Question about Refrigerators
I have an amana bottom freezer. ABB1922 feq i saw
I have an amana bottom freezer. ABB1922 feq i saw somewhere ... I think that this fridge does not have a defrost timer. Is this correct. fairly new 2-3 yrs old. the damper is open and the freezer is cold. no air seems to be coming out in the refrigerator. And I have defrosted it and appears to wor fine for a couple weeks.. And then nothing... suggestions?
Master_Tech
  • 770 Answers
SOURCE: fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Posted on Feb 22, 2008
22yooper
  • 828 Answers
SOURCE: Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Posted on Jul 16, 2008
peyton32034
  • 410 Answers
SOURCE: Does new defroster timer require adjustment?
 there are 3 components in the defrost system that can go bad. timer, defrost thermostat, and defrost heater. since youve already replaced timer that means youve eliminated it as a bad component. the most common defrost system failure is actually the defrost thermostat. moisture will infiltrat into the control and ause it to short out. the way to check it is:
  • unload freezer section
  • remove shelving
  • remove icemaker if applicable
  • remove rear access cover
  • once coil is exposed look for a round disc shaped peice that is attached to the top of the coil and has 2 wires going to it
  • hopefuly the control will still be frozen
  • using a multimeter set to ohms sheck for continuity on the 2 wires that go to control
  • if the control has continuity then you have a bad heater if no cont then bad defrost sensor
  • in alot of cases you will actually see that the control has seperated and come apart and you will not even need a meter.
I hope this helps you out. while you have unit pulled apart and after youv'e diagnosed the problem use a hair dryer to defrost ice build up on the coil. this will get the unit working temporarily until you get a replacement part.  thanks Peyton
Posted on Mar 19, 2009
  • 46 Answers
SOURCE: I have a ARB2205CS that is 6.5 yrs old. It stopped
also does it have condencer fan on the comp is this working ?if not comp is over heating it needs that fan
Posted on Jun 26, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Is there a way to disable the frost-free feature on amana freezer
Unplug your refrigerator and open the rear panel in the back of freezer. Disconnect one whire on one end of the defrost heater. Tape the wire up and you'll be good to go no defrost. Sea Breeze
Posted on Aug 19, 2009
Can you tip an amana abb1922few backwards to check underneath
The bottom grill unsnaps easily and allows you to clean under the fridge
Feb 26, 2013 | Amana ABB1922FEW Bottom Freezer...
MY FRIDGE SEEMS TO FREEZE FOODS NO MATTER WHAT SHELF OR DRAWER THE FOOD IS IN
Put the duals back to factory setting. Always the middle number and it is always highlighted. If they already are then turn the fridge only down a setting. The freezer always stays at factory I think 3 or 4 on Amanas.
Jan 28, 2011 | Amana ARB190RCB Bottom Freezer...
I have an Amana BC20TW refrigerator with a bottom freezer. It seems to be running all the time. I raised the temperature dial to make it warmer and it still runs too much. Put velcro on the bottom freezer...
Accuracy is important --Use a digital thermometer to monitor freezer and fridge temps. Fridge should be around 40 and freezer around zero and then take it from there and draw conclusions
Sep 22, 2017 | Amana ARB9058CS Bottom Freezer...
Amana 20 - 20 years old. Freezer thawing - refreezing. Fan running very hot in the compressor arae at the bottom. Drip pan full of water - never saw that before.
IT SOUNDS LIKE YOU HAVE DEFINITE ISSUE WITH YOUR COMPRESSOR, IT MAY BE CONSTANTLY RUNNING OR RUNNING TOO OFTEN, THIS WOULD CAUSE THE LARGE AMOUNT OF HEAT COMING FORM THE BOTTOM. IF YOUR COMPRESSOR IS RUNNING TOO MUCH YOU WILL ALSO GET AN EXCESS AMOUNT OF WATER EVAPORATING DUE TO CONDENSATION ON THE EVAPORATOR COILS THEREFORE FILLING UP YOUR DRAIN PAN THAT MUCH QUICKER. YOUR FRIDGES COMPRESSOR MAY BE ON THE WAY OUT BUT YOUR FRIDGE SOUNDS LIKE IT'S WORKING THE WAY IT SHOULD BE.HOPE THIS HELPS
THANKS
Oct 12, 2009 | Amana Freezers
I have an Amana refrigerator #ABB1922. I purchased this in Jan. 09. Every so often it makes a loud cracking noise. Is this normal? I did have a problem today with things thawing in the freezer, but I think...
check to see if there is ice on the back of the freezer pannel. if there is then you need a new evap heating element.. this some times will casue cracking sounds
Aug 11, 2009 | Amana ABB1927DE Bottom Freezer...
Amana ABB1922 refrigerator - refrigerator not cooling
Check fan for operation and vent duct for ice or the damper sticking between the two compartments. It does not take much when the freezer is on bottom, colder air (because heavier) remains there without proper circulation. I will be trying to find the maintenance /service manual to help resolve this. JT
Feb 04, 2009 | Amana ABB1927DE Bottom Freezer...
Compressor not starting
the thermostat is in the fridge and fridge runs at about +4-6degC. if temp in the garage is about that value, appliance will not want to turn on
Dec 01, 2008 | Amana DRB1901C Bottom Freezer Refrigerator
My amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer lower basket: how to get a replacement part not available in Canada
I can't find a cross reference that shows avalible. The lower basket part number is 67001240. I would try a web search for that number some still has it in stock somewhere.
Apr 18, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
