Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
3 main problems all discribed below
The first problem we came across is that the wireless connection turns its self off pediodically, normally during the night.
the second problem is my wife and i will be both on laptops, both online connect to the router via wireless, but as soon as she turns her laptop off i loose my connection.
Both the above problems we rectify by resetting the router but it is getting a bit of a chore.
the final problem has only just started recently, we have played a many games on facebook then some or them stopped loading, we have checked all Java and Flashplayer setting and they are both up to date. we excepted that we would not able to play them untill we visited a friends house and we used their wireless network and were able to play all the games again. This then pointed to our router, we were advised to check our router settings, but not sure what they should be.
  • 13433 Answers
SOURCE: Wireless security settings on laptop do not match network settings
Hey,
As the settings don't match, I would recommend you reset your router, theres a reset button there, hold it for 30 seconds, your router is returned to default settings and you will instantly get online after the router is working.
After this you will need to setup some security settings incase you don't want people to freely connect and use your network.
Let me know how it goes.
Thanks,
Ekse
Posted on Sep 06, 2008
cnavarro
  • 2460 Answers
SOURCE: Laptop won't connect to the router
Let's start with the easy first. It's a ROUTER issue. If it came with a CD, DO NOT RUN IT!!! You will not like the result when Belkin tries to take over your wireless card, especially in Vista.
The best you can hope for is Plug in the Belkin to your Modem. If it's DSL, you probably have a PPPoE connection and there's a username and password TO THE INTERNET> If it's a Cable modem, you probably use DHCP. Hope for that, because out of the box the Belkin is looking for DHCP. Plug your computer into the router and see if it connects.
Set your computer for Obtain a DHCP and see if your computer gets 192.168.2.x (possibly 2). Now, open Internet Explorer (IE) and type in 192.168.2.1 in the address bar (no http, no www, just the numbers). If it logs you in, you're all set to make the changes to the router, no password is required on initial login. If for some strange reason the router does not give out DHCP addresses, manually set the network card to use 192.168.2.x (anything but 1)
the mask at 255.255.255.0 and the gateway at 192.168.2.1.
Set your wireless up with the wireless access tab and set your security for the wireless login. I use WEP with the 64 bit password of 1011121314.
All the above was for the easy. If you're using something ugly like an AT&T or Verizon DSL and you need PPPoE settings, you need to follow the instructions for your specific router to set it up. It may require the assistance of the Telco, as they can direct you into their modem to turn on bridged mode and the like. Since you can get into it by just plugging in the computer directly to the modem, I'm thinking that DHCP settings will work.
Please post back and mention your country and the exact number of the Belkin router. I don't know what version software you have, but if it's new, I'm guessing Axxxx. Here's a link
http://cache-www.belkin.com/support/dl/p74559-h_f5d7230-4vaxxx_manual.pdf
Starting on pdf page 29 (25 real) are the step-by-step manual configuration instructions. If you follow along, it will tell you how to set up PPPoE and the like.
Good luck and please post back if you run into any problems.
Carl
Posted on Mar 22, 2009
SOURCE: Cannot connect Belkin F5D8233-4 Router to Mac Laptop
Hi, I had the same problem with my MBP and the best solution I found was:
Dissable the Wlan security and use Mac Address control only for the wireless. This will keep your network secure anyway and you can connect normally.
The only inconvenience is that when you want to connect other computers to your wireless you have to enter its MAC address on the list.
Remember to set the list as Allow.
Posted on Apr 28, 2009
  • 86 Answers
SOURCE: F5D7231-4 stopped connecting to Internet via downstream router
Why did you change it from dynamic to static? My suggestion would be to put it back to dynamic and let it grab a good ip address from the gateway. The other option is to contact whoever managed the network at your apartment and see what they will charge you for a static IP address.
Posted on Jun 03, 2009
  • 22 Answers
SOURCE: Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Posted on Jun 12, 2009
Oven burner and broiler burner don't warm at all. Stove top burners work. Clock display normal. When turned on lights indicate oven on and preheating (normal). I have reset the main circuit breaker with no...
Hi Brian, thank you for your post!
Sounds like the either both bake and broiler element may be faulty or a potential wiring failure to the elements. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Sep 15, 2013 | Frigidaire 30 in. Electric Gallery Series...
Tip
The settings saved on this computer for the network do not match the...
Many a times you must have come across a weird error message while using wireless connection on the computer with Vista operating system.
This error message generally appears when the existing wireless settings on your network have been modified or removed. You may either revert the wireless settings on your wireless router or access point or configure the concerned Vista computer to match the new wireless settings. Follow the below steps to configure the settings on the computer:
1. Click START, Click Control Panel then click classic view in left hand side
menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
To know about the security key or passphrase on your NETGEAR ROUTER'S please visit the below tip:
http://www.fixya.com/support/r4095687-check_wireless_security_key_or
For any other make of the router, please contact technical support of the concerned router.
on Feb 10, 2010 | Computers & Internet
How do i turn on my wireless connection on my acer aspire 4530?
Hi, You can activate your wireless connection by either sliding the switch across on the front part of your laptop, where your wrist rests are (across front of laptop) Or try keeping hold of FN and F8 together, or FN and associated F button to activate wireless. Hope this helps, If so please rate, Thanks. If you need anymore info or help, I'll be happy to help
Mar 07, 2011 | Acer Aspire 4530-5889 Notebook PC
My grandparents ust got a motorola surfboard sbg900. I am trying to connect my ipod touch 4g to it but i cant find the wireless password.
hi this is normally printed on the underside of the unit, you have to go into the main user profile to gain access to the network password, the main user name is normally : admin and the normal default password is : password, but this is normally under the unit on its label once in you should be able to find the main network password from there...hope this helps
Jan 01, 2011 | Arris SURFboard SBG900 Wireless Router...
Problems taking in water ?
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 14, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
Having problems getting my wii on line can not figure it out
not sure what your problem is exactly but here goes. on your main screen go to wii options (bottom left)then into wii settings after that across to page 2 and click on internet then connection settings. pick a connection 1,2 or 3 then wireless connection (i presume you've got wireless) then put it your router info and it should connect
Jan 22, 2010 | Nintendo Video Game Consoles & Games
JVC KD-AVX44 no sound in normal mode
is it as 44c or a 44j?
thanks,
Lee
Jul 04, 2008 | Car Audio & Video
Wireless laptop failure
to look for wireless icon on windows XP start by clicking
start-->Settings-->Network Connections
here you shoud able to see wireless network connection
Double click on wirless network connection and below you
would see "show icon in...." and also " notify me...". Check
on this 2 box and click apply.Next time you'll be able to see this icon again.
goodluck,takecare.
May 22, 2008 | Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
142 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
