Question about Microwave Ovens
Everytime I use the microwave, there are droplets of water in the microwave oven and it becomes wet inside. What seems to be the problem?
  • Anonymous Mar 27, 2014
    water inside the oven
  • Microwave Ovens Master
  • 9,098 Answers
Do you feel air flow at the vents when it's running? That's important.
Lack of air flow can cause the magnetron to overheat and be damaged.
It can also cause excess moisture to accumulate in the oven.
If your air flow is good, this is probably normal. It's always advisable to leave your microwave door open or even wipe down the interior after using it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
Kitchen aid microwave Kcms185j is arcing on the inside ceiling when popping popcorn, but normal when frying bacon?
It may be the oil in the popcorn---do you own one of the covers that go inside to cover so food does not splatter?
Dec 22, 2012 | KitchenAid KCMS185J Microwave Oven
Microwave is arcing
The inside of the microwave has a hood and when metal becomes exposed causing it to arc, white enamel paint that has worn off will show the same result. If not fixed the magnetron will be destroyed.
Mar 09, 2012 | Kenmore 62622 Microwave Oven
Is this a self cleaning oven? If so how do you set it to self clean?
Self-cleaning microwave oven?
Loosen up gunk and grease splattered inside your microwave by following this simple tip. Fill a pyrex measuring cup or other microwave safe bowl with one cup water and put in microwave on high for three minutes. This should bring the water to a boil. Let it set in microwave for several minutes with the door closed.
Then, wet a sponge or soft rag with a tablespoon of vinegar. If you need a degreaser, add a few drops of dishwashing liquid to it. Wipe microwave clean with the rag or sponge. The microwave will practically clean itself. Now that was easy!
Jun 03, 2011 | Microwave Ovens
My Kenmore 665.61639100 microwave will not even heat a glass of water. Everything else seems normal. I'm thinking magnatron. Is there anything else it could be?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 27, 2011 | Kenmore Microwave Ovens
Can you run a microwave with nothing in it? Someone told me that just putting a sponge in it will ruin the microwave.
hi, running it with nothing in it will cause it no harm, the only object that will cause it any harm is if you place anything metalic inside it whilst it is switched on.
to clean a microwave most people place a bowl of clean water inside and put the microwave on high for 5 to 10 min doing this breaks up any grime stuck inside the microwave making it easier to wipe off, you can also put a wet cloth in a bowl and switch it on doing this does the same as a bowl of water.
so the only thing that can cause damage is anything with metal in it this will cause it to short out.
hope that has been some help to you
Aug 18, 2010 | Sharp R-1480 Microwave Oven
Arcing inside microwave
unless you are familiar with these, leave it alone. Over time small particles of food become carbonized inside the oven, hence the electrical display. the solution is to clean it after every use.
Oct 02, 2009 | Magic Chef MCD1110ST Microwave Oven
F3 error
So far so good we unplugged the machine took the filters off the bottom let everything dry out over night and it seems to be working I'll update you tomorrow. I think the steam got the control pannel wet.
Jun 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
419 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
