Fault codes for brivis heating systems he30i no 5a thm code50
3 Suggested Answers
  • 148 Answers
SOURCE: brivis central heating fan will not switch off runs continuous
fan limit switch
Posted on May 12, 2009
SOURCE: brivis central heating problem code ''busy 40 H1
Hi, i recently had the same problem with mine and found that the inside adapter was unplugged. I plugged it back in and all is working find, so if anyone has the "Busy Hi 40" message on the control box the check the adapter :)
Posted on Dec 21, 2010
I need a schematic for the fuses on a 2002 VW Beetle. can you help me?
1 - Heated washer nozzles, heated outside mirrors 10A
2 - Turn signal system 10A
3 - Illumination 5A
4 - License plate light 5A
5 - Comfort system 7.5A
6 - Central locking system 5A
7 - Back-up lights 10A
8 - Telephone system 5A
9 - ABS 5A
10 - Engine control, gasoline 10A
11 - Instrument cluster, shift lock 5A
12 - B+ (battery positive voltage) for DLC 7.5A
13 - Brake lights 10A
14 - Interior lights, with central locking 10A
- Interior lights, only 5A
15 - Instrument cluster, automatic transmission 5A
16 - A/C-clutch, electrical water pump 10A
17 - Door lock heater 7.5A
18 - Right headlight, high beam 10A
19 - Left headlight, high beam 10A
20 - Right headlight, low beam 15A
21 - Left headlight, low beam 15A
22 - Sidemarker lights, right 5A
23 - Sidemarker lights, left 5A
24 - Wiper system, washer pump 20A
25 - Fresh air blower, air conditioning 25A
26 - Rear window defogger 25A
27 - Daytime running lights 10A
28 - Fuel pump (FP) 15A
29 - Engine control, gasoline 15A
- Engine control, diesel 10A
30 - Sunroof 20A
31 - Automatic transmission 20A
32 - Engine control, injectors, gasoline 10A
- Engine control, injectors, diesel 15A
33 - Headlight washer system 20A
34 - Engine control 10A
35 - Trailer socket 30A
36 - Fog lights 15A
37 - Radio system 10A
38 - Luggage compartment light, central locking system 15A
39 - Emergency flasher system 15A
40 - Dual horn 20A
41 - Cigarette lighter, 12V power outlets 15A
42 - Radio system 25A
43 - Engine control 10A
44 - Heated seats 15A
Mar 18, 2017 | 2002 Volkswagen New Beetle
Brivis zone
$900 seems like a lot for a new HSI and flame sensors :( 54 seems to be with the supply air thermistor. does the unit still operate with the error?
May 09, 2014 | Heating & Cooling
Brivis heating owners manual HE20i
I am having an error HO1 code#56 on my Brivis HE20i unit. It does not start. Initially had a code 55 and I did first press botton 1 followed by Fn and pressing 2 and 4 keys to make disappear the spanner. Can you help me, please?
Nov 01, 2010 | Heating & Cooling
Hi We have just arrived back in Wellington from overseas. Our house has a gas central heating system - the unit is Brivis Buffalo 20. What we would like to know is how cost effective the Brivis Buffalo 20...
Hi, if you are planning to change this system out, please stay with a gas fired central system as compared to a heat pump, they are much more cost effective. Heat-pumps have so many problems as there are more parts on them to go wrong. The compressor and condenser fan motor run year around as with a heat-pump they use what is called a reversing valve that changes the flow of freon making the indoor coil the outdoor coil and the same with the outdoor coil becomes the indoor coil in the winter season. I can recommend excellent gas fired units compared to the Brivis unit you have that is much more cost effective, such as the Bryant, Carrier, Goodman. I would go with a Bryant and talk to a dealer. Stay away from a heat-pump no matter what they tell you as I have worked on them for many years and if you have gas available, stay with gas. You will heat your home much faster and save on electricity as this heat -pump units need heat strips for back up heat as they can't keep up the temperature with out them. I hope I have been of help to you on this, and you will be kind when rating me as I know you will. Please contact a Bryant dealer as you will not regret it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Sep 05, 2010 | Heating & Cooling
Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Apr 12, 2010 | Heating & Cooling
Fuel Pump Fuse Number for a 1998 audi a4 2.8 quattro
Fuses: Fuse arrangement in fuse panel, behind instrument cluster, left
Fuse Arrangement In Fuse Panel 62624464
1 - Heated washer jets 5A 2 - Turn signals 10A 3 - Headlight washer (relay), illumination for glove
compartment, climate control, Automatic Transmission, instrument cluster 5A 4 - License plate light 5A 5 - Instrument cluster, seat heating, test connection
for cruise control, bulb monitor for auto-check display, Automatic Transmission display, switch
lighting, mirror switches and actuators, airbag
warning light, outside temperature indicator,
climate control 10A 6 - Central locking system 5A 7 - Anti-lock brake system (ABS) 10A 8 - Vacant 9 - Mirror heating 10A 10 - Vacant 11 - Cruise control (Automatic Transmission) 5A 12 - On board diagnostic system 10A 13 - Brake lights 10A 14 - Interior lights, reading lights, anti-theft alarm system, vanity mirror 10A 15 - Instrument cluster, power windows, climate control, automatic transmission 10A 16 - Anti-lock brake system (ABS), Anti-Slip Regulation (ASR) 5A 17 - Heated door locks 10A 18 - High-beam, right 10A 19 - High-beam, left 10A 20 - Low-beam, right 15A 21 - Low-beam, left 15A 22 - Side marker and tail light, right 5A 23 - Side marker and tail light, left 5A 24 - Wiper and washer system 25A 25 - Blower for heating, climate control 30A 26 - Rear window defogger, mirror heating 30A 27 - Rear window wiper 15A 28 - Fuel Pump 15A 29 - Engine timing 30A 30 - Sun roof 20A 31 - Tail lights, cruise control, automatic transmission 15A 32 - Engine timing 20A 33 - Cigarette lighter 15A 34 - Engine timing 15A 35 - Trailer recptacle 30A 36 - Fog lights 15A 37 - Radio 20A 38 - Luggage compartment light, central locking system 15A 39 - Emergency flasher system 15A 40 - Horn 25A 41 - Anti-lock brake system (ABS) 25A 42 - Vacant 43 - Vacant
Apr 05, 2010 | 1998 Audi A4
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Heating & Cooling Logo
198 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
