Question about HP W1707 LCD Monitor
It keeps telling me there is no signal (when everything is showing up just fine) and then it tells me to check the video cable when everything is hooked up corectly.
  • HP Master
  • 1,606 Answers
I'm not 100% sure about this as it sounds like a intermittant problem but I think your problem is going to be either the connector on either end or the cables.
All it takes is one pin not seated properlly or dirty etc and the signal could be out giving you the error. As long as it was only certain pins with a strong enough signal that would create your messages.
Basically all you need to do is take the cables off on both ends and then reseat them a few times. That will usually be enough to clean any corrosion and even straighten the pins.Alos look when you have both ends off for pins that are not long enough or bent out of shape. Don;t forget to check the connectors on the tv and cable box etc as well as the cable. You can also try a differant cable if you have one or can borrow one to rule it out.
Posted on Jul 04, 2010
I have a craig tv. It keeps telling me that there is no signal. Everything is plugged in. This just happened all of a sudden.
Check and make sure its on the correct video input...if your using hdmi cord make sure its under that input
Mar 31, 2017 | Craig Televison & Video
TV doesnt shows video signals, audio is working can you tell me the remedies
1.restart tv or
2. Check everything or
3. May reboot Tv if you can
Jul 28, 2016 | Televison & Video
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
I replaced my screen and the video is not showing, I believe I did not replace the video cable correctly... Can you tell me how to properly replace the video cable please?
i dont know your model but usually the cable only fits one way round,dont force it ,keep your hands dry and clean and have a fine flat screwdriver to hand to just push the ends or whatever ,etc--good luck!
Davey Snake!
Oct 24, 2010 | Toshiba Satellite A100-S8111TD Notebook
Digital projector is shutting down as soon as dvd
Hi make sure that in the projector menu it doesn't have an option to cancel "control" as many tv's with hdmi have the capability to receive command signals through the hdmi cable.
Also make sure that your receiver is set for hdmi signal you must designate which input you are using on the receiver and then tell it what type of signal you want it to use.
you may have just pushed a button that changed these settings somewhere along the way.
hope that helps
Dec 30, 2009 | Denon AVR 3808Ci Receiver
Just got this TV - trying to hook up to cable and keeps telling me input 1 ch 91 on the screen and wont pick up cable. Its a home theater system console with vcr inputs and everything. Just trying to get...
The set needs to be autoprogrammed with the cable attached.Auto program can usually be gotten to using the remote or font panel menu - select cable as signal source or type.
you could also try hooing a VCR to video 1 input and then the cable to the VCR and changing channel with the VCR.
please Vote rate me if this helped
Oct 23, 2009 | RCA G27648 27" TV
No signal keeps appearing
This message means the monitor is not getting a video signal from the computer.
This could be a loose video cable, a faulty video cable or a faulty video card.
It is possible the monitor is faulty, try connecting it to another computer with a different video cable. This will tell you if the monitor is faulty or not.
Sep 14, 2009 | Acer 22" X223w LCD Monitor
Monitor on power save mode and using wireless keyboard and mouse
This sounds like the monitor is not reading a signal from the computer. I had the same problem when I installed a DIV cable from my old VGA cable. The video card was still sending the signal via VGA port instead of the DVI port of my video card. You should cheack the cable to you're computer and what port is being used. If everything is hooked up correctly then there might be a problem with the cable. Other then that it could be you're video card. If the hard drive is running and everything is running fine then what I said should be whats wrong. If nothing works go back to the shope and tell them the new problem you have.
Sep 10, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My HP Officejet J4540 All-in-one printer is showing Offline. I have checked all connections and all appears ok. Could you tell me how to change that status to Ready?
It shows offline if the printer is not communicating. Initially open printers folder and right click the printer icon and check if "use offline" option is not ticked.if its ticked then un-tick it. if everything looks fine then:
1)first try unplugging printer from main power cord for a minute and then plug back in and check after refreshing if it becomes ready.
2)other thing to do is to remove the usb cable from behind the printer and plug back in after 45 seconds.
3)it is also quite possible that the usb port or cable might have gone faulty.in that case try replacing usb cable and check.
thanks ,keep updated and accept the solution.
Sep 02, 2009 | Office Equipment & Supplies
PS3 - tv says no signal
You need to change the resolution output on your PS3 to match the capabilities of your TV. If your TV is not HD you can't leave the PS3's video output on HD. SCART is for european television connections. Have you tried using component cables? Have you tried changing your tv's source to Video 1 or Component 1 or HDMI or anything that might work? Good luck!!
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
HP W1707 LCD Monitor Logo
64 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
