Question about Whirlpool GHW9150 Duet Washer
F11 Fehler bei Whirlpool Waschmaschine
Nach mehreren "normalen" Waschdurchgängen an einen Tag passierte plötzlich Folgendes: Die Maschine wurde gefüllt und "gestartet". allerdings "schoss" das wasser incl. waschmittel sofort wieder aus dem abwasserschlauch und die fehlermeldung F 11 erschien. alle LED´s blinken. ich habe die maschine ausgeschaltet, den stecker gezogen, sie neu gefüllt, angeschaltet.... programm gewählt - sie pumpt immer wieder nur ab und zeigt die fehlermeldung F11. das flusensieb ist sauber....
wer hat einen rat?
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Posted on Sep 28, 2010
What does error 6000 mean on Canon MP630? It keeps telling me it's printing then the paper runs through without anything being printed on it. Thanks for any help.
Error 6000; Fehler 6000.
"Error 6000 is a mechanical problem of paper-input." (Hotline)
Remove paper-tray and check the rail inside as deep as you can see. (look for stuff!) Then try again. All other atempts are hopeless and send it to service.
Ich habe die abstrusesten Antworten im Net gelesen:
z.B. "Fehler 6000 bedeutet, dass die maximale Anzahl der Drucke erreicht ist und das Gerät wegzuschmeißen ist!"
Ich habe beim Service angerufen. Die meinten, es liegt ein mechanischer Fehler im internen Papiereinzug vor.
Das Gerät muss eingeschickt werden. Reparatur von eigener Hand aus nicht möglich.
Papiereinzug? Ich habe dann die Schublade einmal ganz rausgezogen und nach Störteilen auf der Schubladenbahn gesucht.(und gefunden!) Tatsächlich ging die Schublade danach sehr leicht wieder rein und der Drucker lief wieder. Alle anderen Recherchen sind m.E. vertane Zeitverschwendung!
Nov 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Hallo, meine Camera wie oben funktioniert nur noch wenn keine Speicher- karte im Gerät ist. Mit Speicherkarte ist kein Strom vorhanden. Wo ist hier das Problem. Habe kein Geld für teure...
Ich bitte um Entschuldigung, aber ich bin mit Google übersetzer. Bitte schauen Sie in Ihrer Kamera CF-Karten-Slot. Ich vermute, dass Sie eine gebogene Nadel in es haben kann. Wenn ja, entfernen Sie die Batterien und Karte. Verwenden Sie einen kleinen / dünnen Juwelier flachen Schraubenzieher, bis die Nadel verbiegen wieder so nah wie möglich. Eine preiswerte Juwelier Schraubenzieher funktioniert problemlos. Ein weiteres Tool, benutze ich manchmal ist ein steifer Draht mit einem gebogenen Haken am Ende. Dies trägt dazu bei sehr flachen Pins erhalten begonnen. Nehmen Sie sich Zeit und verbrauchen viel Geduld (machen Sie eine Pause dazwischen, wenn nötig). Macht einfach weiter es nach oben und gerader einer "kleinen Menge zu einer Zeit". Was immer Sie tun, versuchen Sie nicht, um es mit einem Tastendruck entspannen, werden Sie nicht in der Lage, es zu tun.
Es muss nicht perfekt sein, nur so nah wie man es bekommen kann. Wenn es das Beste, was Sie es bekommen können, nehmen Sie Ihre Flash-Karte und "langsam" einfügen. Die Karte selbst ist fein-align des Stiftes. Entfernen Sie die Karte, und stellen Sie sicher, dass die PIN noch gerade ist. Wenn ja, setzen Sie die Karte und versuchen, die Kamera.
Nov 17, 2009 | Canon PowerShot A85 Digital Camera
Drucker Druckt nicht
Sorry, wenn ich dies schreibe in einen falschen Weg, weil ich ein übersetzungs-Tools Software zu nutzen. Drucker-LED blinkt grün mit orange abwechselnd in der Regel müssen zurückgesetzt werden.
Hier sind die Schritte:
1. Sie schalten Sie den Drucker
2. Sie drücken und halten Sie RESUME
3. Sie drücken POWER
4. nicht frei (nicht abzulassen) Power lassen Sie sich (Loslassen) und wieder zwei mal drücken Sie RESUME, und lassen Sie sich (Loslassen) POWER
5. Nach der Anzeige blinkt Sie in einem Service-Modus zu gelangen
6. Drücken Sie RESUME 4 Mal (Dump einer Pampers) oder 3-mal (dump EEPROM), die von jedem Drücken RESUME der Indikator ändert seine Farbe: grün - orange
7. Sie drücken Power. (führt den Dienst - RESUME-Funktion eingegeben)
8. Wieder POWER - ein Ausgang (Erscheinen) aus einem Service-Modus.
Hoffen, dass dies Ihr Problem lösen
Oct 04, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Washing Machines Logo
436 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
