Question about Nokia N70 Cellular Phone
N70 network problem
My n70 mobile don't have the network its showing 3G but no network signal how i can solve this problem
  • 149 Answers
Its shows 3g when there is no network coverage , its just an indication that the mobile is a 3g enabled mobile. if it continues there might be a possible hardware problem.
Posted on Jul 04, 2010
  • nara58
    nara58 Nov 06, 2012
    how solve the problem?
No network coverage solution for samsung E2230
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Aug 15, 2012 | Samsung Cell Phones
I m new beginner in hardware field guide me how i check signal fault in any mobile guide me sir pl
Hi Buddy,
Signal has a wide range field or area in diagnosing a network problem,it depends the situation on what happen to the phone,weather it was watered damage,drop off the ground or suddenly lost network.
Let's start with the Software Problem
* check your network settings if set to DUAL mode,it means you've 2G or 3G signal,if this mode is far away from your area or out of coverage,you will experience signal dropping, If you are not using 3G signal,better switch to GSM mode and it will stick the signal along your area.
For Hardware Problem
* Base on source and latest issues about signal problem is by replacing 2n2 capacitor,before reheating or removing some main parts like PA (Power Amplifier) and other IC,better focus on this capacitors,Here is a illustration and have a look were it is located
* For no access,change the upper part.
* For no network coverage, change the lower part.
For the meantime,just stick with this solution before doing hardware modification,If you have some questions,don't hesitate to reply,i will give more ideas regarding signal problem.
Thank you for visiting FixYa.
Jul 24, 2011 | Nokia N70 Cellular Phone
SonyEricsson Vivaz how do you set it for 3g signal
rod please call your carrier service center and inform you your carrier support 3g network or not is your carrier support 3g signal then go to main menu and click phone setting and press network setting and select umts mow your mobile show 3g signal i hope it is helpful to you please vote me please
Jun 28, 2011 | Sony Ericsson Cell Phones
Tata docomo with nokia N70 shows 3G signal. but not able to access internet on 3G speed so it work as 2G while it shows 3G signals . Please give me solution.
Dude is your sim is 3g activated or not first check it and then send INTERNET to 121
you will get the setting
and them set it default setting for all services. And then try it again i hope it will work . And please contact to your docomo customer care
May 01, 2011 | Nokia N70 Cellular Phone
Nokia n70 does not show 3g icon
The 3G icon appears only when you are in 3G reception area and you are receiving 3G signal.
Ensure that you are in the 3G reception area and signal is received .some areas there may be weak signal it may also cause to select Gsm mode
May 28, 2010 | Nokia N70 Smartphone
My mobile N70 failed to find network and show 3g in place of network tower
there may not be any problem at all ,
as 3g is notorious for sometimes bad and very patchy network coverage ,so it may be a network problem rather than your phone
i know a few people who have similar issues with all ranges off phones from nokia,sony erricson,samsung blackberries etc.
if problem persists ring 3g from a land line to find out about the network coverage and if they have known issues/problems
May 19, 2009 | Nokia N70 Cellular Phone
N70 no signal problem
try to set your network in network settings'
press menu,
tools folder'
settings'
network settings
in network mode change it to GSM...
tnx for rating this solution.:D
Sep 04, 2008 | Nokia N70 Cellular Phone
N70 lost signal
reset your phone it might work
Nov 30, 2007 | Nokia N70 Cellular Phone
Nokia N70 Music verson
remove the network switch and change it. or in case u dont have the network switch then join the first two points on the right hand side and continue the same wire with left hand first point and forth point
Aug 16, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
601 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
