Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony WEGA Just received this monster from my parents to use in my first home. Cable set up fine and the picture is fine. Problem is with the DVD hookup. The back of the tv has Three VIDEO ports and a GAME and HD port. I have tried hooking Monster cables up to the VIDEO 1 port as well as the old school red, white and yellow connectors. The problem i see is that when you use the TV/VCR or Input button on the TV remote to access the aux units.....there is no display of a VIDEO component....the TV will only read "DVD, HD, GAME, ANT A, ANT B." How in the ****** do I get the TV to recognize the VIDEO 1 component? Thanks.
  • Sony Master
  • 8,617 Answers
If your remote has a wega gate button press that and it will allow you to add and edit the inputs.
Posted on Apr 17, 2008
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Super high pitch whistle from tv, only powering it off helps.
Shut it off and unplug. You have a serious HIGH VOLTAGE problem that could cause a fire. Professional repair needed.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony TV KV 27FS 100 Picture in BW when connected to my Laptop.
connect a dvd to the tv using the same cable.
If the color is O.K. then the fault is in the laptop.
Thanks Guy9
Jul 07, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Jan 04, 2008 | Denon AVR-3200 Receiver
HDMI Monster cables
I had the same issue. I think you have to reset your PS3. I don't remember how I fixed it but I did find the anwser in the PS3 user manual "Trouble Shooting".
Dec 27, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
No picture?
I called sony, even though the manuel shows that you can use a component wire to hook up the set top box and hdmi for the tv and dvd sony claims that you can not do this. The cable box must also be wired with an hdmi cable going into the video 2 port.sony claims it doesn't work using component and hdmi together because the receiver is unable to up convert. I hope this helps. I have not tried it yet (i'm at work) we'll see what happens when i get home.
Dec 25, 2007 | Sony STR-DG510 Receiver
Trinitron KV20FV12 sony
check the video cable first / next try using a s-video or hdmi cable some dvd players you have to select the way the picture is sent from the dvd player
Dec 10, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
Dec 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Video signal drops out
Well, I have a solution and a question. First, why do you have S-Video hooked up from the sat receiver? is it a non- HD unit? Does it have component out? if so use it. Next; your receiver, as awesome as it is,it is 3 model years old and the HDMI firmware that was used in 2005-06 was version 1.1 which unfortunately for all of us was a "failed" format when using DSS,Cable, or FIOS. The problem was passing the DHCP copyright protection format from one source thru another to a third. Sounds complicated, I know, but that's what the issue is. The Good news is; the human eye cannot tell the difference between 720p and 1080p on any TV set 50" or smaller, and that is a fact. and the 2600 would only convert from s-video to 1080i which is equal to 540p. So, to make a long story short and understandable, if you use a good quality component cable to your TV set (Monster, Phoenix Gold, Apatchure, etc) your picture quality will not suffer and there is no reason to be upset at your receiver since it was firmware provided by HDMI not Yamaha and was a problem on every receiver made with 1.1 firmware. So here's what you do Hook up your Sat receiver component (if you have it) S-vid if you have to, and any other sources that are going to pass video thru your receiver either s-vid,component, or standard vid. The only exception would be a blu-ray DVD. I would run HDMI direct to your TV, then run digital coaxial for audio to the DVD Digital audio input of your receiver. You have an awesome receiver that has lots of cool features and a bullet-proof electronics! enjoy it! Hope this helps. If you have any more questions, post a comment and I will help some more.
Jan 07, 2007 | Yamaha RX-V2600 Receiver
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
237 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
