Question about Sony The Cartoon Guide to Physics (753182043814)
A hammock is supported by two hooks at the same level. A man is seated in the hammock. Under what conditions will the pull on each hook be equal to the weight of the man?
2 Suggested Answers
  • 3 Answers
SOURCE: how to hook up equalizer to the amplifier
always remember source, amp, then speakers. ex: cd to eq to amp to speakers and it goes: out from cd player into eq, out from eq into amp, out from amp into speakers . hope this makes it easier for you.
Posted on Jun 23, 2009
What are the different benefits provided by hammock?
The hammock is a swinging piece of material that you can lie back in and drift off and it's absolutely perfect for resting, sleeping or swinging.
It has numerous advantages over other types of seating. Some of it is :
1) They are completely unique and really stand out from other items of furniture
2) They provide relaxation to an extreme level
3) It encourages relaxation.
4) These will increase the enjoyment while vacations by providing comfort.
Well, I always prefer to use ENO Hammock which is breathable and completely made up of from dry nylon which makes it different from other.
Sep 02, 2017 | Miscellaneous
Chain and s links for hammock
Fixya does not sell parts.
Jun 27, 2016 | Televison & Video
How can i Test defrost heater, Check refrigerant leak
Check the defrost heater by doing a continuity test across the heater element leads. An easy way to check for a refrigerant leak is to hook up an ammeter to the unit and check for amperage draw under normal ambient conditions. If draw is equal to or slightly above rated spec the refrigerant level is ok. If amperage is low then the charge is lacking and the compressor works less and uses less electricity.
Aug 05, 2015 | Fisher and Paykel Refrigerators
Can i set a hammock indoors?
Certainly. There are many ways to hang a hammock even without trees.
Somme hammocks include self-standing metal or wood structures that support the hammock. Otherwise it is possible to hang it from the walls or cealing. Best if at a 30 degrees angle circa.
Dec 05, 2013 | Garden
Handlebars are bent
Instructions
YZF600R (1994 - 2007)
Insert the ignition key into the seat lock, located on the left side of the tail fairing above the left passenger foot peg. Twist the key clockwise to release the seat lock mechanism.
Grasp the rear portion of the seat and lift it off of the motorcycle's subframe. Pull the front of the seat away from the gas tank until the tab under the front of the seat is free of the subframe.
Hold the seat over the subframe to reinstall it. Hook the seat's tab under the cross-member below the base of the gas tank.
Push the seat forward slightly, then lower the rear of the seat onto the motorcycle's subframe.
5
Push down on the rear of the seat until the seat lock mechanism clicks into place. Remove the ignition key from the seat lock.
YZF-R6 (1998 - Present)
6
Insert the ignition key into the seat lock on the left side of the tail fairing. 2006 and newer R6 models place the seat lock under the tail fairing, near the left rear foot peg. Twist the key clockwise to release the seat lock mechanism.
7
Grasp the rear of the passenger seat and lift it up slightly. Pull the seat toward the rear of the motorcycle until the hooks under the front of the seat are free of the tabs built into the subframe under the tail fairing.
8
Pull the rear corners of the rider's seat up to reveal both mounting bolts. Unscrew the bolts with a 5 mm Allen wrench. Lift the rear of the seat up, then pull it away from the gas tank until the tabs under the front of the seat are free of the cross-member below the base of the gas tank.
9
Slide the rider's seat tabs under the frame cross-member to reinstall the seat. Lower the back of the seat onto the subframe, then screw the mounting bolts into place with a 5 mm Allen wrench.
10
Hook the front of the passenger seat onto the tabs built into the subframe under the tail fairing. Lower the seat onto the fairing and press down until the seat lock mechanism clicks into place. Remove the ignition key from the seat lock.
Jan 15, 2013 | Yamaha XT 125 X Motorcycles
Hi, I just purchased a used set of 901s with the original active equalizer. they are both series VI and were bought together. Unfortunately, the man misplaced the installation instructions for the...
If no Amp is used, connect jacks ( Left, Right) from your receiver output to Bose equalizer Input ( L, R) where it says Amplifier. Then also under where it says Amplifier, connect jacks from Output to your speakers. This would require the type of speaker wires that are RCA (plug in, red and white) on one end bare wire on the other to the speakers.
I don't know what the output is on your Kenwood, but if it's low watts, an amp is much better to crank those Bose. It's a different connect with an amp. Go L &R from the receiver to Equalizer as before, then from equalizer to amp Input where it says Tuner. then hook bare speaker wires to back of amp to Bose speakers.
You should have full use of Bose controls. The Monitor button is for an extra component that can be hooked up on the back, right side of equalizer.
Jul 15, 2009 | Bose 901 VI Main / Stereo Speaker
Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
How to hook the eq up??
take output from left and right from equalizer and go to line in any two channels inputs in peavey mixing console and adjust your level with faders and other control knobs.
Mar 02, 2008 | Phonic PEQ3400 2x15-band Graphic Equalizer...
Sony The Cartoon Guide to Physics (753182043814) Logo
504 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
