Question about Panasonic RR-US395 Digital Voice Recorder
Training my audio recorder to my voice in order to convert sound to text
Hi - I'm having trouble training the recorder to voice - my goal is to convert files I have recorded to text. I am following the manual's instructions, but once I get to #9 on page 49 of the manual, nothing happens.
Please help!
thanks, Betty
Buen dia, necesito el motor de reconocimiento de voz en español para mi grabadora, ya que no puedo usar la funcion de sonido a texto
Posted on Jun 09, 2008
1. My sound is very scratchy. I cannot hear myself very well. 2. How do I record not just my voice but the person that I am playing the video game with. Right now, I can only record my voice
All you have to do is to install a video capture software http://www.megaupload.com/?d=Y99OK8XJ where you will be able to record an audio in the output of your computer. After that you have install this software http://eviosoft.com/audio-converters/audio-converter.html this will convert or pick up the audio of your video. There is an instruction there how to use that software. Hope this solve your problem.
Jul 25, 2011 | Pinnacle Dazzle DVC 90 (210100371) Video...
How do I change a 32 Bit to a 16 Bit?
Not only does the wav have to be 16 bit, it has to be PCM, 11.025
or 22.050 kHz, 16 Bit, Mono. I think it would be easiest just to play the audio from your sound recorder right into the microphone of your computer, since the Dragon software is especially made for listening on the microphone, Or hook up the audio out from the sound recorder to the Line-In jack of your computer using a male to male phono cable.
Jul 18, 2008 | Olympus VN-3100PC Digital Voice Recorder
Tip
How to record audio on Mac OS X El Capitan
Some users of Mac OSX 10.11 probably find that recording audio is not so easy as before. Since this operating system made some changes in "Sound" preference, lots of audio recorders become malfunctional. This issue can be solved by QuickTime if you just need to record mic voice, but recording audio from sound card is another story. Soundflower is still helpful, however you may be troubled by the complicated settings. To make this stuff simpler, share you an efficient solution here.
Step 1: Open the online audio recorder, click Start Recording to activate the application.
Step 2: Follow the instruction and install a launcher, the recorder will open. You will only be asked to install the launcher when you use the app for the first time.
Step 3: Select the Audio source at the bottom of interface, it allows to record sound played on Mac, voice from microphone or both.
Step 4: You can start to record sound on El Capitan now, the sound can be streaming music, radio, voice calls or others. Click the Record button, recording will be started.
Step 5: When you want to stop, click the Record button again.
Step 6: You can access to more functions like play, rename, edit ID3 on Library interface.
Based on my experience, the application doesn't have restriction on recording time. The audio will be saved as M4A which can be played with QuickTime and iTunes.
on Apr 27, 2016 | Apple Mac OS X
Not having success saving new message for night or day prompt. WHat am I doing wrong?
Hi, the prompts on the Samsung DCS Voice Mail ask you to press 2 when you have recorded your message, this actually deletes the message, you have to press the # key to save. I have posted you a video with training tips on the DCS voice mail, others like this 1 are on Youtube by 'abbeytel'. a text version is on
http://www.abbeytelecom.com
Dec 23, 2010 | Samsung DCS 12 Corded Phone
No voice recognition
You must have already set up and trained a user with the Dragon NaturallySpeaking software prior to transcription. Make sure that the Digital Voice Editor (DVE) software is not opened prior to starting these steps.
Open the Dragon NaturallySpeaking software.
The Dragon Bar window opens. From the Dragon Bar menu, click the Sound button.
From the Sound button, select the Transcribe Recording menu item.
The Transcribe a Recording dialog box opens.
Click the large square button to the left to start the DVE software.
The Digital Voice Editor window opens.
NOTE: If the file you want to transcribe is still on the Integrated Chip (IC) recorder (which will be reflected on the left side in the IC Recorder window), you will need to connect the IC recorder to the computer using the supplied USB cable, or transfer the file to the computer.
Select the item you want to transcribe from the PC window on the right side.
Click on File from the tool bar.
Select the Voice Recognition menu item.
The Converting.. Dialog box opens.
The Transcription Options dialog box opens.
Click the Transcribe button to continue.
The Transcribing window and Dragon Pad window opens.
The text is displayed while the transcription is in process.
NOTE: Once the transcription is complete, it may be necessary to make grammar, word, punctuation, and formatting adjustments.
To save the text file, click on File from the tool bar.
Select the Save As. Menu item.
The Save As dialog box opens.
Browse to the folder location to which you want to save the text file and double-click on that folder.
The folder you chose should now be showing in the Save in drop-down box near the top.
Type in the desired File name in the File name drop-down box towards the bottom and then select the document type.
Click the Save button.
Click the X (close) button in the upper-right corner to close the Dragon Pad window.
Click the X (close) button in the upper-right corner to close the Digital Voice Editor software.
Feb 10, 2010 | Sony ICDSX68 Digital Voice Recorder
I would like to download my voice as a ringtone. I can record on Vista Sound Recorder but it is a .wma file, not a .wav. Can I do a voice ringtone on a Snap?
get a converter   i use total audio converter  or a mp3 to wav converter   i also have many polyphonic (.mid or .mmf) converters   to locate them come to filetopia (a downloadable software for chat)  and come to the All Good things room  we will help you   i am The_MacGyver
Nov 03, 2009 | Samsung SCH-u340 Cellular Phone
Ds2 to dss convertion
Watch this video and classic mode for your player and then you got dss files automatically and you play these file in express scribe..
Jul 07, 2009 | Olympus DS-2 Digital Voice Recorder
Olympus VN-3100pc
on Windows XP, you will need to convert those files into 16bit cd audio quality. You can do this thru Sound Recorder on the computer. Just make that you change the file name before converting. Open up sound recorder, open up file, save as, convert, then change quality to cd quality then ok. After it is saved in 16 bit format, open Windows Media Player and then burn.
Aug 24, 2008 | Olympus VN-3100PC Digital Voice Recorder
Convert .voc to .mp3 format
VOC format is not a commonly used format, most popular player software(Windows Media Player, Quick Time, iTunes, etc) and devices(iPod, iPhone, Zune, etc) do not support this format. To play VOC files in these software or devices, you need convert them to popular formats such as WAV, MP3, M4A, etc.
The following introduces a step by step guide about how to convert VOC to MP3.
VOC File Format
Mar 03, 2008 | RCA RP5020 Digital Voice Recorder
Audio converter for dss audio files
You can convert DSS file into wav format with DSS Player 2000 or the latest version. it can only convert it into wav format. after convert into wav format then u can use any other converter to change it into any other audio format. u can use total video converter or Sonic record now multilanguage software.....
best of luck.....
Feb 08, 2008 | Olympus WS-100 Digital Voice Recorder
Panasonic RR-US395 Digital Voice Recorder Logo
166 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
