Question about Fuji FinePix A500 Digital Camera
Xd picture card
Bought new card. when inserted in camera states card not initialized Inserted the FujiFilm XD Picture Card M 1GB and the camera says card not inititialized. Have not found how to make it work, tried every setting and even reformated the camera. Tks for hep
    Novelist:
    Champion:
  • 216 Answers
Greetings FredericoIV,
A common fix for this issue is to use an external card reader, and reformat your card using your computer. Make sure you chose FAT format instead of FAT32 or NTFS.
I hope this helps.
Thank you,
Agent Dort
Go Ahead. Use Us.
Posted on Apr 17, 2008
Hit replay button.
Menu.
Option tab, set-up
2 tab, format...
Make sure to move the highlighted bar to ok because if you just hit the ok button right away you will click on cancel and not really format anything.
I thought to present a simple mistake I made a few times when I first had the same problem.
Posted on Nov 13, 2008
Best answer!!! it really works
Posted on Jul 31, 2008
Card not initialized?
The error can be caused by:
1. The xD-Picture Card or internal memory is not formatted.
2. The xD-Picture Card contact area is soiled.
3. a camera fault
for 1.:
Format the xD-Picture Card or internal memory on the camera (p.130)
To format the internal memory or xD card goto format in the setup menu and chose the correct memory.
for 2.:
Wipe the contact area on the xD-Picture Card with a soft, dry cloth. It may be necessary to format the xD-Picture Card
(p.130).
If the message still appears, replace the xD-Picture Card
for 3.: You won't like this one:
Contact your FUJIFILM dealer.
Oct 30, 2013 | Fuji FinePix S6500 Digital Camera
Is olympus xd -picture card,type m+ 2gb compatable with camera Fujifilm Finepix.
XD cards are now obsolete memory cards. The cards were developed by Olympus and Fujifilm and released during the summer of 2002. There is now an adapter that allows an SD card to be used in place of the XD card You need to remember that the capacity should not exceed 2 GB or the camera will not be able to accept it. As far as I know cameras accepting XD cards were last produced in 2007, I don't know what specific models however the camera specifications would show what type card it uses.
Jan 15, 2011 | Olympus 1GB XD Picture Card...
Display says card not initialized when a new xd picture card is inserted in the fuji fine pix A340 how do i initialize or format the card
the camera cannot use XD picture card and multimedia card (MMC). SD and SDHC can be used. for compatibility check this http://www.fujifilm.com/products/digital_cameras/accessories/card/a/ you might need to update your product depending on your serial no.
to format the card, press menu to display menu setup, press right to move to setup 2 (3rd tab) you will see Format. click Format to format the memory ("SD" is displayed if memory card is inserted and "IN" (internal memory) if no memory card. hope this helps
Jul 08, 2009 | Fuji FinePix A340 Digital Camera
I am getting a message that reads "card not initialized". It is a new XD picture card. How do I initialize the card?
To initialize the new XD card, you go into the camera's setup menu and navigate to the format function. Format the card and you might be ready to go. If your new card has an "M" or an "H" preceeding the XD, your camera will need a firmware upgrade before it will recognize the card. Here's a link to the firmware upgrade procedure. http://www.fujifilm.com/products/digital/download/a340/fupd.html
Jun 15, 2009 | Fuji FinePix A340 Digital Camera
NEW CARD
You will need to do a firmware update to be able to use your new 'M' XD card. Also you will need a AC adapter to be able to use the update for your camera.
It is a Fuji site and it works.
Good luck.
http://www.fujifilm.ca/x3719.xml
May 26, 2008 | Fuji FinePix A120 Digital Camera
Xd picture card
Good luck.
I cannot get card to work in my fuji finepix a 340 says write error inserted Olympus Xd picture card . ASfter attemting to take picture, rec'd message that it could not initialize.
If your new xD card is an "H" or "M" type card, it is only compatable with the A340 following a firmware upgrade to the camera. http://www.fujifilm.ca/x3721.xml is a link to the software and steps you can take to perform the upgrade.
Mar 13, 2008 | Fuji FinePix A340 Digital Camera
Xd card not initialized
Go to menu, SET, set-up,FORMAT,push OK Button,read "Format
ERASE ALL DATA" then, choose OK, and ready.
FinePix A 205S
Jan 15, 2008 | Fuji FinePix A205 Digital Camera
Xd picture card
Hi, You have to go to the menu/setup function. Check the different settings. One of them would lead you to the memory card settings, from there you should be able to format the new card. Good luck and kind regards.
Sep 22, 2007 | Fuji FinePix A350 Digital Camera
Fuji FinePix A500 Digital Camera Logo
149 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
