Question about Apple iTunes
Final stage of downloading states "cannot find connection %/%appa....can't remember the exact msg
  • 51 Answers
Hi
  I think there is some problem with ur network connection. Check whether u can able to ping the destination and check the modem is properly connected
Posted on Jul 04, 2010
HOW CAN I CONNECT A MIXER TO A TECHNICS SA-DX940 AV
I used the manual downloaded from http://www.manuals365.com/technics/sadx940.html
Try using the final stereo output of the mixer as the input to the CD or Tape or VCR inputs.and use the switches on the fromt of the DX940 as necessary.
The specificatios state input sensitivity is 27 mY so your mixer needs a low output..
No reason it shouldn't work.
Sep 18, 2014 | Technics SA-DX940
Tip
1998 BMW 328i AC Blower dead or on and off intermittently
Check the wire harness connector on the final stage unit for loose connection before replacing the final stage unit/blower resistor. I just fixed mine and found a loose connection. Good luck!
on Apr 10, 2011 | BMW 328 Cars & Trucks
Heater relay 97 bmw
Go to the front power distribution box and check 30A fuse 20 (GRN/BRN wire) which feed power to the blower relay. When the ignition switch is in START or RUN position, the relay closes and power is fed to the final stage unit. Depending upon the state of the automatic climate control module, power output from the final stage module is applied to the blower motor. If checking all this does not solve the problem, you may have a clogged heater core
Oct 16, 2012 | 1997 BMW 3 Series
Red button doesn't show on Philips TV after digital switchover
What is the exact model number to your Philips TV?
Apr 21, 2012 | Televison & Video
My amp breaks up too much and sounds messy. I changed the tubes and resistors and it helped a little but didn't solve the problem. Could it be my speaker?
colearthur16, Only a slight chance of problem with your speaker. You will need to prove that all stages of amplification of the audio signal from input to output are not being driven into distortion (clipping) because of a bad DC power supply rail to the low level amplifiers or the high power "final" output amp! To prove this, you will need the help of an electronics technician who has access to a variable audio signal generator (amplitude and frequency) and a cheap 5 to 20 megahertz oscilloscope to view the amplified waveforms of the amplifier stages in the Fender Amp. Remember the following statement for the rest of your life!!! "All musicians who use electronic amplification to play musicial notes through speakers should have between 4 and 8 hours of classroom instruction on how typical amplifiers (tube and solid state) operate and how to troubleshoot them when they fail to perform to rated specifications!!!"
Cole, have the Fender amplifier (not the speaker) tested by a qualified technician to prove amp is not at fault!!! 12fixlouie
Nov 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Protect on dial
The protect message is an indication that a problem exists in the final amplification stage. In order to prevent damage to either the amp or connected speakers, the final stage is shutdown. Most commonly the output transistors are at fault. If you can update this with the make and model of the unit, I should be able to provide additional details and possibly the parts that are most likely defective.
Thanks,
Dan
Apr 04, 2009 | Audio Players & Recorders
I download Google Earth as directed,at the final stage, says, can't use DX? or other???....can't remember. Please help.
To me it sounds like your direct X is not supported.
Go to Download.microsoft.com
and from their you can download it!
PLease dont rate this as thanks for trying, as my rating decreases!
Im only a whiz now :(
Haha
If it still doesnt work open ruin and type dxdiag tell me what happens :D
Oct 24, 2008 | Computers & Internet
Prepares download copies but has problem at final stage of copying to disc
It might be because your cd is not good at the end that's why it fails at the final stage to copy the cd..try using the nero software and when it open use copy cd option and when it ask for burning select image recorder......so when it copies the cd you will get information whether cd will be get copy or not..,
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 26, 2008 | Computers & Internet
Burning
The songs you are tyrying to download do not have "transfer rights," so they will not work with any Mp3 player. Convert he songs to Mp3 format to solve.
Apr 18, 2008 | Philips GoGear HDD6330 MP3 Player
Apple iTunes Logo
51 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
