Question about Detecto 2391 Eye Level Physician Mechanical Beam Scale
A rope 26 feet long is attached to two points A and B, 20 feet at the same level. A load of 250 lb is carried at the middle of the rope. What forced is exerted on A?
1999 flhr road king shock air pressure
Recommended Suspension Air Pressure: FLHX, FLTRX, FLHR/C
SHOCK LOAD TOTAL WEIGHT PRESSURE
LB. KGPSI kPa
Solo rider up to 150 up to 680 0
150-200 68-91 0-10 0-69
200-250 91-113 10-20 69-138
250-300 113-136 20-30 138-206
over 300over 136 30-50 206-345
Solo rider with capacity
luggage of 40 lbs (18 kg) up to 150 up to 68 10-20 69-138
150-200 68-91 20-30 138-206
200-250 91-113 30-40 206-276
250-300 113-136 40-50 276-345
over 300 over 136 50 345
Rider plus passenger ALL ALL 40-50 276-345
Maximum GVWR ALL ALL 50 345
If Tour-Pak is installed, add 5-10 psi (34-69 kPa) to shock pressure.
Do not exceed 50 psi (345 kPa) suspension pressure.
May 13, 2014 | Harley Davidson FLHR Road king Motorcycles
Tip
Not all ropes are created equally
Choosing the wrong type of rope for the purpose you are going to be using it for can result in injury and / or broken property. It may seem to you that some ropes are a little thicker than others, or that some feel stronger than some others. It is very important that you know what you are going to be using your rope for and doing a little research before you walk into a hardware store and blindly buy just any rope.
For water skiing the ropes that come with the ski isn't made to handle shock loading, this is when the rope goes completely slack and then get taught very quickly. This can lead to injury should the rope snap. This is why many water skiers and water tubers go out to buy replacement ropes.
There are many different strengths of towing ropes and cables, the recommended strengths for tubing are 3,350 lb. break strength, 4,100 lb. break strength and 6,000 lb. break strength. A regular rope that you might pick up at a hardware store might only have a break strength of 1,350 lb. which is not strong enough. Also when you buy the rope specially made it will have the knots already in the rope so you don't have to tie them yourself. When you do tie the knots yourself it tends to reduce the strength of the rope.
Its always better to be safe than sorry. When it comes to safety in a water sport don't take your chances with the cheaper rope, buy the right stuff!
on Jan 05, 2014 | Water Sport
Tip
Military Antennas
In the Army you are out in a field with a radio, a copper wire, a metal stake, and you pitch a tent. Its a radio similar to Cb radio 2 ways. You can run a wire 34 feet across between two trees about 15 feet up. make sure you tie the wire at both ends with Nylon rope(plastic) to the trees. Take the 4 to 6 feet metal rod drive into earth(ground). Attach center coax piece to wire strung between trees at one end. Attach shield to Ground Rod. Another way is to nail a board about 15 feet up, attach a copper wire 34 feet going out one way and another 34 feet the other side. It will form a Pyramid. Tie to two stakes in ground at both ends with nylon rope. It will make do for a fast Cb radio emergency camp radio. It may get stations 15 to 30 miles away. Try camping on a Mountain top with a portable 12 volt battery,Mobile CB, Copper wire, Metal stakes,plastic rope, Square plastic piece 14 inches long or a board piece.
on Apr 01, 2011 | Radio Communications
How do you jump rope?
If there is one person, then that person holds each one end of the rope in each hand. They swing the rope from behind their head, over their head, and then under their feet. When it is under their feet, they must jump over the rope so it turns continuously. The other option is with 3 people where 2 people hold the rope on either end and turn it, while one person or more will jump in the middle. When there are two jump ropes being used this is called double dutch and is a fancier, more difficult version of normal jumping rope.
Jan 03, 2013 | Exercise & Fitness
How long should your jump rope be for exercising?
If you are 6 feet or shorter, than the rope should be 9 feet long. This is the standard jump rope size found in stores. If you are over 6 feet then you'll need a 10 foot rope. Generally, when you hold the rope and stand on the middle with your feet, each end should reach your arm pit.
What are the torque settings for the head bolts on a 1999 ford taurus 3.0L.
This is the factory torque adjustment procedure for a 3.0L, also i post you the bolts tightening sequence. i hope that this could help you
  1. Tighten in five steps (refer to illustration in Cylinder Head Installation for tightening sequence):
    • Tighten in sequence to 47-53 Nm (35-39 Lb-Ft)
    • Then back off all bolts 360 degrees
    • Tighten in sequence to 27-33 Nm (20-24 Lb-Ft)
    • Rotate 85-95 degrees
    • Rotate an additional 85-95 degrees.
  2. Tighten in two steps:
    • 20-30 Nm (15-22 Lb-Ft)
    • 26-32 Nm (20-23 Lb-Ft)
  3. Advance 3/4 to 1 turn after gasket contacts sealing surface or tighten to 13-15 Nm (10-11 Lb-Ft).
  4. Tighten in two steps:
    • 7-15 Nm (6-11 Lb-Ft)
    • 26-38 Nm (20-28 Lb-Ft)
  5. Refer to illustration in the Cylinder Head Installation procedure for tightening sequence.
Mar 20, 2011 | Ford Taurus Cars & Trucks
15 yr old admiral 20 lb. (I think it is model 35-4119 ) walks
You gonna have to remove the front and look for a broken spring, If the springs are all there then the snubber pad probably needs replacing.
Mar 05, 2010 | Washing Machines
Parking brake assembly diagramneeded
Item Part Number Description 1 2553 Rear Disc Brake Caliper 2 4234 LH Axle Shaft 3 2C026 Rear Disc Brake Rotor 4 383609-S Push Nut (2 Req'd each side) 5 2C189 Rear Brake Anti-Lock Sensor Indicator 6A 3912205-56 Nut (4 Req'd) 7 2C220 Rear Wheel Disc Brake Adapter 8 1177 Inner Wheel Bearing Oil Seal 9 390317-S190 Bolt (4 Req'd) 10 1225 Rear Wheel Bearing 11B 2B296 Disc Brake Caliper Locating Pin A Tighten to 27-54 Nm (20-40 Lb-Ft) B Tighten to 26-35 Nm (19-26 Lb-Ft)
The automatic (vacuum) release-type is standard equipment on all vehicles. The automatic vacuum-type parking brake system contains the following features:
  • A parking brake release control motor (2A843) with mounting bracket bolted to the parking brake control .
  • The vacuum-actuated diaphragm within the parking brake release control motor which is connected by a rod to the upper end of the parking brake release vacuum hose (2B653) .
  • The parking brake release vacuum hose which connects the parking brake release control motor to the engine manifold through a vacuum release switch at the steering column tube (3514) .
  • The parking brake release control motor which is actuated to release the parking brake whenever the engine is running and the transmission is in a forward-driving gear.
  • The automatic parking brake control which has a manual release feature that releases the foot parking brake control by applying force to the parking brake control pedal in the "apply" direction to the point of initial application.
  • The parking brake control will return to the full-release position after removing the force.
Apr 14, 2009 | 1994 Lincoln Town Car
I need a diagram of a 1995 ford escort engine
96 escort 1.9L
Engine Components
Item Part Number Description 1 6766 Oil Filler Cap 2 6A548 (8 Req'd) Valve Cover Bolt 3 6582 Valve Cover 4 — Exhaust Manifold Shield-to-Exhaust Manifold Nut (4 Req'd) 5 9A462 Exhaust Manifold Shield 6 — Exhaust Manifold Shield Stud (4 Req'd) 7 9430 Exhaust Manifold 8 9454 Exhaust Manifold Nut 9 9448 Exhaust Manifold Gasket 10 — Exhaust Manifold Stud (Fine Thread), Short (4 Req'd) 11 — Exhaust Manifold Stud, Long (1 Req'd) 12 — Exhaust Manifold Stud (Medium Thread), Short (1 Req'd) 13 6518 Valve Spring Retainer Key 14 6514 Valve Spring Retainer 15 6513 Valve Spring and Damper, Intake 16 6C515 Valve Tappet Guide Plate Retainer 17 6571 Valve Stem Seal 18 6513 Valve Spring, Exhaust 19 12405 Spark Plug 20 6269 Camshaft Thrust Plate 21 — Camshaft Thrust Plate Bolt (2 Req'd) 22 — Cup Plug 23 6B273 Camshaft Oil Flow Control Rod 24 6K292 Camshaft Front Seal 25 6256 Camshaft Sprocket 26 6278 Camshaft Sprocket Washer 27 6K252 Camshaft Sprocket Retaining Bolt 28 6L269 Camshaft Sprocket Key (5 x 18) 29 6250 Camshaft 30 6051 Head Gasket 31 6A008 Cylinder Head to Block Dowel 32 6010 Cylinder Block 33 6507 Intake Valve 34 6505 Exhaust Valve 35 6049 Cylinder Head 36 — Intake Manifold Stud (7 Req'd) 37 17A084 Engine Lifting Eye 38 — Engine Lifting Eye Bolt (2 Req'd) 39 9439 Intake Manifold Gasket 40 — Bolt 41 9723 Accelerator Cable Bracket 42 9424 Intake Manifold 43 — Intake Manifold Nut (7 Req'd) 44 9D476 EGR Valve Gasket 45 — Exhaust Gas Recirculation (EGR) Valve Bolt (2 Req'd) 46 9D475 EGR Valve 47 — Fuel Injection Supply Manifold Bolt
(2 Req'd) 48 9F593 Fuel Injector 49 9D930 Fuel Charging Wiring 50 6786 Oil Level Indicator Tube Bracket 51 — Oil Level Indicator Tube Bracket Bolt 52 6754 Oil Level Indicator Tube 53 6750 Oil Level Dipstick 54 9D280 Fuel Injection Supply Manifold 55 — Vacuum Fitting 56 9E498 Main Emission Vacuum Control Connector 57 — Vacuum Tap 58 — Vacuum Hose 59 9B989 Throttle Position Sensor 60 — Screw and Washer 61 9F782 Throttle Position Sensor Gasket 62 — Throttle Body Bolt (4 Req'd) 63 — Idle Air Control (IAC) Valve Bolt
(2 Req'd) 64 9F715 Idle Air Control Valve 65 9F670 Idle Air Control Gasket 66 9E926 Throttle Body 67 9E936 Throttle Body Gasket 68 — Vacuum Fitting 69 — Camshaft Position Sensor Screw 70 6B288 Camshaft Position Sensor 71 8255 Water Hose Connection Gasket 72 — Water Hose Connection Bolt (3 Req'd) 73 8592 Water Hose Connection 74 8575 Water Thermostat 75 6065 Cylinder Head Bolts 76 6500 Valve Tappet 77 6K512 Valve Tappet Guide Plate 78 6564 Rocker Arm 79 6A528 Rocker Arm Seat 80 6A527 Rocker Arm Bolt (8 Req'd) 81 — Ignition Coil Mounting Bracket Bolt
(3 Req'd) 82 18827 Noise Filter Condenser 83 — Ignition Coil Mounting Bolt (4 Req'd) 84 12259 Spark Plug Wire Set 85 12029 Ignition Coil 86 12043 Ignition Coil Mounting Bracket A — Tighten to 5-12 Nm (4-9 Lb-Ft) B — Tighten to 5-7 Nm (3-5 Lb-Ft) C — Tighten to 21-26 Nm (16-19 Lb-Ft) D — Tighten to 2-10 Nm (1.5-7 Lb-Ft) E — Tighten to 8-13 Nm (6-9 Lb-Ft) F — Tighten to 40-55 Nm (30-41 Lb-Ft) G — Tighten to 16-20 Nm (12-15 Lb-Ft) H — Tighten to 20-30 Nm (15-22 Lb-Ft) I — Tighten to 8-10 Nm (6-8 Lb-Ft) J — Tighten to 8-11 Nm (6-9 Lb-Ft) K — Tighten to 23-30 Nm (17-22 Lb-Ft) L — Tighten to 20-40 Nm (15-30 Lb-Ft) M — Tighten to 4.5-7 Nm (3-5 Lb-Ft) N — Tighten to 18-26 Nm (13-19 Lb-Ft)
Feb 24, 2009 | 1995 Ford Escort
Tiny CD conection cord probe suposed to fit positiveto foot 25 negative foot 26
Actually the pins go on the Slave connector (the connector in the middle of the IDE cable) while the CD/DVD is connector to the Master connector which is on the end.
Apr 02, 2007 | Atrix Black Gamer Case w/ Maximum Filtered...
Detecto 2391 Eye Level Physician Mechanical Beam Scale Logo
133 people viewed this question
Top Detecto Health & Beauty Experts
Rhonda Webster
Rhonda Webster
swetha
swetha
Ashley Bennet
Ashley Bennet
Are you a Detecto Health and Beauty Expert? Answer questions, earn points and help others
