Question about Nikon COOLPIX S230 Digital Camera
When I turn on camera it makes A buzz sound and lens goes in and out then says lens error
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 02, 2012
  • 374 Answers
SOURCE: says lens error!!!!!
A lens error requires to be sent into repairs. Give them a call at 800-706-2534 option 2.
Posted on Apr 05, 2008
dlundmark
  • 797 Answers
SOURCE: nikon L3 lens stuck
Hi:
Lens errors like this usually happen as a result of something damaging the lens in some way.
It could have been against something to prevent the lens from moving out.
It could have been dropped when the lens was out.
If the lens is impacted when the lens is out, damage can occur.
If there is a buzzing, grinding noise as the lens extends, then the probability of damage to the small plastic gears, internal guides or other internal lens parts is high.
What can be done is, as mentioned a few times in my posts, to hold the lens back or pull on it as the camera starts.
This may cause more damage, and may not help at all, but some cases may re-align the internal parts in the lens assembly. This may be worth a try, since the camera is useless unless the lens works right.
Hope I can give some help here on these.
Posted on Jul 26, 2008
PAPA-RAZI
  • 37 Answers
SOURCE: coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Posted on Sep 02, 2008
  • 320 Answers
SOURCE: lens do not open
try smacking the sides of camera.also try to make the lens up down with you hand couple of times.then check out.
Posted on Mar 23, 2009
  • 102366 Answers
SOURCE: S210 Lens Error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced or replaced.
Posted on Dec 31, 2009
Nikon s220 lens error
The s220 seems to be very susceptible to lens errors, usually associated with the lens barrel being unaligned. It only takes the slightest bump/drop in many cases. Fixing it is a hit or miss solution. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html Has a good list of possible fixes.
Jul 06, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Camera turns on makes buzzing sound and casio jingle music then the screen reads lense error
hi, there's a dust or sand goes inside of your lens gear thats why the buzzing noise occur.bring to service center and request for cleaning only.
thank you
Jun 19, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Camera says
Hi there just like to informed you that 2 reason can make a noise.
1. low or old battery's using.
Solution: replace it if too old or charged it fully.
2. Lens error. Internal lens guide pin if damaged then the camera goes off with bad noise.
Solution: repair or replaced the lens guide pin.
Thanks & waiting for your feedback.
Apr 01, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
When turning on there are several buzzes and the lens goes in and out then closes and screen reads "lens error!" in red
There is dirt or an obstruction in the lens telescoping mechanism or the lens cover that is preventing it from working properly.
Try clearing it with compressed air.
Otherwise, you need a professional to repair the camera. You can find a service center on the manufacturer's website.
If this helps, please vote for my solution.
Oct 12, 2009 | Nikon Coolpix S210 Digital Camera
Lens error when turned on unit, with buzzing sound
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 15, 2009 | Nikon Coolpix S210 Digital Camera
S210 Lens Error
Jul 24, 2009 | Nikon Coolpix S210 Digital Camera
Lens error, restart camera, ive tried everything!
Take a look at this tip. Bear in mind that your camera may be broken.
May 12, 2009 | Canon PowerShot A470 Digital Camera
Pentax Optio M20
When the camera is turned on, the lens extends, makes a slight buzzing sound and then retracts and the camera turns off.
Jan 01, 2008 | Pentax Optio S Digital Camera
Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
Oct 27, 2007 | Pentax Optio S50 Digital Camera
I get a buzzing sound
Hello Rrosario35, This problem is related to the lens assembly. The camera will check if these work properly when it's being powered on. If something goes rong here it will turn off or display you some error messages. This problem occures when some of the lens mechanisms get out of place and jamms or damages other components. As the lens assembly is a very delicate mechanism I would suggest you to go back to the service center that fixed it the first time and ask them to check it. Don't try to power the camera on anymore because the lens assembly could be damaged further or beyound repair if the servo-motors are trying to alling the lens something jamms them and not allowing them to move properly. This will force the servo-motors and they could damage other components or themselves. It could be fixed, but don't force the camera to work anymore for the time being. Please post back if more informations are required.
Mar 22, 2007 | Kodak EasyShare V570 Digital Camera
Nikon COOLPIX S230 Digital Camera Logo
59 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
