Question about Linksys WRT54G2 Wireless Router
Hi I had my router set up on my xbox and it was reset. How do I reconnect it to my internet? All 4 ethernet cable lights are on and I dont know what to do.
  • 1,675 Answers
Hi click on link and then choose your hardware version, then download the user manual this will tell you all you need to know, tried it myself but my upgrade adobe is playin up lol, hope this helps
http://www.linksysbycisco.com/UK/en/support/WRT54G2/download
Posted on Jul 04, 2010
2 Suggested Answers
  • 10406 Answers
SOURCE: Hi I had my router set up on my xbox and it was
If you disconnect one of the 4 "LAN" Ethernet cables, the corresponding lamp should go out.
If not, then power-off the router, wait a few seconds, disconnect all the LAN-side Ethernet cables, and power-on the router. When the lamps on the router settle down, the router will have finished rebooting,
and the LAN lamps all should be "dark".
If not "dark", connect one Ethernet cable, and see if the lamp goes on. If not, then the router should be responsibly recycled, and a replacement should be purchased.
Posted on Jun 15, 2010
I HAVE WIFI WERE IS THE ROUTER
The router is provided by your internet provider some companys only have modems which means you would have to plug your Xbox into the modem whith a Ethernet cable call your provider to make sure the router has WiFi if so just go to settings on Xbox and conne
Mar 31, 2014 | Microsoft Xbox 360 Console
My black wireless adapter is contiuesly disconnectiong from xbox live and is always lagging in games with other people
Hello
Probably not the adapter.
Try rebooting your router/modem
1 unplug all cables and shut router down.
2 Find reset button,usually small button behind router.
3 Hold in reset button with a pen tip or paper clip for one minute.
4 Reconnect router and power up,wait for all lights to come back on.
5 Try x box or internet again.Double check your wep or wire less code in x box internet settings.
Jan 04, 2011 | Microsoft Wireless Network Adapter Xbox...
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
I try to plug in my belkin 54 wireless usb thing into my xbox 360 and my xbox doesnt even recognize that it is in there and i dont know where to start but i would like to be able to play games online and...
XBOX 360 is alredy wifi enabled you dont have to plug a thing in to it, if you want to configure wireless
All you got to do is turn on your wireless router/access point and try to search for available network in Xbox 360 and upon selectin the network it would ask for wireless key (WEP key cab found on the back or bottom of router) punch in the key and bingo...its done
Your box is ready to be wirelessly connected to internet and play online
alternatively if you dont ahve a wirelss router or you are facing difficulty is seraching wireless router or finding the security key
Connect the router to modem > then connect the router and XBOX with an ethernet cable
It will work
Else you can also try connecting the modem and XBOX with an ethernet or USB cable
(However in all the aboove scenario, please ensure the modem is getting the internet link through the normal RJ11 or phone cable, please dont unplug that else though your XBOX would be connected to Modem or router but it wont get internet connection)
Aug 01, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Hi I had my router set up on my xbox and it was reset. How do I reconnect it to my internet? All 4 ethernet cable lights are on so I dont know if that means it was reset or the ethernet cable doesnt work....
Jun 15, 2010 | Linksys WRT54G2 Wireless Router
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
How do i hook my xbox up to my computer to get on xbox live?
hi,
just to elaborate on zombies post.....
Zombie is correct in what she says...but in 'Laymans' terms.........
you dont need to hook up your xbox to ur computer to get 'On Live' .
The easiest way is a direct 'Ethernet' lead (plugged into the back of ur 360....(dont worry....u cant put it in the wrong slot....an ethernet lead will only fit an ethernet slot)) & the other end into an empty Ethernet slot on your broadband suppliers router (the little box they sent you which is plugged into ur fone line)....there are usually '4' ethernet slots on most routers ! once the ethernet lead is plugged in just follow on screen instructions (xbox) for 'signing' up to 'Xbox Live' :-)
hope this is a little easier to understand ??
p.s. Dont get ripped off buying an ethernet lead if u havnt got one long enuf ! dont let the shops tell you ur better off with 'Gold' plated ones !! its rubbish !! u dont need gold plated !
the usual 'bay' shop (u know who i mean??) have numerous suppliers....u dont want to be paying more than £5 for at least a 5 metre one !
p.p.s dont bother with the wireless adapters !! there pants !
good luck :-)
Feb 13, 2010 | Microsoft Xbox 360 Console
How do i connect xbox 360 to internet i will be connecting by ethernet,what do i need to do many thanks dave.
HI Dave ...
If you dont have the manual, you can get one online from the Xbox site.
All you need is an ethernet cable and a router port ( where your PC gets its innernet connect.
Nov 04, 2009 | Microsoft Xbox 360 Console
I dont know how to set up my routers
Put the setup disk in your computer and it will step you through the process.
Typically, you will have to hook your computer directly to an internet connection (with ethernet cable), then unhook it and connect the internet cable to the router (usually in port 1), then connect an ethernet cable from the router to your computer and plug in the router.
The disk should download the appropriate software and walk you through setting up a password and stuff.
After all that, you can unhook your computer and use it wirelessly.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Linksys WRT54G2 Wireless Router Logo
69 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
