Question about Garden
Wards signature 2000 lawn tractor TMO-3396409 18/46 parts and belts.i need to know the lentgh or part no. Of the upper deck belt. Mark
I have a tmo3396409 mower I need a7 speed trans axle or a 25 and 31 tooth straight gears
Posted on May 04, 2013
4 Suggested Answers
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
  • 3074 Answers
SOURCE: My 2003 troy-buit 46" lawn tractor won't go
check your drive belt, it is different then the deck belts, as it is above them
Posted on Apr 13, 2011
Testimonial: "Fast Answer to know where to start checking for the problem!"
  • 640 Answers
SOURCE: what is the correct belt size for yard machine
Take your make and model number (located under seat) to your local lawn mower repair parts shop and they should be able to get you the appropriate belt.
If helpful, please rate.
Posted on Jul 11, 2011
I need to know the placement of the deck belt on my husqvarna mower 26k54t. I think I keep twisting it the wrong way, which pulleys need the flat side of the belt on?
https://www.partstree.com/parts/husqvarna/mowers-lawn-garden-tractor/gth-26k54t-96043001101-husqvarna-garden-tractor-2006-03/mower-deck/
Sep 09, 2016 | Husqvarna Garden
I have a 1990 toro wheel horse classic 312 8 lawn tractor, it has a 42 inch side discharge deck, What's the deck drive belt size of this mower, model 31-12K801, I have searched for hours
If the belt is in one piece, put a chalk mark on the back of the belt and measure the length by running a tape measure from one side of the mark all the way around the belt until the mark appears. Take that measurement, subtract an inch for stretch and that number is the number of the belt you need. If it's broken in two, not three, then simply measure the length of the belt.
May 28, 2016 | Garden
Need belt diagram for montgomery wards 2000 elite riding mower
mtd signature 2000 elite Also, make sure you push in the clutch/brake in order to create enough slack to get the belt on....Good luck!
Aug 20, 2014 | Garden
How do I put a genuine factory parts deck drive belt O.E. 954-04062/754-04062 on 38"Bolen's lawn tractor model#13AM762F765
To start with, the easiest way is to remove the mowing deck from the tractor. It will really be tough if you don't or can't. You may need an owners manual to guide you through all the steps.
1. Remove the cutting deck from the tractor 2. Work the old belt off (if not broken) the mandrel pulleys and idler pulleys 3. Pull the belt away to reinstall a new one 1. Work the new belt around both the mandrel pulleys 2. Make sure the belt is in all the pulley grooves and inside all the belt guides 3. Now you have to reinstall the mowing deck. Here are some diagrams that should help you.
http://www.ereplacementparts.com/bolens-13am762f765-2005-lawn-tractor-parts-c-27272_27390_27402.html
Apr 19, 2011 | Garden
Need too know proper deck belt installion
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Sep 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Ineed to get the belt routing diagrams for the mower deck and rear rototiller attachment for an older cub cadet lawn tractor
GO TO INTERNATIONAL PARTS SITE, ENTER TRACTOR MODEL, SELECT PROPER DECK AND THE PARTS LIST HAS A BELT DIAGRAM BUILT IN. IF YOU HAVE AN INTERNATIONAL BELT FOR IT BEAT A PATH TO A BEARING COMPANY TO ORDER THE SAME OR BETTER BELT FOR LESS THAN 1/4 THE IHC COST.
Apr 27, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Have a power kraft 18.5hp with 46'' deck, need a
first you'll need a model number. look on the underside of the seat, or on the metal plate between the rear wheels for the model no. sticker. wards tractors were made by MTD. there will be two numbers plus the serial number, write 'em both down. then log on to www.milacalawn.com. in most cases, you'll be able to pull up an owner's manual for your tractor with one or the other model numbers
Aug 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cant get a deck cutting belt for model YTH 2448T960430008 48 INCH CUT TRACTOR MOWER
which belt do you need the primary or secondary i have part # for ya i can also order them 180808 & primary part # is 174368 let me know if i can further help thanks wade
Jul 07, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
1,293 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
