Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How do you open the cover to change the light bulb?
    President:
  • 3,197 Answers
Everything depends on the model you have.
Posted on Jul 06, 2010
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
Need to change rear brake light bulb on a 2000_L sedan. Owners manual addresses only the turn signal bulb change proceedure. The brake light fixture is flat not round.
there is an access cover in the trunk.Open that and just pull the bulb fixture out replace the bulb and place back in the hole.
Apr 07, 2012 | Saturn Cars & Trucks
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do I change the light bulb? I twist and pull but nothing happens. I have a Kenmore 106.72864100.
Is it the cover or the light bulb that isn't coming out? The cover for the 74889 needs to be pushed up and then pull it forward and down. It is hanging by a tab that holds until the angle of the cover is changed to a shallow angle relative to the back of the fridge. The light bulb should unscrew by turning it counterclockwise. If the bulb was previously overtightend, then you may need to use something to improve your grip on the bulb. I sometimes use the plastic jar opener sheets. If the bulb breaks, remove the remainder of the bulb from the socket with pliers (I use needle-nose or similar long straight blade pliers held open to the width of the butlb).
You should unplug the appliance while changing the bulb.
The manual for the Kenmore 74889 is available here: http://www.managemylife.com/mmh/owner_manuals/5899/KENMORE-Top-Mount-Refrigerator-L0411041?brand_name_search=Kenmore+74889 . Other Kenmore manuals can be found by using the search engine here: http://www.managemylife.com/mmh/owner_manuals .
I hope this helps.
Mar 21, 2011 | Kenmore 74889 / 74882 / 74884 Top Freezer...
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
How do i change the bulbs on a jvm1870sk03 microwave
That's covered on pages 35 & 36 of the owner's manual here.
your GE supplier.
or pull the plug. *
to open.
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
* If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
Apr 25, 2010 | GE JVM1870 Microwave Oven
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
How can I change the light bulb in this fan. The
They have opening clips on the top side all around the cover, you can reach it with your fingers and try opening them all, the cover will come off easily, once done you can unscrew the light bulb and install a new one.
Feb 07, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
How to change the bulb on the front head light on my 2002 jaguar x-type
Dip beam (outer) headlight
Open the bonnet.
Slide open the two spring clips (A) and remove the cover (B).
Press the spring clip inwards and push towards the bulb
to release the bulb and then remove the bulb from the light
unit. Pull the connector from the bulb.
Fit a new bulb to the connector, type H1 for dipped beam.
Fit the bulb to the light unit, the bulb will only correctly fit in
one position. Engage the spring clips to retain the bulb and then
fit the cover and retain using the two spring clips.
Close the bonnet.
Note: High Intensity Discharge (HID) Xenon light units,
type D2S 35W, are not renewable, contact your Dealer if the headligh fails to operate
Oct 07, 2009 | 2002 Jaguar X-Type
Light Bulb
open the cover ,unscrew , replace the bulb return cover ,then ok
Dec 23, 2007 | Whirlpool GSC308PR Electric Double Oven
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
407 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
