My Bowin SLE 2 gas heater keepers cutting out?
2 Suggested Answers
  • 81 Answers
SOURCE: I have a bowin gas heater and no instruction
The remote may need a battery. A watch shop should charge 5 dollars to put one in - if it does not work they should not charge you. You can get new batteries for your car remote / watches etc
Posted on Jul 15, 2011
Why are a/c and heat not changing when I move the temperature up or down just on the driver side?
GMC Acadia no heat coming from heater Questions ... - Fixya
www.fixya.com > ... > Cars & Trucks > GMC
GMC Acadia cars & trucks no heat coming from heater questions and answers. ... on my GMC Acadia 2008 SLE the panel where i control the AC/Heater stopped ...
Sep 09, 2015 | 2007 GMC Acadia SLE
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
High temperature thermal cut-out has tripped
Type, model, brand, age of water heater, and general installation of water heater are unknown.
1) Electric tank-type water heater: replace thermostats and test elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) Gas tank-type: replace gas control valve, clean air intake screen/ location varies by brand:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Tankless: call service technician, or replace tankless with tank-type and save money long-term.
4) Add comment and describe water heater using label located on side of unit, and include what you are doing to 'reset' the thermal cut-out.
Jan 04, 2013 | Water Heaters
Wat can i do to come out from this foolish cut
no solution u are with us not aganst us u must be u broder keeper
Dec 14, 2012 | Viking VGSC366-6B Gas Kitchen Range
What holds pully on shaft for lawn keeper blade
I have an old model Lawn Keeper gas edger with a 2HP Briggs and Stratton engine. It uses a 30" fan belt to drive the cutting blade and both pulleys have an alllen head set screw holding the pulleys to the shafts. The pulleys are cast aluminum and the set screw and shafts are steel so I find need penetrating oil and heat to loosen the set screw in order to push the drive pulley further on the shaft to make room to replace the drive belt.
May 17, 2012 | Mtd 25B-520D200 CA Gas Lawn Edger
The clean filter light is flashing on my Bowin SLE2 however the only filter i can see at the back is dust free? Where else might there be a filter?
It should take just a min to remove it and vacuum it. If it will start with the filter out try and see if the light still blinks
Jul 27, 2011 | Heating & Cooling
I have a bowin gas heater and no instruction manual. The LCD display on the remote is not working. How do I fix this?
Jul 13, 2011 | Heating & Cooling
2003 gmc seirra sle 2500hd 4x4 ext'd cab duramax diesel allison a/t #1 heater fan operates on hi w/switch on hi when engine is started, but will not in most cases when adjusted after engine is running???...
To reset the oil life......turn the key on....do not start....pump the gas pedal 3 times within 5 seconds.....then turn the key off and back on and it should be reset....sometimes u have to do it a couple times.......and what heater fan r u talking about?.....
Dec 30, 2009 | 2003 GMC Sierra
GMC Sonoma SLE 4.3L 1991- Coolant Temp Gauge Not reading
there are 2 coolant sensors one for gauge and one for ecm
Jul 23, 2009 | 1991 GMC Sonoma
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
