Question about Whirlpool Washing Machines
I NEED TO KNOW HOW TO CLEAN THE PUMP IN A WHIRLPOOL WFS1071AW FRONT LOAD WASHING MACHINE
    President:
  • 1,554 Answers
Unplug the machine then remove the screws attaching the lower front access panel to the cabinet then pull the panel down and off. Prop up the lower front edge of the washer or cushion the rear top edge with cloth and lean the washer against the wall for an easy access of the screws.
Place a shallow pan or lay a towel under the filter to catch the water from the pump. Unscrew the filter from the pump assembly and drain the water. Clean the filter and screw it back into the pump assembly. Slide the lower front access panel up back into the cabinet and secure it with the attaching screws.
Posted on Jul 04, 2010
Wanting a user manual for whirlpool 6th sense wfs1071aw front loader washing machine please
go google and type in--operators manual fro whirlpool washing machine model wfs1071aw --- and down load the pdf version
Jun 12, 2017 | Whirlpool Washing Machines
How do I clean the pump on a Whirlpool 6th sense frontloader
The pump filter is situated behing the white plastic kick strip on the front at the bottom of the machine.
Instructions for use Whirlpool UK
Sep 19, 2014 | Washing Machines
I have a WFS1071AW-7.5kg. It is stopping mid cycle and showing a red "Clean Pump" light on the front panel. Where is the pump and how do I clean it? Your help would be appreciated.
The pump is hidden below the removable kick plate at the bottom of the machine. Hold the plinth on either side and pul it downwards and outwards to remove it. The filter is unscrewed by turning anticlockwise.
This is covered in page 11 of your manual, a pathetically poor scanned PDF copy of which is supplied by whirlpool Australia if you go to this web address:
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001/DOCTYPE/IFU/DOCLANGUAGE/AU
Enter WFS1071AW As the commercial code and select language ENGLISH
Note: This model has no drain hose to get rid of residual water, suggest you tip the machine back 45 degrees and have a towel ready to catch any leaked water.
Aug 23, 2011 | Whirlpool Washing Machines
Can you show me a whirlpool WFS1071AW manual
The manual is available from the Whirlpool Australia site: http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001 . Enter the model number (WFS1071AW) in the box marked commercial code. Then select your language and click Search. The table of contents is starts on page 3 of the pdf.
I hope this helps.
Jul 09, 2011 | Whirlpool AWM6100 Front Load Washer
When my washing machine is on the wash cycle and it is using the detergent... water and soap suds pour out of the detergent dispenser and run down the front of the washing machine, why? I use proper front...
There is an article of clothing stuck inside the dispenser housing. Remove the top and the housing to get to the hose and clean it out. Very common issue, I know this unit very well.
Apr 22, 2011 | Washing Machines
My Whirlpool front loader washer has "clean pump" light displayed. How do i clean the pump.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Whirlpool AWOE8748 Front Load Washer
Clean pump red light on Whirlpool WFS1071AW, How do I?
TAKE OUT THE SCREWS ON THE BOTTOM PANEL AND ON THE INSIDE OF THE MACHINE NEXT TO THE PUMP YOU WILL FIND A PIECE OF PLASTIC WITH A SMALL HANDLE, ROUND IN SHAPE, PULL THIS OUT AND CLEAN THE FILTER
Aug 11, 2009 | Whirlpool Washing Machines
I have a front loader WFS1071AW 7.5kg and it leaks loads of water and suds from under the detergent tray when filling. What is wrong with it???
The hose down from the back of the dispenser to the drum is blocked.
Take out the soap drawer and use a babys feeding bottle brush to clean out the pipe
Either that or take off the top of the machine (Normally two screws on the back of the top panel)
Then remove the pipe and clean it you may need a pair of Corbin Clip pliers to do so , at a push use Mole Grips
Jul 08, 2009 | Whirlpool WFW8400TB Front Load Washer
Red light on - clean pump
remove bottom panel 3 screws7mm once removed access to pump im front clean and reinstall thats it
Jan 03, 2009 | Washing Machines
Vibrations in Whirlpool WFS1071AW
Hi the problem with your machine is the fact the transit straps have not been removed!! Remove them and you will not hear another thing from it. Look at the manual to find out how to take them off!
Dec 28, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
