Question about SAMTRON 55V 15" CRT Monitor
Hey. the problem with my monitor is that .....at the top right and left corners of my monitor d colour has been changed to red ..ie even if open a new window is opened is maximized its size the same problem.....the corners is having the red colour instead of the usual colour....help me out ....pls.
  • 748 Answers
The most probable cause for this is some magnetic field present near these areas, which cause the monitor's mask getting magnetized. I would guess that you have speakers on the monitor's sides, right? You need magnetically shielded (good quality "computer" type) speakers, or else move the existing ones away from the monitor.
The DEGAUSS option from your monitor's controls is used to de-magnetize the mask. You are sure to find it in the monitor menu. Or if you can't find it, simply switch the monitor on and off a couple of times (off, 10 seconds wait, on, 30 seconds wait, and so on) - degaussing is (should be) performed upon every power up cycle.
Posted on Jul 04, 2010
Testimonial: "thank you....i used the degauss option from the monitor menu.... again thank u very much...:)"
Which connectors are used for front panel, power on (red @white) and led ( blue @ white) please show a close-up view
On the motherboard the pinouts on the front panel should be colour coded, and marked with letters like in this picture >>>>>
The connectors are also marked corresponding to where the connect on the motherboard, like in this picture >>>>>>
If the board is not colour coded then the motherboard will marked with the same letters, you may need a strong light to see the marks.
Regards.
Feb 22, 2010 | Gateway GT5428 PC Desktop
My compaq 7540 monitor settings menu automatically opens frequently and on the other side of the monitor means on the upper right corner of the monitor the color slightly greenish
about the settings menu it is the problem of the main system ic in the monitor.And about the colour on the right side corner pls change the ptc in the monitor .
Jul 21, 2009 | Compaq CV 7500 17" CRT Monitor
Red X and Blank IE window
CHECK THE INTERNET CONNECTION AND MAKE SURE THAT YOUR CONNECTED. OPEN INTERNT EXPLORE AND GOTO:
TOOLS
INTERNET OPTIONS
CONNECTIONS
LAN SETTINGS
MAKE SURE THAT THE AUTOMATICALLY DETECT SETTINGS BOX IS CHECKED AND CLICK OK......
HOPE THIS HELPS
May 04, 2009 | Sony VAIO VGC-RB42G PC Desktop
Just let Windows install IE 8 and now the desktop picture is over
Change the resolution. Right click in the middle of the screen over nothing, and select properties then select the settings tab and move the slider left for larger resolution.
Apr 28, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Faded colors
moniter colours changed what prabulem
Nov 22, 2007 | Samsung SyncMaster 793MB 17" CRT Monitor
Saitek Eclipse II Lighted Keyboard
Changing the default colour involves a little dis-mantling. remove the screws from the back of the board. Carefully remove the rubber feet inserts too as there are 4 more screws under there. Now remove the top section of the keyboard (the bit with the keys) Lay the board down flat and you will notice where the usb cable comes in a circuit board. this has a connector with 4 wires attached to it on the left hand side. the wires are coloured red, grey, blue and black. Remove the connector and swap over the Blue and Red wires. Re assemble the keyboard after reattaching the connector to the circuit board being VERY careful not to overtighten the screws. Now at boot up the keyboard will by default be red.
Sep 15, 2007 | Saitek Eclipse II
COLOR ISSUE
this sounds like a pixel problem, you might have to buy a new monitor or see if that one still has a waranty.
Dec 07, 2006 | Gateway VX 1120 22 in.CRT Conventional...
COLOR ISSUE,
either the tube degause cirt is faulty or you have another appliance close to the display,sometimes changing the position of the display will cure this.
Dec 07, 2006 | Gateway VX 1100 (White) 21 in.CRT...
SAMTRON 55V 15" CRT Monitor Logo
220 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
