Question about HP LaserJet 1320 Printer
It doesnt have a good printing output... what do i have to do?
    Champion:
  • HP Expert
  • 202 Answers
1 first are you using the reffil tooner if yes replace the tooner
2 clean & refix the scanner assembly
ur problem might be resolved
Posted on Jul 04, 2010
Tip
Problems with the output printing
How can i determine the left output unit to all printing jobs finish on this unit and this don't run to up output?....
***Sorry, my english is not good ****
on Jul 18, 2008 | Canon imageRUNNER C3220 Color Copier
Please help my zebra doesnt want to print barcode it print numbers i want to change from digits to barcode i have windows 7
in your guide book for the zebra it describes codes that must be outputted before the code number . in coding start a field, tell it where to place the field and orientation, tell it bar code type and height give it the output characters (i2of5) is special extra coding then close the field . close the label then print
Jan 09, 2014 | Office Equipment & Supplies
Appear duplex jam at display samsung ML-2150
Lubricate all gears and shafts inside the machine. There is an idle gear on the top back motor "where the paper comes out" the nylon it is made of shrinks causing the gear to seize on the shaft resulting in jamming. Super glue the fuser output rollers to their shaft. the rubbers on the output roller expand and slip when heated (usually after printing a large document) printing one page then resting/cooling down the problem doesnt occur. the idle roller on the duplex feeder also breaks off.
Jan 06, 2011 | Samsung ML-2150 Laser Printer
Blurred printing at the x offset
Print head is not aligned properly . You need to adjust heating plate on head.
Aug 02, 2010 | Evolis Dualys ID Card Printer Smart Card...
My Kodak Easy Share 5300 has new ink, it shows that it has new ink, but when it prints, it looks like it is out of ink.
Run the printer through a "nozzle clean" cycle. If this doesn't clear the problem, if you can see beneath the print head (the part that moves back and forth inside the printer) check to be sure some dust or paper chip may be blocking a portion of the output nozzles.
Jan 04, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Wont Print
try to go under control Panel - Administrative Tools - Services, then scroll down to Print Spooler and stop the service, then restart it. Try to print now.
good luck
Mar 31, 2009 | HP Officejet J5780 All-In-One Printer
Check page counter on Canon MF6590
if the control panel doesnt have the "Check counter" button then you need to print the System dump list.
Access to service mode, then go to Report, then choose report output, then choose system dump, then press OK.
All the above info is classified since this machines are not suppoused to be kept track of prints like that for the user. Reason why i cannot go further.
when the page is printed (the first one) tells you how many copies you have Totally printed... under PRINT-TTL.
good luck!
Jan 29, 2009 | Canon ImageClass MF5770 Laser Copier...
Epson cx6000 will not print
Have you tried replacing the cartridge....to verify
keep me posted
Cheers
Nov 13, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Zebra Z4MPlus doesnt communicate with PC
Ok,
This machine has a parallel port. Try to print via parallel cable. If it works, consider staying with it. Serial ports are a pain to manage.
If you absolutely have to do it via rs232 though....
Question 1. Has it ever printed?
If yes, Go into Windows Printers and Faxes control and select the Zebra or whatever printer that you are using. Right click on it and you should get a menu that at the bottom say "Properties", select that, then you should get a new window with tabs at the top. You want the tab for "Ports". Select it and you will see all of the different output ports that you can direct your printing. RS232 is a COM port. So start at COM1, check it and try to print. If that doesn't work, go to COM2, etc.
Last resort, If you can't get control via the printer driver program, you will have to try redirecting the print manually (now you will understand why I said to stay with parallel output).
What you have to do is redirect your printing via the dos "mode" command.
Under "Start Menu" goto "Run" and put in "CMD" and click "OK".
This opens a black square window with a cursor blinking. Type in this:
mode com1:9600,n,8,1 (enter)
mode lpt2=com1 (enter)
Tell your program to use LPT2 if you can and see if it works.
By now a parallel cable instead of RS232 should be looking really good.
Mar 12, 2008 | Zebra Z4Mplus Label Printer
HP LaserJet 1320 Printer Logo
Seeker5211
Seeker5211
