Door locked light flashes. When machine is then switched off at mains and re-started it starts up for short period then stops and "door locked" light flashes
    President:
  • 1,554 Answers
There must be an issue with the door lock/switch assembly. Either there is a loose connection or the door lock/switch assembly is failing. But troubleshooting can be more accurate and specific if the make and the exact model number of the machine is indicated. The accuracy of the troubleshooting and repair advice depends on the information provided by the client and the basic and the most important information required is the make and the model number of the machine.
Please specify the make and exact model number of the machine before we can proceed with the troubleshooting and give you advice and tell you the necessary actions needed to be undertaken to address the issue. You don't have to accept, reject, or rate this post in order to post additional information or follow-up questions. Accepting the solution/advice does not prevent or stop you from communicating with an expert, You can still post comments as long as you need assistance with regard to the problem stated herein.
Posted on Jul 04, 2010
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Zwh6160p set programme,start/pause light flashes, when pressed machine doesn't start, door does not lock either
Is the door shutting at all or is it just not clicking shut , there is a pressure switch / electronic switch on the door catch mounted on the machine main body which prevents machine running if the door is not shut correctly.
Nov 28, 2013 | Zanussi zwh6160p
Getting this code
Hello there and wdelcome to fixya
Resolution: DL is a failure of the door to lock. The door must lock before any cycle begins. This can be caused by any of the following conditions:
  1. The door lid is not completely closed due to an interference.
  2. Wash media buildup is preventing the lock bolt from extending.
  3. Machine/Motor control is detecting an open door/lid switch when it attempts to lock.
  4. Machine/ Motor control can not determine if the door/lid switch is in a locked state.
  • In some cases the control can be non-functioning and not accept any activation from the keypad, to clear and restart the control follow the below listed steps:
    • Unplug or turn the circuit breaker off for a 30 second period.
    • Reconnect the unit to the power source, breaker back on or plug into the wall outlet.
    • Press the Pause/Cancel/Stop button twice to clear the PF in the display
    • Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Mar 22, 2013 | Washing Machines
Zanussi zwf 1437 starts cycle then stops midway. door light flashes. have to turn off machine at main switch to reset
This is a door lock fault, the lock is working initially but as the machine operates it fails, the only way to fix it is to replace the door lock assembly
Mar 07, 2012 | Zanussi Washing Machines
Whirlpool ghw9100 Door lock solenoid 60 ohm and 126 ohm? Duet job aid says 60 ohms on contact point 3 to 2 and 3 to 1 that is not possible because the two windings double the resistance the way its made. ...
The terminal numbering of the door lock and unlock solenoids solenoid looks messed up and your resistance reading is correct and the solenoids are good as long as you get 60 ohms both on 3-2 and 2-1 and 120 ohms on 3-1.
You stated, as per live chat discussion, that the door never locks to start a cycle. The door locking routine starts only if the door switch contact is closed (refer to page 6-2 of Job Aid L-68). This could mean the door switch contact never closes for the door locking routine to be initiated and a wash cycle can start or the CCU is not detecting it closed.
Check the continuity of the door lock and switch assembly wire harness (door switch, door lock main switches, and solenoids wire harnesses) including the connectors. Replace the wire harness if a discontinuity or any other issue that might jeopardize its function is found. Proceed with the troubleshooting if no issue is found with the harness or if the problem is not resolved with the replacement of the harness.
Reinstall the door lock and switch assembly, reconnect the wires, put the door gasket back over the outer lip of the door opening, and close the door. Reconnect the door lock main switches and the door lock/unlock solenoids harness except the door switch harness. Jump a wire between the door switches terminal connections (adjacent terminals) on the central control unit (CCU) then reconnect power and start the machine.
The door locking routine should start and eventually lock the door and start the cycle if the issue is with the door switch not closing. Replace the door lock and switch assembly if that is the case. The problem is in the CCU not detecting the door switch closing and needs to be replaced if door locking routine still fails to start, lock the door, and start the cycle.
If the door locking routine starts and the door lock seems engaging but fault code "FdL" flashes and the door is locked, unplug the machine then check the continuity of the door lock main switches at the wire harness connector in the CCU (refer to page 5-3 of Job Aid L-68). The problem is also with the door lock and switch assembly if there's no continuity in any of the door lock main switches. Otherwise, the problem is in the CCU not detecting door lock main switches closing and needs to be replaced if there's continuity in the switches.
With the fault "FdU" flashing when the door lock main switches bypassed, the CCU is certainly detecting the switches closed. This eliminates the possibility of the CCU not detecting the door lock main switches closing. It leaves only the possibility that the door switch is not closing or the CCU is not detecting it closing.
Sep 23, 2010 | Whirlpool Washing Machines
Door light flashes 4 times and can hear 4 clunks?
First measure the door lock, make sure it's fine, then ensure that there's current flowing towards the door lock. if it'll trip all the electricity out you'll need to ru very close inspection or to replace the main circuitboard
Update me about your progress
Jul 24, 2009 | Washing Machines
Machine stops, "door open light" flashes door is securely shut.
bad door lock and or harness replace door lock assy and check all connections
Jul 07, 2009 | Washing Machines
'door locked button flashing'
The door lock flashing all time has nothing to do with the weather, or pipes freezing up, it is a fault with the washer.
It is unlikely to be a faulty door lock, but could be a broken door catch spring or door catch problem, make sure you can feel the door latch in securely.
the other probable cause a fault on the main pcb where you programme the washer.
Another prob that can occur is a fault on the mptor caused by the brushes shorting on the motor armature, this in turn can blow a track of the pcb, and giving you the flashing light prob.
I would start by checking the motor first, if you are satisfied that the door is closing o/k.
Plz rate my solution.
Thanks.
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Whirlpool AWM8121 ?door open? light flashing and washing machine won't start. I had solved this same problem over a year ago. It seemed to be the door locking solenoid not working. I solved the problem by...
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Jul 20, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
