Question about Singer 3116 Simple
Arm wont move and needle wont go up and down any more in the middle of sewing, I was in the middle of sewing and all the sudden it froze up. It wont move any more and when you try you cant hardle move the handle on the right side that moves the needle up and down at all
How do you remove the entire bobbin casing
Posted on Oct 24, 2012
    Problem Solver:
  • 6 Answers
Annoying solution, but works every time. Remove the ENTIRE bobbin casing from the base and then turn the wheel. The needle should lift right out. Reassemble bobbin casing and oil very well.
This generally only happens when you are sewing through several layers of fabric or though a thick fabric. If you are doing neither, the timing in your machine may be off and you will need to get it repaired.
Posted on Jul 20, 2010
All of a sudden handwheel froze up.
Is it a mechanical machine (not computerized)? If so it has probably frozen from lack of oil during the time that it was not in use.
It was working now it seems to be frozen the needle part wont move
Feb 12, 2016 | Sewing Machines
When I move the arm and needle over, why doesn't the arm go down?
Arm and needle? Sounds like a turntable, not a sewing machine. There's typically a 'cueing lever' that controls up/down. Pull that lever forward and down to lower needle to record.
Jun 02, 2015 | Sewing Machines
Why is my needle not moving?
open the end cover of the machine and see if the needle shaft is moving up or down
it is possible that a screw has come loose or an arm has broken
May 14, 2015 | Sewing Machines
Sewing Machine froze up
it's very possible that the machine jumped time,even tho the needle didn't
break, it's possible that the needle bent.
the machine needs to be retimed at a sewing machine shop.
Apr 26, 2012 | Brother Sewing Machines
I have a Finesse sewing machine and I was sewing some placemats but it suddenly stopped feeding the material although it keeps sewing (foot moves up and down). According to the book I have checked the...
Can you see the feed dogs moving?
un thread, raise the pressure foot then manually turn the flywheel towards you and watch the feed dogs (the teeth that move under the needle plate). If they are not moving around and coming up above the needle plate then one of two things:
either you've accidentially disengaged the feed dogs, check the manual for instructions to reengage, sometimes a knob, button or slide, often on the front base or around the back of the free arm.
If they are engaged but not moving up at all, then something has gone in the drive to them, usually a gear in the free arm area. In which case, take to the shop for repair.
Jul 01, 2011 | Sewing Machines
My sewing machine clutch knob won't release so I can wind the bobbin without the needle going up and down. It used to release and suddenly froze. How can I release it?
Try taking a hair dryer to it and see if that will free it up. Sometimes heat can make things move. If, it is old, you have nothing to lose taking the cover off and seeing if a belt slipped off or a broken part is in there.
Dec 30, 2010 | Sewing Machines
My Pfaff 1211 was working and all of a sudden it
Your hook where your bobbin case goes in are most likele jammed with cotton. give it some oil and turn your handwheel backwards gently. Look if you see any cotton jammed and remove it
Jan 20, 2010 | Sewing Machines
Janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Feb 25, 2009 | Janome MyLock 634D Mechanical Sewing...
New singer 8280 needle hits overcasting foot and breaks
so, it sews for a while?  It sounds to me like the screw that holds the needle in place is loose.  As the needle moves up and down the screw loosens until that one fateful stitch, it comes out completely.  Try to tighten with a screw driver.
the other possibility is that it breaks if you are sewing over a bulky seam, like a flat fell.  as the presser foot "toes up" to go over the lump, the needle hits and there you are.
holler if that doesn't help.
Jan 18, 2009 | Singer 8280 Mechanical Sewing Machine
Singer 3116 Simple Logo
308 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
