Question about Hasselblad H3DII-31 Digital Camera
I have a problem with hasselblad 80 mm lens (with H3DII - 31 camera). When camera is turn on - camera reported "lens problem - ID 44.5". When I'm using 28 mm lens - all is OK, camera works well.
    Brigadier General:
  • 11,967 Answers
This is an $18,000 camera. You shouldn't be asking us for advice...you should be contacting Hasselblad!
Posted on Jul 04, 2010
Canon 35-80 Error 1 clean your lens
The usual method is to use a pencil eraser on the contacts on the lens and the camera. Be careful not to get the bits in the lens or camera
Jan 19, 2014 | Canon EF zoom lens - 35 mm - 80 mm
If you had a compact camera it would say 10x zoom what is the equivilent in a 70mm -300mm tamron
A 35-80 mm lens is 2.3X zoom. Divide 80 by 35 and you'll get the result.
It is usually better to know what the focal length of a lens in "35 mm equivalent" is and judge by that, rather than relying on the "X" power of the lens. For instance, most point and shoot cameras start at about 35 mm and have either a 3X or 4X zoom. This would make it a 35-105 or a 35-140. I've seen some that start at 28 mm, though. A 3X starting at 28 mm is 28-84 and a 4X is 28-112. Neither one is a particularly strong telephoto lens and the 4X is just about the same as the 3X that starts out at 35 mm.
It's also important to realize that tradition dictates that lens focal lengths are usually expressed in terms of "35 mm equivalent," where "35 mm" refers to a 35 mm film camera. This is because of the relation between the sensor size and the actual focal length of the lens and the resultant angle of view of the lens.
I have one point & shoot that is actually a 5.8-24 mm zoom. This is a 4X zoom. The 35 mm equivalent is 28-116 mm. The sensor is 7.2x5.3 mm. (1/1.8") (And I wish I knew someone who could explain how the heck they came up with sensor size terminology!)
I have another point & shoot that is actually a 5.7-17.1 mm zoom. This is a 3X zoom. The 35 mm equivalent is 34-102 mm. "How could a shorter focal length give a longer 35 mm equivalent?" you might ask. It's because the sensor is only about 5x4 mm. (1/2.5")
I have a few Nikon DSLR's and - thankfully - they all have the same size sensor. They all have a "lens factor" of 1.5. This means that you just multiply the actual focal length of the lens to get the 35 mm equivalent and then you can make comparisons accurately from camera-to-camera. Most Canon's, for instance, have a lens factor of 1.6. On a Nikon DSLR, a 28 mm lens is the "35 mm equivalent" of a 42 mm lens. On most Canon DSLR's, the same 28 mm lens is the equivalent of a 45 mm lens.
These example are just to show you how freaking confusing it can all become if you try to make sense of the "X" power of a zoom lens.
Bottom line...
Check the 35 mm equivalent specifications for the lens. This way, you will be leveling the field and comparing apples to apples. More or less.
Jul 10, 2012 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
I pressed the shutter release button while attaching the lens to the body. Now my Hasselblad is jammed. The diaphram is closed, the shutter crank knob is turned about halfway, and the lens is stuck half...
On my Hasselblad 501 CM, I have never encountered this problem. As expensive as these cameras are, and delicate, I wouldn't chance it. I would contact the Hasselbad company and ask them to fix it for you.
http://www.hasselbladusa.com/service--support/technical-support/contact.aspx
I would try the above link to contact hasselblad's tech support if I were you.
Good luck on this.
Dec 25, 2010 | Hasselblad 501CM Medium Format Camera
I HAVE A CANON EOS REBEL T2 35MM FILM CAMERA AND AM PURCHASING A CANON TI1. CAN I USE THE SAME LENS ON BOTH CAMERAS?
Yes, you should be able to use them. Be aware, moving to digital there is a 1.6 crop factor. The means your 100 mm lens will have the field of view (FOV) of a 160 mm. No, it does not mean it is a 160 mm it is the fFOV is the same as a 160 mm. Also, at the other end is were you will most want to purchase a wide angle lens.
Example: your 28 mm film lens now has the FOV of 44.8, not wide angle. As you can see wide angle is where the move to digital crop sensor cameras lose out. To get back to wide angel you would need a 17 mm lens, that would give you 27.2 mm FOV.
To figure FOV take the lens multiply it by the crop factor. On a Canon it is 1.6, on a Nikon it is 1.5, the 4/3 sensor is 2.0.
Nov 01, 2010 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Im getting a lens error message on my h3dii ....message reads ... lens error id 21:1
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
May 22, 2010 | Hasselblad H3DII-31 Digital Camera
I have a Hasselblad 500C/M camera and can't get the lens on.
http://www.butkus.org/chinon/hasselblad.htm
Get the manual. They are picky, it might require the shutter to be wound or something like that.
Jul 01, 2009 | Planar Normal 80mm f/2.8 CFE Lense
28-80 mm sigma won't auto focus
The lens may not be a dynex type so it wont work on your 700
Nov 27, 2008 | Canon Sigma 28-80mm f/3.5-5.6 II AF Lens...
Unsharpness
if you can acquire sharp image with your 80mm, but not the 50mm and 120mmmm, there is no problem with your camera body, i.e. lens-flange to film plane. but how come you can not manage to get a sharp spot anywhere from the full turn of focusing rings with your 50mm and 120mm, unless the lens units inside these 2 lenses shifted. i doubt this happened to both lenses simultaneously?
if you are sure that your lenses have problem, send them for focusing test, since they are good and expensive lenses.
pc-cook
Sep 14, 2006 | Hasselblad 503CW Medium Format Camera
Hasselblad H3DII-31 Digital Camera Logo
159 people viewed this question
Top Hasselblad Cameras Experts
Steve
Are you a Hasselblad Camera Expert? Answer questions, earn points and help others
