Question about Sony The Cartoon Guide to Physics (753182043814)
The forces on the table act on a ring but are said to be concurrent. Explain. If the cords were right would the forces necessarily be concurrent?
A bike traveling at 20km/h on a flat roadway stop pedaling.Make a diagram showing the forces acting on the coasting bike and rider.using newton's second law ,explain how the bike's motion change
How Wide are the Tires?
How much does the Rider Weigh
Is there Wind?
Is there car's going by him that will be effected by the Force of Doppler Effect?
Apr 09, 2013 | Cars & Trucks
How do i fit reducing ring 16mm bore onto a30mm bore table saw blade, to use on a draper table saw
the reducer should fit right onto the shaft, if its the right size. Mic it to ensure. Then the blade should fit on no prob. I use a 30mm to 5/8" adapter on my own General 50-185 saw. Quality(sizing) of adapter is an issue.
Aug 02, 2012 | Saws
Rings twice and goes to general mailbox
Just have to go into vmail system and change the the number of rings till the vmail system answers (in this case 4); check your greeting table make sure the right one is assigned to the lines in question (each line can have a diiferent one or the same); and also make sure the right greeting is assigned to the greeting table you want to use.
Do you have a program manual? If so, it has some sample proramms that would give you a "picture" of this is done, plus flow charts.
Jan 06, 2012 | NorStar T7316E Corded Phone
I have a 10" Delta table saw. It was running rough
Check that the blade is not warped or binding. Don't use long extension cords. Check your home breakers. Also check if the table saw has a breaker. Don't force lumber into the blade too fast and don't jam the lumber between the guide and blade. Try a different outlet and check your wire for breaks. Good luck!
Oct 05, 2011 | Saws
My HP Deskjet 3845 printer had a paper jam and it was removed. It still says it has a paper jam and will not print. How do i fix this?
It sounds like your issue is a sensor is still not happy. Several things happen, but Long story short, you need to get REALLY GOOD LIGHT, get the printer on a table where you can work on it.....
So you need to inspect the entire paper path for foreign material, like torn paper. the sensing typically happens with little plastic levers. These levers get pushed out of position, and force a false indication. any dislodged lever needs to be put back, not necessarily an easy task....
Fortunately, most issues are some teeny tiny tear off of paper, wedged in somewhere.... Inspection and extraction fixes 90% of this issue....
Don't force anything.
Mar 11, 2011 | HP Deskjet 3845 InkJet Printer
Right now, when the phone rings - i have to press the line that is ringing. how can i just pick up the phone when it rings?
Hi, you need to put that extension into the ring group / groups. to do this, with the handset down dial;
TRANSFER 200
Password 1234
1 to enable
SPEAKER key
601.
press the volume key to get to the group(s) you want to be added to, this is the number in the brackets. once you have that press the 3rd soft key under the phone screen, use the volume key again to find 'members' then use your volume key when you get an empty slot - reads NONE, type in your extension number, press TRANSFER to store and exit programming. the video off http://www.abbeytelecom.com will help explain,
Feb 14, 2011 | Samsung Prostar DCS-24B-LCD Corded Phone
Panasonic KX-T7630 Corded Phone need to let all phones ring.
I can explain. If you have the maintenance software with access to ICD groups, you can program it. If you don't, then your Panasonic technician has to do it. It can usually be done remotely.
Carl
Apr 28, 2010 | Panasonic Lands Phones
The bottom right red light is on when i turn my xbox on, what does this mean?
it is similar to the red ring of death on the 360 and it means that it overheated and damaged itself
Nov 23, 2009 | Microsoft Xbox Console
0 and - keys fell out!!!!
hey
This could be a little difficult to explain.. coz the white ring acts as a spring and putting it back on is not hard but difficult to explain.
See first of all on an acer laptop a key has 3 components
the key
the white thing (which holds the key in place)
and a black soft thingy (which actually gets pressed wen u press a button and acts like a spring)
first of all the white ring can be removed and refixed easily .
Youll see 4 small hook like structures on the palce where key needs to be placed ... first place the white ring over there, the white ring has 2 things which come into one another. (try referring to the key where in the white ring is still in place).
now if the black spring like thingy is removed from its place, place it in the center of the ring and put the key on, try moving the key a little, if the key and white ring are put correctly, this will produce a click like sound showing the key is locked by the white ring .. if the white ring is dismantled into 2 parts it could be a little tricky to put them back on.. in that case i guess ull have to check a fixed ring and try and replicate the same for this key
for further assistance feel free to mail me on:
kushalagarwal22@gmail.com
Cheers
Kushal
Aug 27, 2008 | Acer NSK8458AN Keyboard
Lines won't ring
Please explain in detail.
1) How are the lines connected?
2) Which PBX are you using?
Aug 17, 2008 | Panasonic KX-T7453 Corded Phone
Sony The Cartoon Guide to Physics (753182043814) Logo
356 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
