Question about Gateway GT5220 PC Desktop
Vertical lines appeared om my computer desktop after completed loading operating system.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 49 Answers
Please check with another monitor. If another having the same problem then it is the issue with computer.
Posted on Jul 18, 2010
  • 487 Answers
Hi, you need to check you have the latest driver for your graphics, this does not always install with your operatiing system
Posted on Jul 04, 2010
Horizontal vertical lines on Laptop screen
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Aug 04, 2012 | Lenovo IdeaPad Z560 Laptop Computer -...
Emachines t5274 vertical blue lines during startup/XP.
It looks like you've got two issues. If you tried a different monitor and it too have vertical blue lines your video card might be bad, but hold that thought. I'm thinking you need to reload the operating system because you can't boot all the way up which is the second issue.
Have you tried to boot up in Safe Mode and do a System Restore? Turn the computer off, then turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option. When it boots, if it boots successfully things will look different in Safe Mode. The screen will be darker and icons bigger, but that's normal. If you get into the desktop successfully, click Start/Programs/Accessories/System Tools/System Restore. Select a restore point (date and time) that is before you started having problems. If the system tells you that you have no restore points, then you will have to either Reload the Operating System or do a System Recovery. By the way, System Restore does not lose your data, documents, music, pictures, videos, or programs unless the program was installed after the restore date. System Recovery LOSES EVERYTHING, it sets your system back to when you first purchased it.
Mar 26, 2012 | eMachines T5274 Desktop PC
After loading the computer, the vertical lines appeared on the the desktop
getting vertical lines are usually hardware issues , jst do one thing check in bios by tapping f10 continiously while u restart the computer and check if u get the same vertical lines on the bios screen or not if u get then the monitor has gone bad u need to replace the monitor.
Jun 11, 2010 | Gateway GT5220 PC Desktop
A white line has appeared on my desktop only
Two inch vertical line appeared.It sometimes is on the left and sometimes moves to the middle. It is only on the desktop.
Feb 20, 2009 | Microsoft Windows XP Professional for PC
Desktop computer monitor (flat screen) has a thin red vertical li
Detach the monitor from the cpu and turn it on. If the same vertical line appears then take it to the repair centre.
Dec 17, 2008 | IBM NetVista PC Desktop
Vertical lines in video
It sounds like you installed a video codec or driver which isn't compatible with your other codecs or drivers.  If you replace them both, you'll be covered, won't you?
Jul 26, 2008 | E-Machines eMachines Desktop PC
Vertical white line in center of monitor
Your monitor may have been cracked somehow...
Try restarting and look to see if the line is there immediately from the start or does it only show up when your operating system (windows/linux) loads?
Regards,
Chester
Jan 11, 2008 | Dell Inspiron 2200 Notebook
Monitor
capacitor (either ceramic or electrolitic) that connect to vertical ic (TDA8173 or TDA 9302) is short or open. Check all capacitor in vertical range. tq
Nov 22, 2007 | IBM E74 17" CRT Monitor
NX 6800 GT Driver issues
Either your graphics agp slot needs the driver updating or the card itself is faulty, check the agp slot for dust and gently moneuvre the card in the slot to see if the lines appear to change and check that therea are no bent pins in your connecting plug or card.
Nov 17, 2006 | MSI NX6800GT-T2D256E GeForce 6800GT, (256...
Gateway GT5220 PC Desktop Logo
44 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
