Question about Siemens Ovens
Siemens HB28024 / HBT294 oven display very dim
The LED display has become very dim, so that it is almost impossible to read the time etc (day or night). Help please!
Rotu
  • 175 Answers
SOURCE: LED Display is very dim
Unfortunately this is a bad display, and the kit to fix it (comes with new display board and power/relay board) is about $270 for the parts, and if you cant put it in yourself expect to pay an additional $120-$220 depending on rates in your area. Wish I had better news, but I see these (and Dacors) do this frequently. Hope this helps.
Posted on Nov 11, 2006
SOURCE: Dimming temperature and clock light on display window
I had the same problem, I think it took place when my cleaning person washed it as the motherboard and lcd have very little protection form the top of the oven.. where it would be wiped down
Posted on Nov 12, 2007
docjohn174
  • 943 Answers
SOURCE: kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Posted on Oct 05, 2008
  • 114 Answers
SOURCE: Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Posted on Mar 21, 2009
SOURCE: dim LED display on oven
You need to replace the capacitors on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Posted on Apr 10, 2009
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Jan 16, 2013 | DCS WOS-227 Electric Double Oven
Thermador single convection oven, SC301TP has inop LED panel. Dim, then blank. Solutions? I have Googled this complaint, and find many irate owners stating this is a common problem. Is there an LED panel...
Welcome to FixYa.
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available.
You can find these "display kits" at "repairclinic.com" for around $275USD and includes what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Dec 29, 2010 | Thermador SC302T Electric Double Oven
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Kenmore model c970-655632 LED Display is very dim
Oct 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Thermador oven display is dimming
replace the capacitors on the display unit. Just did this and it now works
theblog
Nov 29, 2007 | Ovens
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Oct 29, 2006 | Jenn-Air W30400P Stainless Steel Electric...
Ovens Logo
305 people viewed this question
Top Siemens Ovens Experts
Sal De
keith jones
keith jones
Are you a Siemens Oven Expert? Answer questions, earn points and help others
