Back to:
Tags:
Panasonic PanaFax UF-8000 Laser Fax
UF-8000 J43 Jam (Not There) (by 2 users)
posted by CJSC on Apr 17, 2008
I have a UF-8000 that is giving me a J43 error code. There is no paper jam that I can find.
It's brand new out of the box.
Any ideas?
Thanks in advance,
Jim
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 16, 2008
j 43 jam code no paper anywhere
Best Solution
posted on Apr 24, 2008
Thanks for Trying (70)
Jxxx
Rank:Wiz Wiz
Rating: 89%, 33 votes
turn it around and have a look in the back panel that opens, open all other covers and check that any of the small black sensor levers are not stuck down they shoul all spring back
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on UF-8000 J43 Jam (Not There):
I don't want to Accept this solution
Solution #2
posted on Sep 10, 2008
Not Rated (0)
tech435
Rank:Wiz Wiz
Rating: 84%, 19 votes
J43 has a few solutions, one there are a few finger sensors under the toner cartridge , make sure there not broken. two is there a grinding noise because if there is , could be a fuser problem. three there are some small white cables at the back of the machine some people think there paper and try to pull at them. if there cut or damaged then theres a big problem.
good luck
Comment by tech435, posted on Oct 02, 2008
if your blue knob keeps moving back every time you close the tray means you broke the knob.
how it could have been broken.
1-tray was not removed to insert paper
2-tray is constantly slamed shut
Thank You!
Solution #3
posted on Sep 09, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Open the paper tray & most likely the tab that holds the paper tight has gotten scooted back. Make sure the paper is up tight next to the front of the paper tray & push the tab to hold tight.
Ours does this ALL the time - poorly made. It scoots back a little each time you shut the paper tray.
Thank You!
Can you Help with these Fax Machines problems?
Fax Machines
recently received a Brother intellifax1800c and i needto...
Fax Machines
Canon fax/scan/copy Model F 146502 - super G3. There was a...
Fax Machines
Casio fx-260 solar calculator: (1) How to put in COMP...
Fax Machines
I have an L4 error code on a Sharp SF 2027 can you tell me...
Fax Machines
I have a canon c6870 copier/fax. I have loaded the...
Loading problems.
Repair Service
Find Fax Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
