Question about Refrigerators
Refridgerator not cooling. Motor is on Fan is on Coils are not warm. Could it be the thermostat?
    President:
  • 1,891 Answers
If colis are not warm or some what hot . the compressor is not running . compressor runs when the fan is on feel the top of comp see if its hot . this may be a bad comp relay .. if not running .. some times you can hear a clicking sound about every two or three min . this is the relay trying to start comp .. mm
Posted on Jul 04, 2010
Refrigerator not cooling properly
There are several things that can cause cooling problem with your refridgerator. The first and most common is dirt dust and lint clogging the condenser coils. These coils are usually located underneath the refridgerator and have a small fan that blows air across them. If they are clogged, the refridgerator cannot get rid of the heat to allow it to cool properly. To check and clean these coils you must first pull out the refridgerator and unplug it. Remove the lower panel ( usually made of a cardboard material) this will give you access to the compressor and fan and coils. Check the coils for dust,dirt and lint. Clean out carefully with a vacuum cleaner or brush( you can get a brush specially made for this ) check the fan motor to see if it spins freely( some units may not have a fan) plug unit in to see if fan runs (make sure to temporarily turn thermostat down colder to turn on compressor and fan). If fan does not come on with compressor you may need to replace it. Put unit back in place and see if that solves the problem. If this does not help, you will probably have to have a appliance repairman check out unit.Hope this helps.
Dec 15, 2013 | Maytag Refrigerators
My Amana refridgerator does not cool but the freezer works
If you have noticed a rise in temperature in the fridge, and there seems to be fromst building up in the freezer than your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Sep 07, 2012 | Amana Refrigerators
I have a GE GSS25WGSA WW refrigerator and the freezer wont stay cold
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Jun 17, 2012 | GE Refrigerators
Hi my refridgerator is not cooling and the fridger section is also not working, every thing is been melted. we can here the refridgerator running but its not cooling.
b44df16.jpgIs the fan motor running below and the coils clean? 8dff5ce.jpg6e3f9f7.jpgIf nothing is running but the light is on you might have a stuck defrost timerb365bb7.jpg
Aug 30, 2010 | Kenmore Refrigerators
Refridgerator just stop cooling...it got warm and the ice melted. When I unplug an plug back up it starts cooling again an seems to work fine but as soon as it gets to -4 freezer and -38 it will work for a...
Hi,,
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this helpout......
Aug 14, 2010 | Samsung RS2534 Side by Side Refrigerator
2003 refridgerator
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 18, 2009 | Refrigerators
Hi i just replaced my evap fan in my amana mod bbi20tpsw i have 120 v at the motor leads until i hook up the motor then the voltage drops to 9 v
Replace the defrost thermostat , not the motor . The defrost thermostat ( bimetal ) sends power to the fan motor when bimetal is cold ( 35 degrees maybe ) . When first plugged in , the compressor cools the coils until the bimetal clicks on . Then the fan comes on , blowing cold air into the fridge . If the fan came on when first plugged in , it would blow warm air , gradually getting colder . Amana is the only brand using this process of coolant .
Sep 02, 2009 | Amana Refrigerators
Refridgerator too warm freezer ok running constantly
could be your evaporator fan which is located in freezer.If you dont hear it blowing when compressor is running then it is evap. fan motor.if you see alot of frost building up on back panel inside freezer then you have a defrost problem.check heater and thermostat to see if they are good or bad.the thermostat will usually pop apart but not always it is located at the top in back of freezer on coils.it will have two wires going to it.good luck.and unplug first.
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
