Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Cant open Sure Safe electronic pad safe.
We own a Sure Safe electronic pad safe. when we enter the code, the lights blink but the dial will only turn 1/2 way
5 Suggested Answers
  • 124 Answers
SOURCE: i forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Posted on Sep 14, 2009
ekoo
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
  • 13 Answers
SOURCE: SURE SAFE ELECTRONIC CONTROL PAD AND BATTERIES
try default number 159A
Posted on Oct 04, 2009
pctech1
  • 1940 Answers
SOURCE: kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
Posted on Feb 21, 2011
Change code number to a new number on safe e.d.safe s25ebf
electronic keypad -159B. (These numbers are preset. You should change the code as soon
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Aug 04, 2011 | Office Equipment & Supplies
How do i change my code on my safe? it is a S-25E i have keys but want 2 change the code
Try this,
won't work.
ELECTRONIC SAFES
Good luck
Thanks
Apr 29, 2011 | Office Equipment & Supplies
I purchased a new Sentry Safe, Model CSW 4747 yesterday. When I unboxed the safe, the safe was open, the lock handle was down, cyclinders were a little pertruding, and the lock cyclinder was popped out. ...
(1) sounds like the interior lock activation screw is still installed. it's the long screw on the inside of the door with the yellow tag; (2) when entering the code, make sure the key is turned to the right; (3) after entering the code, make sure you next press the program button. enter the code wrong three times and it locks up for two minutes.
Sep 11, 2010 | Office Equipment & Supplies
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
I forgot the safewell electronic code and didnt have the key
won’t work.
ELECTRONIC SAFES
Good luck
Sep 14, 2009 | Locks & Locksmithing
Harldline safe not opening
Sure blame the poor kid.
Think about it, what good would a safe be if by pressing a few keys the combination was changed?
As with any combination safe you need to clear the combination by turning one, two or three times in the opposite direction before entering the combination.
Now say your sorry to your kid.
Jul 24, 2009 | Safe International Digital Electronic Safe...
Factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Nov 23, 2008 | Sentry Fireproof Safe
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Mar 29, 2008 | Sentry Fireproof Safe
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
200 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
