How would u get the ip address of a cam4 user?
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details
Thanks for using FixYa.
Posted on Jul 09, 2010
How to stop user privately setting up a static IP address?
Huawei S2300/3300/5300 series switch although no H3C switches am user-bind command, but through the DHCP Snooping function can also be realized IP+MAC+ port binding to prevent users set up a static IP address. For example, if the request port Ethernet0/0/1 in addition to the static IP address for the 1.1.1.2, MAC address for the 001c-2309-9aa7 corresponding to the user, all other static IP users can not access the internet. Configuration is as follows:
Configure the device DHCP Snooping
# enable the global DHCP Snooping function.
[Quidway] DHCP snooping enable
# configure user side interface of VLAN.
[Quidway] VLAN 100
[Quidway-vlan100] quit
[Quidway] interface Ethernet 0/0/1
[Quidway-Ethernet0/0/1] port default VLAN 100
[Quidway-Ethernet0/0/1] quit
# enable VLAN DHCP Snooping function.
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping enable
# configuration interface for packet inspection at the user side
[Quidway-Ethernet0/0/1] DHCP snooping check ARP enable
[Quidway-Ethernet0/0/1] DHCP snooping check IP enable
# configuration static binding table entry
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping bind-table static IP-address 1.1.1.2 mac-address 001c-2309-9aa7 interface Ethernet 0/0/1
Aug 06, 2015 | Huawei Boxed Ls-s2318tp-ei-ac Quidway...
Keyboard works intermittently in cam4
Could be the contacts are shorting out. Dust, Grime, and Moisture can cause these problems. If after you attempt to clean out the keypad, it still is intermit, the keypad needs replacing.
Jan 02, 2014 | Dell Inspiron Computers & Internet
What is the ip address
IP address
noun Computers. a code that identifies a computer network or a particular computer or other device on a network, consisting of four numbers separated by periods. See also IP.
http://dictionary.reference.com/browse/IP+address
PS. Free points for newcomers or are you to lazy to google it?
Aug 23, 2013 | Comtrend CT-520 Router
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address
Jul 24, 2013 | Computers & Internet
What is an ip address
An IP address is also known as Internet Protocol Address.It is very important in Internet.Every Internet users are identify by their users using their IP address.IP address is Unique.You can get it from your Internet Service Provider[ISP].
IP address are two types.
There are Internal and External IP address
Internal IP means that your system IP address.
If you want to know your system ip address follow these steps:
Start--->run-->Type cmd
Then command prompt will display.
type ipconfig
then it will display your system IP address
External IP address means that your network IP address.
If you want to know your Network IP address then visit IP-details.com here it shows the details like ISP(Internet Service Provider),IP location,country,latitude,longitude etc..
Mar 15, 2013 | Computers & Internet
Need help getting a Toshiba e-series167 to work properly. connected via ethernet cable, using an IP address and have several users using the printer. It will not work consistently. I have connected...
You need to setup a fixed IP address for this printer that no other users will use this address. Please follow the printer user manual in how to setup a fixed ip address. You will need to diable the DHCP ip address in your printer.
Secondly you will need to reserve this IP address in your router's DHCP server which corresponds to your printer's MAC address (a unique machine address code for each device). Please follow this properly in your router's user manual.
Thirdly please unblock the firewall settings in every PC that needs to use this printer. Usually this will be unblocked when you install the printer driver or program that comes with the printer.
Fourthly, please install this printer program properly that comes with this printer. You should detect this printer's fixed ip address during the process of the installation.
Please let us know any problem you may have in future.
Jun 21, 2011 | Toshiba E-Studio167 Copier
I have two user on my computer but on one i can get on the internet and on the other i cant it says change the proxy setting
every user created on the OS will have to have different settings.....
before making changes...get the foll info from your internet service provider
IP Address, Subnet mask, Default Gateway, DNS server address both primary and secondary
once that's available.....
you can use different settings in in WinXP as below....
Control panel / Network Connection /Local Area Conn /Right click / properties/ Internet Protocol TCP IP / Check Box / Propertis / in IP address use the IP address that's been assigned by your internet service provider
log in to first user accunt and make the settings....for....
use the info obtained from the service provider.....
....then
in the IP address filed use some thing similar like this..(check your internet service provider for that info).....the foll is only an example from my PC
say....192.168.1.2 for user ONE
log out....
shut down and restart PC
log in to second user accunt and make the settings....for all the above fileds....then
in the IP address filed use 192.168.1.4 for user TWO....(note the difference of the last filed of the IP address....2 vs 4)...every new user a/c the last field of IP address keeps changing
1st user ....say 192.168.1.2
2nd user .........192.168.1.4
3rd user ..........192.168.1.6
etc...
http://windows.microsoft.com/en-IN/windows-vista/Change-proxy-settings-in-Internet-Explorer
hope this helps
reg
Suresh
Apr 28, 2011 | Google Chrome
Change ip address at ricoh aficio 2022
Hi, to change the IP address of a Ricoh Aficio 2022, follow these steps:
- Press the User Tools/Counter button.
- Choose System Settings.
- Choose Interface Settings.
- Choose Network.
- Choose IP Address.
- To specify an IP address, choose Specify, and then enter the address you want to use. To have DHCP automatically assign an IP address, choose Auto-Obtain (DHCP).
- Exit out of the User Tools screen.
Dec 15, 2010 | Ricoh Aficio 2022 Black and White Copier
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
First of all sorry for my english i have 10 user pc and 1 server (windows 2000 sp4) and 1 modem i have static ip address in my modem and i give the local ip in my modem 192.168.0.2.......ok i give the...
Each of the eleven(!) computers needs:
1. a _unique_ IP-address
2. the IP-address of the "gateway" device
3. the "network-mask" (usually 255.255.255.0)
The IP-address for your server must *NOT* match the IP-address of any of the 10 computers.
The IP-address for your server must *NOT* match the IP-address of the "gateway" computerl.
Nov 13, 2009 | Microsoft Windows 2000 Server
Computers & Internet Logo
288 people viewed this question
David Payne
David Payne
