Turning on everdure brigadier gas heater after being in storage and not getting anything on the LED display except squares along the top row!!
3 Suggested Answers
kfwilso
  • 45 Answers
SOURCE: i need my everdure gas
you will need the conversion kit for the heater and an autorised gas fitter to convert if in wa perth contact me on 0439905607
Posted on Jun 18, 2011
  • 4736 Answers
SOURCE: Hi, I have an Everdure natural
Mark, Natural Gas pilot flames are fairly long. Usually about 2" to 2 1/2" long. However from what you are describing about the pilot flame licking the ceramic plaques of the heater is not normal. Plus, you indicated that you're having a hard time lighting the pilot. All of this leads me to believe, that the unit needs to be thoroughly cleaned inside and out. Especially, if it hasn't been professionally serviced on at least, an annual basis. Vent-free or Flue-less heating appliances collect a lot of dust, lint, etc when in operation. Because whatever is floating in the household is going to eventually work it's way into the heater and clog things up.
Cleaning the unit is something you can do yourself, with minimal tools. A vacuum cleaner with a hose, brush attachment, crevice tool and a can of compressed air with a straw nozzle (like you clean you computer with) is all you need. The compressed air with a straw nozzle is used to blow out the pilot tip. this won't be mentioned in the Owner's Manual. http://www.everdure.com/MANUALS/HEATERs/Gas/EC%20&%20ECR%20User%20manual.pdf
I hope all of this will help you troubleshoot and solve the problem. Cheers....
Posted on Jul 20, 2011
Testimonial: "Thankyou for your insight, the explanation is very clear and should be no trouble to follow. Much appreciated."
Dell 25UXR A12870-408 Socket 370 ATX RDRAM Motherboard front panel diagram
http://www.ebay.com/sch/sis.html?_nkw=Asus+TUV4X+Socket+370+Motherboard+6+PCI+PIII+1GHz+CPU+
I put Dell 25UXR A12870-408 in my browser search bar, in the hopes of seeing the motherboard, and the Front Panel header.
The above was the best search hit I got.
Ebay is a little whacked with their search engine, sometimes; but the above made me wonder.
Why would you list the Asus TUV4X ,along with the Dell motherboard I am looking for?
Probably just their search engine trying to advertise anything close.
Motherboards do not seem to be the same, except they all use a Socket 370 processor socket.
So out of curiosity, I would like you to look at the Front Panel header, on an Asus TUV4X,
http://www.ebay.com/itm/ASUS-TUV4X-Socket-370-Motherboard-W-SL52P-800Mhz-CPU-Heatsink-M425-/251197524658?pt=LH_DefaultDomain_0&hash=item3a7c8a0ab2
Set your mouse cursor in the middle of the photo, to use the
Zoom In feature.
Now move all the way to the right, to the right of the bottom white PCI slot.
Immediately above that bottom PCI slot, is a row of pins.
You can almost make out FRT_PANEL.
(Of course I'm using a 26 inch HDTV for my main monitor, and that helps, lol!)
What my question is, are the pins in a row/s like that on yours?
Oh, photo of the Dell 25UXR?
http://www.ebay.com/itm/Dell-25UXR-A12870-408-Socket-370-ATX-RDRAM-Motherboard-PIII-SL4C8-1-0-GHz-CPU-/190754347389?pt=US_Motherboard_CPU_Combos&hash=item2c69d8597d
Yes, even with this large monitor, THAT photo does me no good.
(RCA L26HD31. I'm using dual monitors. Also using HP 2009M)
If the Front Panel header pins are arranged like that, I believe we can use the old process of elimination.
Looks like an 18 or 20-pin header.
Some of those pins are used for a speaker. (Guessing)
Some of those pins are Not used. (Not guessing)
The procedure is to have the Power Supply plugged in, then use an LED light to test with.
Old Power On LED, or Harddrive activity LED, whatever.
Just needs to be a TWO wire LED.
Let's number the pins.
Let's say they are numbered ODD for the Top row, and EVEN for the Bottom row.
I don't know where Pin 1 is. Should be a 1 silkscreened on the motherboard, next to Pin 1.
For this example let's say it is on the Top row, and all the way to the LEFT.
That would make the Top row pinout, from LEFT to RIGHT;
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Bottom row, from Left to Right;
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20.
My thinking is to touch the two wires from the LED, to Pins 1 and 3.
Power Supply doesn't come on?
Go to Pins 5 and 7.
Go along the Top row, then go along the Bottom row; in this fashion.
When you get to the 2 pins for the Power On switch, there will be a tiny spark, and the Power Supply will come on.
Using an LED light you cannot cause any harm to the motherboard.
HOWEVER, the Power On switch is a Momentary Contact Switch.
Do NOT keep the LED wires on the Power On switch pins, more than 2 seconds.
Power Supply on, and running.
Now, touch two pins, and the LED blinks?
HarDDrive activity LED light.
LED stays on?
Power On LED light.
Computer restarts?
Restart switch pins.
Usually it will be the first 8 pins that will be used.
4 on the Top row, 4 on the Bottom row.
Post back in a Comment.
Regards,
joecoolvette
Mar 10, 2013 | Computers & Internet
I need my everdure gas heater to be converted from natural gas to lpg,could you help,thanks
Jun 10, 2011 | Heating & Cooling
No gas coming threw to heater everdure brigadire there is spark but no flame or gas
Check to make sure that the gas line to the unit is in fact, turned ON. Check the pilot for obstructions, as it may need cleaning. In addition, the gas control valve on the heater, may be in the wrong position or setting for lighting the furnace. And finally, check any other gas appliances you have, to see if they are functioning properly. If they're not, your gas may have been turned OFF, by your gas provider.
May 03, 2011 | Heating & Cooling
How do II unlock the keypad for my latitude e5510 laptop?
Hi
Please try using the fn blue switch bottom left of keyboard along with a corresponding key from the top row of keys
so have a look at the top row of keys and look either for the nulock key which mine is the F11 key
or look for one with squares on it and press that along with the FN key
Mar 12, 2011 | Dell Latitude E5510 156 LED Notebook PC...
Where do i plug in the power switch in the mother board
The eMachines T5274 uses an ECS 945GCT-M3 motherboard.
This is ECS Support, and the download page for the motherboard manual,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&CategoryID=1&MenuID=16&LanID=0
To the right of the Download Site heading, (At the bottom), left-click on the country nearest yours.
This is a PDF file download. Takes a few seconds to see the first page come up, and additional time for the file to fully download.
After the file has fully downloaded, go to Page 11.
(The PDF file page number box at the top, next to the blue Down Arrow, will show 11)
In the motherboard photo shown, the number 12 points to Panel1.
This is the Front Panel header.
(The Front Panel is the plastic front of your computer. This particular connector is referred to as a Header)
Barring you cannot download the motherboard manual, I will explain in detail as I go along.
Orient the motherboard in your mind, so that we are both looking at it in the same direction.
Processor to the top, Ram Memory slots to the right, Panel1, (Front Panel header), is at the bottom Right corner, and is along the edge of the motherboard.
Page 33.
There are 2 rows of pins. One row along the top, one row along the bottom.
4 pins along the top, 5 pins along the bottom.
The Bottom row of pins are numbered Odd.
The numbering starts from the Left side of the motherboard, and goes towards the Right.
The Top row of pins are numbered Evenly.
Numbering starts from the Left side of the motherboard, and goes towards the Right.
Top row numbering of pins, starting from the Left side, going towards the Right,
2, 4, 6, 8, and 10. There is No pin 10. Just a flat spot.
Bottom row numbering of pins, starting from the Left side, going towards the Right,
1, 3, 5, 7, and 9
Page 33.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Hard Disk LED (+) The Positive wire of the HDD LED light goes to Pin 1.
The Negative wire of the HDD LED light goes to Pin 3.
More than likely if the wires are marked, only the Positive ( + ) wire will be marked. Usually with a little tag that has + symbol on it.
B) Pins 5 and 7 are for the Reset switch.
IF, a reset switch is offered on your eMachines.
Pin 7 is for the Positive wire. (+)
(It isn't necessary to have a Reset switch. It's a restart switch. Used to restart your computer, and there are many other options available)
C) Pin 9 is reserved, and not used.
D) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire. (+)
(If the two wires are reversed, the Power On LED light will be dim)
E) Pins 6 and 8 are for the Power On switch.
Pin 6 is for the Positive wire (+)
Have any questions regarding this, post in a Comment.
Aug 13, 2010 | eMachines T5274 Desktop PC
Gas heater smells like kerosene and stings the eyes,
this probably occured after you were vanishing timberin your house and has since stopped
Jul 22, 2009 | Rinnai Vent Free Gas Heater/
I need to service an everdure gas heater
if you can smell gas and have not done something about it by now then you should not be thinking about diy
gas is more dangerous that electricity simply because if you can smell it it is already an explosive mixture
get in a gas fitter and get a quote to fix
Jun 02, 2017 | Heating & Cooling
Heating & Cooling Logo
157 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
