Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
How do change belts on a Zodiac Indigo Pool Cleaner
PartsCenter
  • 125 Answers
SOURCE: Baracuda G3 zodiac Clings to bottom or sides moving slowly
here is a link to the Technical Support at Baracuda. this should be able to solve your problems. initially sounds like maybe too much suction.
Posted on Feb 26, 2009
  • 106 Answers
SOURCE: get stuck in the pool corner
try adding a hose length or taking one piece off. Also you can try increasing or decreasing the suction.
Posted on Jan 15, 2010
jharwell668
  • 640 Answers
SOURCE: Hi, we have a Zodiac
With these pool cleaners, getting stuck in one spot is most likely the result of a waterflow problem. Check your water flow valve and make sure that it is adjusted correctly. make sure that you don't have any blockage that would prevent movement and cause the cleaner to stick in one place. This might seem like common sense, but make sure that you have enough hose to reach the entire pool. Many times, when this occurs, the cleaner cannot reach one part of the pool. make sure that your hose balance is correct also.
Posted on Oct 26, 2010
jharwell668
  • 640 Answers
SOURCE: zodiac pool cleaner stops and starts and sometimes
With these pool cleaners, there are several things that can cause a lack of suction and movement. Make sure that the main drain and all suction lines are closed except the line you are using. Make sure there is no debris in the flapper or filter that could be clogging suction. Check the hose are ensure that there are no leaks. Check the pump basket for looseness, cracks, and worn or missing o-rings.
Posted on Oct 28, 2010
  • 16 Answers
SOURCE: Zodiac G2 Cleaner not moving around pool. Suction
any damage to that diaphram will cause the cleaner to not work. If it is only 6 months old then it is under warranty. any pool store should be able to get you a new diaphram at no cost. bring your paperwork with you to show proof of purchase.
Posted on Dec 29, 2010
Zodiac indigo
Zodiac builds dirt. Jandy used to be pretty good Polaris is hanging by a thread ( both acquired by Zodiac.) I\'m an 18 year veteran in the pool industry. Sorry for the bad luck.
Aug 07, 2013 | Pool & Spa
Zodiac G2 gets stuck at far end of pool in two corners. Each time I have to pull the hose to get it out, then its fine. Anything I can do to stopit getting stuck in the first place, please?
The biggest cause of this is current in the pool driving the cleaner to the corners. You propally just need to change the direction of the eye balls on you returns to the pool. Face them down the pool wall or just in another direction to break up the flow of water in the pool.
Oct 07, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Will not travel into shallow end
The first problem that you have is that you indicated that you have a Zippy pool cleaner by Zodiac. This cleaner is designed for above ground, flat bottomed pools. If you are using it for a dished above ground or in ground pool with a shallow end, the cleaner and the hose itself are not compatible with your pool. That is why it is not going to the shallow end of your pool. I would consider looking for pool cleaners that are designed for in ground pools if you want it to cleaner properly.
Aug 04, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Zodiac has suction but doesn't move
With these pool cleaners, that is often a problem with the flapper. Check the flapper to be sure that no debris is stuck. Debris can halt water flow and movement, making your cleaner get stuck.
Jul 11, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac Baracuda Zippy Pool Cleaner hose tear
I haven't seen any bulletins on the Zippy hoses. You might adjust the flow to the cleaner. You can find the Manual for the zippy cleaner on this page beneith the diagram. It shows how the star control works. You can also contact the Mfg Technical Support at Phone: 800-822-7933 They might be able to warranty a hose or two for you.
Nov 03, 2009 | Zodiac Baracuda Zippy Pool Cleaner
The zodiac G4 pool cleaner has slowed down considerably and now gets stuck on the drain so i have to continually drag it off so it will circle the rest of the pool
Your Zodiac should ballence all suction with the skimmer and no suction should go through the main drain. A main drain is better called a deep suction to collect heavy dird and your cleaner is a roveing suction and replaces the drain. If both are on the two suctions pulling against each other will always stop the cleaner.
Oct 03, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
The cleaner does not move to farthest part of the pool.
Change direction of jets, reverse position of hoses, either add or remove section of hose, increase or decrease suction.
Apr 08, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
174 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
