Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
My husqvana lawn tractor starts well and the engine runs but when I release the brake or apply the cutter it cuts out. Why?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Most likely the seat safety switch or associated wiring is the problem. It's designed to cut the engine if you release the brake or engage the blades unless it detects your weight in the seat. Tip up the seat and make sure the safety switch under it has not come loose, and that the wire connections are on tight. If that all looks OK, take the switch off and put a piece of tape over it the plunger to keep it in the 'activated' position and see if the mower works that way. If that fixed it, you should replace the safety switch. They are just a few dollars. Hope this helps - if so, please rate my answer.
Posted on Jul 04, 2010
Goes dead when disengaging brak
Lawn Tractor stalls after engaging blades or releasing brake ...
www.shopyourway.com > Manage My Life > Questions
Scenario 2: Engine started, as above in scenario 1 and manaul brake lever is engaged. Again ... Lawn Tractor stalls after engaging blades or releasing brake .... I am goingto replace that anyway but it almost seems my problem is electrica
Sep 14, 2015 | Garden
I have a MTD yardman yardbug riding lawn mower. Its a 8.5 hp engine. Model: 13b-325-401 year:2000. It will not start, I turn the key and it sounds like its trying to start, but the belts underneath the...
check that you can turn the cutters by hand . I suspect that the bearings for the cutters may have seized up from the wet grass causing them to rust up
Jun 02, 2013 | Garden
Husqvana keeps blowing fuse & when i disconnect a wire from the fuel managment system it doesnt blow
look at the solenoid on the carb the wire starts to break and short out on the solenoid housing
Oct 14, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a Craftsman 19.5hp 42in deck lawn tractor problem. The tractor starts ok but when I release the brake it shut down.
Your tractor has several safety switches. Look around your brake pedal and linkages. You will see a little plastic switch has 2 wires going to it unplug and put the 2 wires together if it runs switch is bad. You can replace the switch or just cut the wires and wire nut them together.
Sep 28, 2010 | Craftsman Garden
My Craftsman 42" 18.5hp lawn tractor will start fine but when I disengage the brake or engage the blades it cuts off. It was recently left out in the rain while I was working, did something short out? It...
there is a safety switch under the seat. to stay running after the brake is released or deck engaged you have to be sitting on the seat or it will die. if this switch is bad it will die as soon as you release the brake.
Aug 25, 2010 | Craftsman Garden
My craftsman 17hp lawn tractor shutters bad when releasing the clutch pedal. is it the clutch and where is it located?
Its not really a clutch, clutch/brake pedal when pressed will release belt pressure which stops pulley from turn axle. When predded all the way down it mechanically applies brakes. The vibration is from a bad pully that the drive belt rides on or a bad belt. Look for chucks of belt missing.With engine off put on parking brake and manually wiggle each pulley that drive belt rides on to see if there is any play. No play should be present. Good luck.
Mar 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have the same ,Sears Kohler tractor won't pull uphill
Have you checked the fluid level in the hydro trans, there is a drive belt from the engine to the hydro trans check and make sure that this is not worn or loose. Make sure that when you check the tension of this belt that you do not have the engine running or the parking brake set, since tension will be released from the belt when parking brake is applied. good Luck
Oct 07, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine stalls when blade is engaged
the best way to check is to run the engine with you on it then lift off the seat and see if the seat sensor is cutting off then put a bag with some weight in it and turn on the engine it should run ok if the sensor is working and lift the back box to see if the sensor works there.. the other cause could be a build up of grass in teh cutter area stopping the blades fron moving this can caus a stall if you get a hose and blast under the cutter guards and make shure the grass shute is clear for the grass to exit this may help to mine cuts out if there is a blockage here and the grass cant get out after it has been cut it builds up at the exit plates.. Hope this works AB
Sep 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ride on Mountfield Lawn mower 1228H - engine cuts out
Check to make sure there is no obstruction in the blades or on top of the deck where the belt goes. Also check that your pulleys turn freely and that a bearing didn't freeze up.
Let me know if this helps.
roundo4
Aug 08, 2009 | Garden
Engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
Jun 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
73 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
