Question about Toyota Car Audio & Video
What is this radio power IC - Toyota Car Audio & Video
    Problem Solver:
  • 4 Answers
If it is on the AMP, it needs to be connected to the electric antennea wire on your radio.
If it is on the radio, it needs to be connected either to the ignition or straight to the battery + terminal. Your radio should have two wires that need power, one goes directly to the battery, and the other gets wired through the ignition. It does not really make any difference which goes where.
Posted on Jul 04, 2010
OVER V error ON ICOM IC-A24 when power UP ?
Sorry to say, but normal. As long as radio works fine otherwise don't worry about the error display.
Nov 30, 2013 | Icom IC-A24 NAV/COM Transceiver
Ic 36 wont transmit
Check PTT switch is working? if working then check power output of your radio. if no power then change PA.
Oct 22, 2013 | Icom IC-M36 VHF Marine Radio
Ic a110 power problem
Hi Joshua,
Not enough info provided, from you.
IC a 110 power problem means very little.
IC indicates to me that you havs an Icom radio, is that correct?
a110 is confusing me though. What exactly are you trying to say here?
To assist you in finding the answer, I need much more info:
1. The make of the radio i.e,. Icom, Motorola etc,.
2. The Model Number ie, IC-XXX, etc,.
Then I require as much info as possible regarding the problem
By just posting what you have doesn\'t help me help you.
Please reply with the above requirements, and I\'ll find a solution for you.
Cheers,
Peter
Dec 14, 2012 | Radio Communications
IC-736 total failure whilst on air, fuse OK, nothing smelt burning etc, not over heated, no voltage surge, SWR was moderate but protected by APC circuit. Totally dead now.
Hi Jack, (No Pun Intended)
As this is such a fine radio, I would take it to the radio doctor for a once over check-up, The technician will find the problem and give you an estimate of cost to repair the fault, Take care of you radio, it's a great unit that should give you many more years of service.
I hope this advice is of help to you.
Cheers,
Peter
Dec 02, 2012 | ICOM Informatique BP-84SM,...
Trying to unluck an ICOM IC-4008M radio
The manual can be downloaded.
http://www.icomamerica.com/en/support/kb/article.aspx?ArticleNumber=63AF543918
To toggle the "Key Lock", push and hold the POWER button for 2 seconds.
Oct 24, 2012 | ICOM Informatique IC-4008 (14 Channels)...
The power is on, however, there is no sound.
Is your ic chip good? This is located on the side of the radio, it has sveral legs. Put your fingure over the legs,do you hear any noise,Do this with the radio on, If you don't hear anything your IC chip is bad.
Aug 14, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
IC A23 Portable VHF radio Locked
ic a 23 quero scannear como fazer /???
please scam mode /???
Mar 04, 2009 | ICOM Informatique IC-A23 VHF NAV/COM Air...
Power inverter on ic-r8500
wow thats a great radio, pack it up and send it to me.(just kidding)you might want to contact icom www.icomamerica.com and talk to their techs about this one. congratulations on having one fine radio, it is worth a quality repair,ive wanted to take one of those apart for years lol
Jul 16, 2008 | Icom IC-R8500 Base Scanner
IC w32a has been apart about 3 times to re solder the power plug ,this time I put it back together and the the 2m band wont transmit but for a second then off.Nearby radio will pick up the brief...
Thanks for letting me post a question.
After taking it apart again I found a pin on the lower board socket that got bent over on reassembly........
May 13, 2008 | ICOM Informatique BP-180M,...
ICOM W2a Won't power up, after full charge with two different batteries
There's a comment on eham.net about charging the internal battery first.
Maybe this will help you.
http://www.eham.net/forums/ModsAndRepairs/1961
Jan 10, 2008 | ICOM Informatique BP-85S,...
Car Audio & Video Logo
32 people viewed this question
Top Toyota Car Audio & Video Experts
Martin Clarke
Martin Clarke
wadingriver
wadingriver
Are you a Toyota Car Audio and Video Expert? Answer questions, earn points and help others
