has time to dry. Apply pressure in appropriate places to ensure the foam sticks evenly. Allow this adhesive a few minutes to set and dry.
  13. Step 7 Lift the edge of the foam gently and apply a thin layer of glue to the edge and also to the side of the steel frame. Apply pressure on all sides of the foam to adhere it to the side of the steel frame. Allow all adhesive to dry.
  14. Step 8 Reinstall the cone into the speaker once all adhesive is dry.
note:
When you remove the cone from the speaker, take note of how the wires hook up so that you can properly reinstall it later.
  • If necessary, you can rub a small amount of rubbing alcohol on old foam or adhesive to loosen its hold on the steel frame.
  • Read more: How to Fix a Tear in a Speaker Foam With Glue | eHow.com http://www.ehow.com/how_5838838_fix-tear-speaker-foam-glue.html#ixzz0si0osI70
    you can additionally refer to the following site which has a pictorial description of how to repair the foam edge.
    http://www.decware.com/newsite/refoam.htm
    Good luck with your Fix
    Have a nice day
    Posted on Jul 04, 2010
    Can i rebuild a jl audio 10w6v2 and how do i do it
    check Amazon for replacement speaker foam kits. Just type in your speaker model followed by repair kit and some should pop up. I replaced my infinity foam a few weeks back with no problems.
    Apr 20, 2014 | Car Audio & Video
    Subwoofer output distorted
    Check to see if the speaker foam surrounds have disintegrated on your subwoofer. I bet it is. If so the speaker will sound like it is distorting or vibrating. Electrically it should be fine. My 2000 Avalon has this same problem with the 8" JBL subwoofer. It is a common problem and an easy fix. Go online to ebay or Amazon and purchase a speaker foam surround replacement kit (Ranges from $18.00 to $25). Youtube also has "How To" videos on how to repair this on your own. I just ordered my foam kit and awaiting the parts. Here is one for $23 but you can shop around for other deals.
    Toyota JBL Speaker Foam Edge Repair Replacement Kit 86160 AC180 Avalon...
    Feb 24, 2014 | 2005 Toyota Avalon
    I have 2 Kenwood 12" Subs and the outer foam edge
    i think it could be time to throw them away ,unless their is any specialist type place close by that can recone them for you ,i have had some success in the past with thin rubber matting that was for repairing a dingy and cutting it round so it fitted then bonding it in with two pack araldite but it sounded a bit muffled to me but the cars owner was happy as he played it so loud he was no doubt tone death
    Mar 01, 2011 | Kenwood 12" 4-Ohm Single-Voice-Coil...
    Our speakers have a "rattle"
    Without the foam they will definitely rattle as you mentioned.Probably 3/8" - 1/2" thick should do it as it should compress when you reattach the speaker.It really doesn't need to be specifically for speakers.At least I would just find something available cheap.Foam is foam really.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg
    Dec 05, 2010 | ElectroVoice . Speaker
    My 12 L7 the rubber came off the cone and doesnt hit as hard what kind of glue would fix my problem
    Hi, Jr.
    I'm sorry, but glue will not fix this problem. When the rubber or foam edge of a speaker breaks down or deteriorates because of age, it becomes almost like dust, which is why it cracks and then breaks apart and falls away from the speaker. The only way to fix it (besides replacing the speaker) is to replace the edge, or "surround". At this link, http://www.simplyspeakers.com/All-Foam-Kits_c_118-1-3.html, you will find a kit that you can buy to repair your speaker for about $30. The standard 12" repair kit will work if you have an 'angle cone edge attach' type speaker (see the bottom of the page for a picture of what this means). This page, http://www.simplyspeakers.com/speaker-repair-foam-edge-replacement-instructions.html, will show you step by step how to use the kit to repair your speaker.
    Good luck, and please remember to rate my help.
    Thank you for the opportunity to help you.
    Oct 14, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
    I have a 13w7 and i am wondering if its possible to find the replacement foam around the top of the speaker. mine has a tear in it and i find it hard to believe that the speaker would be wasted because of...
    The foam is molded, you can not remold / repair
    If it is a small tear you can repair with a bit of rubber cement. Eventuly it will fail and more will tear causing the sub to sound very bad
    Sep 27, 2010 | Jl Audio 13W7 Car Subwoofer
    Surround seperated from subwoofer
    You can order repair kit here:
    http://www.simplyspeakers.com/2doityourself.htm
    Aug 02, 2008 | Jl Audio 12W3 Car Subwoofer
    50 people viewed this question
     Grubhead
    Grubhead
